Macintosh Performa 6300CD
The Macintosh Performa 6300CD is a PowerPC desktop Macintosh with a 100 MHz PowerPC 603e, 16 MB of RAM, a 1.2 GB IDE hard drive and a quadruple-speed CD-ROM drive, in the low-profile case of the Macintosh Quadra 630. Apple's specification sheet dates it 16 October 1995; EveryMac gives 27 January 1996 and lists it at US$2,800 with a 15-inch Apple colour monitor, sold only in North America.[1][2] It is the first model of the Performa 6300 series, and Apple's Performa 6200/6300 Series Service Source covers it with the 6200 models.[3]
Performa 6300 series models
[edit | edit source]| Model | Introduced (Apple) | Processor | RAM | Hard drive | Notes |
| 6290CD | 27 January 1996 | 603e, 100 MHz | 8 MB | 1.2 GB | No monitor; North America only (EveryMac) |
| 6300CD | 16 October 1995 | 603e, 100 MHz | 16 MB | 1.2 GB | 15-inch monitor (EveryMac) |
| 6310CD | 14 February 1996 | 603e, 100 MHz | 16 MB | 1.2 GB | Not sold in the US |
| 6320CD | 22 April 1996 | 603e, 120 MHz | 16 MB | 1.2 GB | Supersedes the 6300CD; TV/video system (EveryMac) |
| 6360 | 1 October 1996 | 603e, 160 MHz | 16 MB | 1.2 GB | Different logic board: DIMMs, PCI slot, no PDS |
All run the PowerPC 603e on a 64-bit, 40 MHz bus.[1][4] Apple says the 6320CD supersedes the 6300CD and differs from it only in having a 120 MHz processor.[3] The Performa 6360 kept the case but has little else in common with the rest of the series; see its own page.[3] EveryMac lists a business version of the 6320CD, the Power Macintosh 6300/120, sold only in Asia.[5]
| Processor | PowerPC 603e at 100 MHz (6290, 6300, 6310) or 120 MHz (6320CD)[3] |
| RAM | 16 MB; 64 MB maximum in two SIMM slots (72-pin, 80 ns or faster); no memory soldered to the board[3][1] |
| Frame buffer | 1 MB of DRAM on the logic board for video, separate from system memory[3] |
| ROM and cache | 4 MB ROM; 256K level 2 cache[3] |
| Drives | 1.4 MB SuperDrive, manual insert; IDE hard drive; CD-ROM drive[3] |
| Video modes | 640 × 480 at 16 bits per pixel (67 Hz or 60 Hz); 800 × 600 at 8 bits (60 or 72 Hz); 832 × 624 at 8 bits (75 Hz, no video input)[3] |
| Sound | 16-bit mono input (a stereo signal is mixed to mono); 16-bit stereo output, nominally 0.5 V RMS into 39 ohms, at a front headphone jack and a rear mini jack; two internal speakers, muted when a plug is in an output jack[3] |
| Serial, SCSI, ADB | Two RS-232/422 ports, mini DIN-8; one external SCSI port (DB-25), up to seven devices; one ADB port (mini DIN-4)[3] |
| Slots | 96/114-pin LC processor-direct slot; 112-pin communications slot; 60-pin video-in slot; 10-pin TV tuner port; optional DB-15 mirroring connector kit[3] |
| Electrical | 100-240 V AC, 47-63 Hz; 125 W; 40 A peak inrush; 2.5 A and 220 W maximum for all line and load conditions[3] |
| Size and weight | 10.95 × 41.95 × 32 cm; 7.7 kg (17 lb) without CD-ROM drive, 8.6 kg (19 lb) with[3] |
Apple's specification sheet gives a lower figure, 55 W maximum at 1.25 A, alongside the Service Source's 125 W supply rating.[1][3]
[edit | edit source]The 6300-series logic board is Apple part 661-1041 (100 MHz) or 661-1175 (120 MHz, 6320CD).[3] Neither has memory soldered on; the 16 MB is in the SIMM slots.[1] On the 6300 board one SIMM slot sits next to the processor, and its heat sink has to come off before a SIMM can be fitted or removed in that slot.[3] The frame buffer is its own 1 MB of DRAM, so video takes none of the system memory.[3] The internal hard drive is IDE; Apple says to replace it like for like, and it plays no part in SCSI IDs or termination. The internal CD-ROM drive is SCSI ID 3 from the factory.[3] The LC processor-direct slot takes many 68030 PDS cards, but cards that work with the main processor, such as RAM caches or FPUs, do not work in it.[3]
The logic board slides out of the back once the plastic I/O door is removed; the drives come out from the front after the front panel.[3] Apple also sold the 603e/100 board and its fence as a finished upgrade kit, the Power Macintosh 5300/6300 Logic Board Upgrade; the Performa 630 Series Service Source lists the same kit as an upgrade for the 630 family.[3][6]
Battery
[edit | edit source]Apple's specification sheets give the battery as 4.5 V alkaline, and the symptom charts call it the "4.5 V battery".[1][3] It sits on a hook-and-loop pad on the logic board with a plug-in lead. Apple's test is to take out the I/O door, logic board and battery, measure on the 10 V DC range and replace the battery below 3.0 V.[3] Leakage from an alkaline pack is neutralised with a weak acid such as vinegar; see Battery Explosion, Capacitor or Corrosion Damage.
Repair extension programme
[edit | edit source]Apple's repair extension programme for system freezes and sudden changes in video colour hue covers the Performa 6300, but not the 6320 or 6360.[3] The repair checks the clock chip at U10 (it should be part 343S1191 or 343S1121) and the cache/ROM DIMM, and replaces the logic board or the DIMM (661-1278) as needed; the full procedure is on the Performa 6200CD page.[3] Open Transport 1.1 does not work on the 6300; it needs 1.1.1, and if that installer reports a hardware issue, the cache/ROM DIMM has to be replaced first.[3]
From Apple's symptom charts
[edit | edit source]| Symptom | Apple's cures, in order |
| Flashing "?" with the 1.2 GB hard drive, cured by a restart | Check the drive firmware with the 1.2 GB Firmware Utility 1.1; replace the drive under warranty if its serial number does not end in "C"[3] |
| Intermittent crashes or hangs | Check for System 7.5 or later; check the clock chip at U10 and the cache/ROM DIMM as in the repair extension; check that an Ethernet card is fully seated[3] |
| Screen dark, no fan, LED off | Check the power connections; the machine powers on only from the keyboard, so try a known-good keyboard; reseat the logic board; unplug the battery for 20 seconds; check the monitor has power; remove cards and peripherals; replace the power supply, then the logic board[3] |
| Eight-tone error chord at start-up | Reseat the SIMMs; replace the SIMMs; replace the logic board[3] |
The Macintosh Performa 6200CD page has a longer selection from the same charts. The start-up chords and Sad Mac codes are on Sad Mac Error Codes.
Maintenance and repair
[edit | edit source]The wiki's guides for this logic board family are written for the all-in-one Performa 5200CD:
- Macintosh Performa 5200CD General Maintenance
- Macintosh Performa 5200CD Troubleshooting
- Macintosh Performa 5200CD Capacitor Replacement Guide
For yellowed case plastics, see Retrobrite.
[edit | edit source]- Performa 6200/6300 Series Service Source: Apple's service manual for the 6200 and 6300 series, including the 6360.[3]
[edit | edit source]- Macintosh Performa 6290CD, Macintosh Performa 6310CD, Macintosh Performa 6320CD, Macintosh Performa 6360
- Macintosh Performa 6200CD
- Power Macintosh 6300
- Macintosh Performa 5300CD, the all-in-one counterpart
- Macintosh Quadra 630
[edit | edit source]- ↑ 1.0 1.1 1.2 1.3 1.4 1.5 Macintosh Performa 6300CD: Technical Specifications, Apple—link(accessed 2026-09-30) PowerPC 603e at 100 MHz; data path 64-bit, 40 MHz; 32K L1, 256K L2; slots LC, comm, TV, video in/out; one ADB; DB-15 video; 55 max watts, 110-240 V; battery type 4.5 V alkaline; no RAM on the logic board, two 72-pin SIMM slots, 16-64 MB, 80 ns; introduced 10/16/1995; form factor Quadra 630; Gestalt ID 42; 19 lb; System 7.5.1 with System Enabler 406; 4 MB ROM; 1.2 GB IDE; 4x CD-ROM.
- ↑ Apple Macintosh Performa 6300CD Specs, EveryMac—link(accessed 2026-09-30) Introduced 27 January 1996, discontinued 1 October 1996; 100 MHz 603e, 40 MHz bus; 16 MB; 1.2 GB IDE; 4X CD-ROM; 15-inch Apple colour monitor; identical to the 6290CD except for the monitor and 16 MB of RAM; both sold only in North America; order number M4425LL/A; model M3076; Gestalt ID 42; US$2,800; supported system software 7.5.1 and 7.5.3 to 9.1.
- ↑ 3.00 3.01 3.02 3.03 3.04 3.05 3.06 3.07 3.08 3.09 3.10 3.11 3.12 3.13 3.14 3.15 3.16 3.17 3.18 3.19 3.20 3.21 3.22 3.23 3.24 3.25 3.26 3.27 3.28 3.29 3.30 3.31 Apple Computer, Performa 6200/6300 Series Service Source, File:Performa 6200.6300.pdf; see Performa 6200/6300 Series Service Source. PDF page numbers: title p. 1; Performa 6320CD and 6300CD p. 6; Performa 6360 p. 7; Open Transport p. 8; Processor-Direct Slot p. 9; IDE Drive p. 16; Logic Board Diagrams pp. 21-23; Processor p. 26; Memory pp. 27-28; Disk Storage p. 29; I/O Interfaces pp. 30-34; Sound and Video pp. 36-38; Electrical pp. 40-41; Physical p. 42; Symptom Charts pp. 46-67; Power Macintosh 6300 Logic Board Upgrade pp. 121-123; 6300 SIMM Upgrade pp. 124-129; Battery Verification pp. 164-165; Reset Button (6320, 6360) pp. 168-169; REA Procedures pp. 175-206; Exploded View p. 208.
- ↑ Apple Technical Specifications pages (accessed 2026-09-30): 6290CD (603e/100; 8-64 MB; introduced 1/27/1996), 6310CD (603e/100; 16-64 MB; introduced 2/14/1996; "not sold in the U.S."), 6320CD (603e/120; 16-64 MB; introduced 4/22/1996), 6360 (603e/160; 8 MB on the logic board, two 168-pin DIMM slots, 16-136 MB, 70 ns; L2 cache optional; slots PCI, comm, TV, video in/out; two GeoPorts; 150 W, 90-270 V; introduced 10/1/1996; Gestalt ID 58). All give data path 64, 40 and battery type 4.5 V alkaline.
- ↑ Apple Macintosh Performa 6320CD Specs, EveryMac—link(accessed 2026-09-30) 120 MHz 603e, 40 MHz bus; 16 MB; 1.2 GB IDE; 4X CD-ROM; TV/video system and 15-inch Apple colour monitor; TV tuner slot occupied as shipped; business version Power Macintosh 6300/120 sold only in Asia; introduced 22 April 1996, discontinued 1 September 1996; order number M4957LL/A; model M3076; Gestalt ID 42; US$2,600.
- ↑ Apple Computer, Macintosh Performa 630 Series Service Source, File:Performa 630 series.pdf; see Macintosh Performa 630 Series Service Source. Power Macintosh 5300/6300 Logic Board Upgrade, PDF pp. 117-118.
