Macintosh Performa 6116CD
Power Macintosh 6100/66; the Performa 6100 series uses the same case
TypeDesktop personal computer
Released17 July 1995
Discontinued1 April 1996
Intro priceUS$1,900
CPUPowerPC 601 at 60 MHz, 30 MHz bus
Memory8 MB soldered; two 72-pin SIMM sockets, filled in pairs; 72 MB maximum
Storage700 MB internal SCSI hard drive
Display—
Sound16-bit stereo in and out
GraphicsBuilt in, using main memory; HDI-45 port with HDI-45 to DB-15 adapter
ROM4 MB on a ROM SIMM
FPU / coprocessorBuilt into the PowerPC 601
Media1.4 MB SuperDrive (manual-inject); AppleCD 300i Plus CD-ROM drive
Ports / interfaceOne ADB, two GeoPort serial (mini DIN-9), SCSI (DB-25), AAUI-15 Ethernet, HDI-45 video, sound in and out
ExpansionOne slot for a processor-direct card or a 7-inch NuBus card (with adapter)
Power100-240 V AC, 210 W maximum input; 86 W DC output
Dimensions3.4 × 16.3 × 15.6 in (85 × 415 × 399 mm)
Weight14 lb (6.4 kg)
OS / FirmwareSystem 7.5.1 to Mac OS 9.1
Model no.M1596 (Gestalt ID 75)
The Macintosh Performa 6116CD is a model in Apple's Performa 6100 series, the consumer versions of the Power Macintosh 6100/60. Apple's specification sheet gives an introduction date of 17 July 1995 and a 700 MB SCSI hard drive.[1] Apple's service manual names it on its title page but does not list its configuration.[2] EveryMac lists it with an external 14.4k modem and a business software bundle but no monitor, at US$1,900 (order number M4094LL/A).[3]
Apart from the drive, monitor, modem and software it is the same machine as the Macintosh Performa 6110CD, whose page has the model table, the full specification, Apple's symptom charts and the battery and reset procedures.[2]
Performa 6100 series specifications (Apple)
Item Specification
Processor PowerPC 601 at 60 MHz with built-in MMU and FPU and 32K of on-chip cache; optional 256K level 2 cache[2]
RAM 8 MB soldered; two SIMM sockets taking a pair of same-size, 80 ns or faster, 72-pin, non-composite SIMMs; 72 MB maximum[2]
Video HDI-45 port driven from main memory, with no VRAM; HDI-45 to DB-15 adapter for 12-inch to 17-inch Apple monitors[2]
Expansion One internal slot for a processor-direct card, or a 7-inch NuBus card with an adapter[2]
Electrical 100-240 V AC, 50-60 Hz; 210 W maximum input, not including the monitor; 86 W DC output[2]
The battery is a 3.6 V lithium cell.[1] Apple's test, in the Power Macintosh 6100 Service Source, is to replace it below 3.2 V on the 10 V DC range.[4] Neutralise leakage from a lithium cell with bicarbonate of soda; see Battery Explosion, Capacitor or Corrosion Damage.
Maintenance and repair
  1. ↑ 1.0 1.1 Macintosh Performa 6116CD: Technical Specifications, Apple—link(accessed 2026-09-30) PowerPC 601 at 60 MHz, 30 MHz bus; 32K L1 cache, optional L2; optional Intel 486DX2-66; one 7-inch NuBus or PDS slot; HDI-45 video; two GeoPorts; AAUI-15; 210 W maximum, 100-240 V; battery type 3.6 V lithium; 8 MB on the logic board, SIMMs in pairs, 72 MB maximum; introduced 17 July 1995; original system software 7.5.1; Gestalt ID 75; minimum hard drive 700 MB.
  2. ↑ 2.0 2.1 2.2 2.3 2.4 2.5 2.6 2.7 Apple Computer, Macintosh Performa 6100 Series Service Source (1996), File:Performa 6100 series.pdf. PDF page numbers: title p. 1; Product Configurations pp. 8-10; Specifications pp. 21-30; Symptom Charts pp. 33-44.
  3. ↑ Apple Macintosh Performa 6116CD Specs, EveryMac—link(accessed 2026-09-30) 700 MB; external 14.4k modem; business software bundle; no monitor; introduced 17 July 1995, discontinued 1 April 1996; order number M4094LL/A; US$1,900. Supported system software to Mac OS 9.1.
  4. ↑ 4.0 4.1 Apple Computer, Power Macintosh 6100/WS 6150 Service Source, File:Powermac 6100 series.pdf; see Power Macintosh 6100/ WS 6150 Service Source. Battery Verification, PDF pp. 102-103.
