Macintosh IIvi
| Macintosh IIvi (same case as IIvx) | |
| Type | Desktop Personal Computer |
| Released | October 19, 1992 |
| Discontinued | February 10, 1993 |
| Intro price | Not sold in United States |
| CPU | Motorola 68030 @ 16 MHz |
| Memory | 4 MB RAM onboard (expandable to 68 MB) |
| Storage | 40 MB, 80 MB, 160 MB, or 400 MB SCSI hard drive |
| Display | DB-15 video, 640×480 @ 8-bit (512K VRAM) |
| Sound | 8-bit stereo output, mono input |
| Dimensions | 6.0" H × 13.0" W × 16.5" D (15.2 × 33 × 41.9 cm) |
| Weight | 25 lbs (11.3 kg) |
| OS / Firmware | System 7.1 – Mac OS 7.6.1 |
| Predecessor | Macintosh IIci |
| Successor | Macintosh Centris 650 |
| Model no. | M1350 |
The Macintosh IIvi is a desktop personal computer manufactured by Apple Computer, Inc. from October 1992 to February 1993.[1] The IIvi was a cost-reduced version of the Macintosh IIvx, featuring the same 68030 processor but running at 16 MHz instead of 32 MHz, and lacking the L2 cache and FPU of its faster sibling.
The IIvi was sold in South America, Europe, and Japan, but not in the United States. The consumer version sold in the US was the Performa 600.[2]
[edit | edit source]The Macintosh IIvi uses a Motorola MC68030 microprocessor running at 16 MHz.[3]
- Clock Speed: 16 MHz
- Bus Speed: 16 MHz
- Data Path: 32-bit
- L1 Cache: 0.5 KB (on-chip)
- L2 Cache: None
- FPU: Optional Motorola 68882
The IIvi lacks the 32K L2 cache found in the IIvx, making it slower in cache-dependent operations.
Memory
[edit | edit source]RAM Configuration
[edit | edit source]- Onboard RAM: 4 MB soldered
- SIMM Slots: 4 × 30-pin
- SIMM Speed: 80 ns minimum
- Maximum RAM: 68 MB (4 MB onboard + 64 MB in SIMMs)
- SIMM Installation: Four identical SIMMs must be installed as a group
ROM
[edit | edit source]- ROM Size: 1 MB
- ROM Type: Macintosh ROM
VRAM
[edit | edit source]- Standard VRAM: 512 KB (two 256 KB VRAMs)
- Maximum VRAM: 1 MB (two 512 KB VRAMs)
- VRAM Slots: 2 × VRAM SIMM slots
- VRAM Speed: 100 ns
Video
[edit | edit source]- Video Output: DB-15 connector
- Maximum Resolution: 640 × 480 pixels
- Color Depth (512K VRAM): 8-bit (256 colors) at 640×480, 16-bit at 512×384
- Color Depth (1 MB VRAM): 16-bit (thousands) at 640×480
Additional displays can be connected via NuBus video cards.
[edit | edit source]Hard Drive
[edit | edit source]- Interface: SCSI (DB-25 external connector)
- Standard Capacities: 40 MB, 80 MB, 160 MB, or 400 MB
Floppy Drive
[edit | edit source]- Drive Type: Apple SuperDrive (1.44 MB)
- Auto-inject: Yes
Optical Drive
[edit | edit source]- CD-ROM: Optional 2X internal
Input/Output and Expansion
[edit | edit source]Ports
[edit | edit source]- ADB Ports: 2 (Apple Desktop Bus)
- Serial Ports: 2 × Mini DIN-8 RS-422 (Printer and Modem)
- SCSI Port: DB-25 connector
- Video Port: DB-15 connector
- Audio Output: 3.5 mm stereo jack
- Audio Input: 3.5 mm mono jack
Expansion Slots
[edit | edit source]- NuBus Slots: 3
- Processor Direct Slot (PDS): 1
- Expansion Bay: 1 × 5.25" (for CD-ROM)
Power
[edit | edit source]- Power Supply: 230W maximum
- Input Voltage: 100V – 240V AC
- Frequency: 50 – 60 Hz
- PRAM Battery: 3.6V lithium
Case Design
[edit | edit source]The IIvi uses the same high-profile desktop case as the Macintosh IIvx, Performa 600, Macintosh Centris 650, Macintosh Quadra 650, and Power Macintosh 7100. The case includes a front-accessible 5.25" bay for an optional CD-ROM drive.
- Dimensions: 6.0" H × 13.0" W × 16.5" D (15.2 × 33 × 41.9 cm)
- Weight: 25 lbs (11.3 kg)
[edit | edit source]Common maintenance concerns include capacitor leakage, PRAM battery failure, and power supply issues.
For cleaning, battery maintenance, and inspection procedures, see the Macintosh IIvi General Maintenance page.
[edit | edit source]The Macintosh IIvi logic board contains surface-mount electrolytic capacitors that leak over time.
For capacitor specifications and procedures, see the Macintosh IIvi Capacitor Replacement Guide.
[edit | edit source]Common issues include startup failures, video problems, and SCSI errors.
For diagnostics, see the Macintosh IIvi Troubleshooting page.
Technical Specifications
[edit | edit source]| Sub-system | Specification (Macintosh IIvi, October 1992) |
| FPU | Optional Motorola 68882 |
| Bus Speed | 16 MHz |
| ROM | 1 MB |
| RAM | 4 MB onboard + 4 × 30-pin SIMM slots (68 MB max) |
| L1 Cache | 0.5 KB (on-chip) |
| L2 Cache | None |
| Video | 640 × 480 @ 8-bit (512K VRAM), 16-bit with 1 MB |
| Storage | 40/80/160/400 MB SCSI HDD, 1.44 MB SuperDrive |
| Expansion | 3 × NuBus, 1 × PDS, 1 × 5.25" bay |
| Ports | 2 × ADB, 2 × Serial, SCSI, Video, Audio I/O |
Identification
[edit | edit source]| Identifier | Value |
| Apple Model Number | M1350 |
| Gestalt ID | 44 |
