Macintosh IIvi General Maintenance
This guide covers cleaning, PRAM battery management, and common failure points for the Macintosh IIvi.
The IIvi shares its case and many components with the Macintosh IIvx, Performa 600, and later the Macintosh Centris 650. Maintenance procedures are similar across these models.
Opening the Case
  1. Disconnect all cables and peripherals
  2. Remove the two Phillips screws at the rear top corners
  3. Slide the cover backward and lift off
Regular Cleaning
Internal Cleaning
  • Use compressed air to remove dust from the logic board, power supply, and expansion slots
  • Pay attention to NuBus slots and the PDS connector
  • Clean the fan blades and air vents
  • Use isopropyl alcohol (>90%) and a soft brush for stubborn grime
External Case Cleaning
  • Use a damp microfiber cloth and mild soap
  • Avoid harsh chemicals that can damage the plastic
  • The case may yellow over time โ€” see Retrobrite for whitening procedures
PRAM Battery
The IIvi uses a 3.6V lithium battery to retain system settings when unplugged.
Inspection
  • Check for white or green corrosion around the battery holder
  • Measure battery voltage โ€” replace if below 3.0V
  • Inspect nearby components for damage from leakage
Replacement
  • Remove the old battery and clean any corrosion with white vinegar, then isopropyl alcohol
  • Install a fresh 3.6V lithium cell
  • Check trace continuity near the battery
Long-Term Storage
Remove the PRAM battery entirely if storing the machine for extended periods.
Connector Maintenance
Areas to Inspect
  • SIMM sockets โ€” reseat RAM if experiencing memory errors
  • VRAM SIMM sockets โ€” reseat if video issues occur
  • NuBus slots โ€” check for oxidation on card edge connectors
  • PDS connector โ€” check for bent pins
  • Power supply connector โ€” clean if power issues occur
Cleaning Connectors
  • Use DeoxIT D5 contact cleaner on corroded contacts
  • Clean SIMM contacts with a pencil eraser followed by isopropyl alcohol
  • Reseat all socketed components during maintenance
Common Failure Points
Capacitor Leakage
The IIvi logic board contains electrolytic capacitors that leak over time. Symptoms include:
  • Startup failures
  • Random crashes
  • Audio distortion
  • Video artifacts
See Macintosh IIvi Capacitor Replacement Guide for recapping procedures.
Power Supply Issues
The IIvi uses a 230W power supply shared with other compact desktop Macs:
  • Clicking or ticking โ€” failed capacitors
  • No power โ€” check fuse, capacitors, and power switch
  • Intermittent startup โ€” cold solder joints or failing caps
PRAM Battery Damage
Battery leakage affects nearby circuits:
  • System settings not retained
  • Startup failures
  • Clock reset
SIMM Socket Oxidation
Oxidation on SIMM sockets causes:
  • Memory errors
  • Random crashes
  • Failure to boot
Clean sockets with DeoxIT and reseat SIMMs.
Voltage Measurements
Test power rails at the logic board connector:
Rail Expected Voltage Tolerance
+5V 5.00V ยฑ5%
+12V 12.00V ยฑ10%
-5V -5.00V ยฑ10%
-12V -12.00V ยฑ10%
