Macintosh Performa 630CD
The Macintosh Performa 630CD is the Performa 630 with an internal CD-ROM drive: a low-profile desktop Macintosh with a 33 MHz 68LC040, sold through consumer retail outlets from July 1994. Apple's specification sheet covers the 630 and 630CD together and dates them 1 July 1994; EveryMac gives 18 July 1994.[1][2] Macworld listed Apple's estimated street price in September 1994 as US$1,849 to US$1,899, with 8 MB of RAM, a 250 MB hard drive, a 14-inch monitor and keyboard.[3] The same machine was sold to schools as the Macintosh LC 630 and to business as the Macintosh Quadra 630 (with a full 68040).[3]
The Macintosh Performa 630 page has the configuration table for the whole Performa 630 series, the full specification and a selection of Apple's symptom charts.
Configuration
[edit | edit source]Apple's service manual lists the Performa 630CD as shipped with 8 MB of RAM, a 1.4 MB SuperDrive, a 250 MB IDE hard drive, an internal AppleCD 300i Plus CD-ROM drive, a 14-inch Apple Performa Display Plus and a TelePort send-fax/data modem.[4] The 4 MB soldered to the logic board is topped up by a SIMM in the single SIMM socket.[1][4]
| Item | Specification |
| Processor | Motorola 68LC040 at 33 MHz, no FPU[4][1] |
| RAM | 4 MB built in; 36 MB maximum on a logic board with one SIMM slot (661-0158), 52 MB on a board with two (661-1114)[4] |
| Video | 1 MB DRAM frame buffer, not expandable; up to 16 bits per pixel at 640 × 480, 8 bits at 800 × 600[4] |
| Drives | 1.4 MB SuperDrive, manual insert; 250 MB IDE hard drive; AppleCD 300i Plus. Internal SCSI hard drives are not supported[4] |
| Sound | 8-bit mono input; 8-bit stereo output, 16-bit in CD mode, 0.5 V RMS into 39 ohms[4] |
| Electrical | 100-240 V AC, 50-60 Hz; 45 W maximum, not including the monitor[1][5] |
The Performa 630 Series volume prints the maximum power as "5 W"; Apple's specification sheet and the LC 630/Quadra 630/Performa 640 volume give 45 W.[4][1][5]
CD-ROM drive
[edit | edit source]The internal hard drive is IDE, but the CD-ROM drive is SCSI, set to SCSI ID 3 at the factory.[4] It comes out from the front: remove the drive bezel and the drive security bracket, push up the release latch and pull the drive out of the chassis. It plugs straight into the internal wiring harness, so it can take some force to free.[4] Apple's symptom charts give these cures for CD-ROM faults:[4]
- Drive does not accept a disc: replace the disc if it is dirty or damaged; reseat the drive; replace the drive.
- The Macintosh cannot mount the drive: reseat it; check that its SCSI ID is still 3; replace it.
- An external SCSI device works on its own but not with the internal drive: set the external device to a different SCSI ID from the CD-ROM drive, and check its termination.
Battery
[edit | edit source]Apple's specification sheet gives the battery as 4.5 V alkaline.[1] The Service Source names no battery part and no test voltage. Its symptom charts tell the technician to "Unplug 5.4 battery, wait 20 seconds, plug in battery, and restart computer"; "5.4" is a misprint for 4.5, which the LC 630 volume prints for the same step.[4][5] Leakage from an alkaline pack is neutralised with a weak acid such as vinegar; see Battery Explosion, Capacitor or Corrosion Damage.
[edit | edit source]Apple's exploded views give the same power supply part number, 661-0170, for the Performa 630 series and for the later Performa 6200 and 6300 machines in the same case.[4][6]
Maintenance and repair
[edit | edit source]The Performa 630CD has the LC 630's logic board and case, and the LC 630 guides apply:
- Macintosh LC 630 General Maintenance
- Macintosh LC 630 Troubleshooting
- Macintosh LC 630 Capacitor Replacement Guide
[edit | edit source]- Macintosh Performa 630 Series Service Source: Apple's service manual for the Performa 630, 630CD, 631CD, 635CD, 636, 637CD and 638CD.[4]
- LC 630/Quadra 630/ Performa 640 Service Source[5]
[edit | edit source]- Macintosh Performa 630 and the rest of the Performa 630 series
- Macintosh LC 630
- Macintosh Quadra 630
[edit | edit source]- ↑ 1.0 1.1 1.2 1.3 1.4 1.5 Macintosh Performa 630 and 630CD: Technical Specifications, Apple—link(accessed 2026-09-30) 68LC040 at 33 MHz, no FPU; slots LC, comm, TV, video in; one ADB; DB-15 video; 45 W maximum, 100-240 V, 50-60 Hz; battery type 4.5 V alkaline; 4 MB on the logic board, one 72-pin SIMM slot, 4-36 MB, 80 ns; 1 MB video DRAM; introduced 7/1/1994; Gestalt ID 98; System 7.1.2P with System Enabler 405; 1 MB ROM; 250 MB IDE; 2x CD-ROM.
- ↑ Apple Macintosh Performa 630 (CD) (PC) Specs, EveryMac—link(accessed 2026-09-30) Introduced 18 July 1994, discontinued 1 July 1995; 4 MB or 8 MB; 250 MB IDE; "The Performa 630CD added an internal 2X CD-ROM drive"; educational version LC 630, business version Quadra 630; model M3076; Gestalt ID 98.
- ↑ 3.0 3.1 Jim Heid, "Multimedia Mac", Macworld, vol. 11 no. 9, September 1994, pp. 98-103, table "The Quadra 630 Family Tree" (Apple's estimated street prices). archive.org scan. Performa 630 US$1,449-1,499; Performa 630CD US$1,849-1,899, 8 MB, 250 MB, CD-ROM, 14-inch monitor and keyboard; the Performa 630 line sold through consumer electronics and office-supply outlets, the LC 630 to education and the Quadra 630 to business.
- ↑ 4.00 4.01 4.02 4.03 4.04 4.05 4.06 4.07 4.08 4.09 4.10 4.11 4.12 4.13 Apple Computer, Macintosh Performa 630 Series Service Source (1995), File:Performa 630 series.pdf; see Macintosh Performa 630 Series Service Source. PDF page numbers: title p. 1; General Information pp. 3-6; Performa 630CD configuration p. 8; Processor p. 18; Memory pp. 19-20; Disk Storage p. 21; I/O Interfaces pp. 22-24; Sound and Video p. 26; Electrical p. 27; Symptom Charts pp. 31-46 (battery step pp. 36, 43; CD-ROM p. 41; SCSI p. 42); CD-ROM Drive take-apart pp. 60-63; Exploded View p. 120.
- ↑ 5.0 5.1 5.2 5.3 Apple Computer, LC 630/Quadra 630/Performa 640 Service Source, File:Quadra.lc 630.performa 640.pdf; see LC 630/Quadra 630/ Performa 640 Service Source. Electrical, PDF p. 27 (45 W); symptom chart, PDF p. 37 ("Unplug 4.5 battery").
- ↑ Apple Computer, Performa 6200/6300 Series Service Source, File:Performa 6200.6300.pdf; see Performa 6200/6300 Series Service Source. Exploded View, PDF p. 208: power supply 661-0170 (661-1053 for the 6320 and 6360).
