PowerBook Duo 250
PowerBook Duo 250
Apple's drawing of the Duo 250 logic board and display assembly (Service Source, PDF p. 209)
TypeSubnotebook computer
Released21 October 1993
Discontinued1 May 1994
Intro priceUS$2,500
CPUMotorola 68030 at 33 MHz; FPU only in a Duo Dock
Memory4 MB on the logic board; one Duo RAM card slot, to 24 MB
Storage200 MB 2.5-inch SCSI hard drive
Display9-inch active-matrix LCD, 640 × 400, 16 grey levels
Sound—
ROM1 MB
PowerType II NiMH battery; 24 V DC adapter
Dimensions1.4 × 10.9 × 8.5 in (H × W × D)
Weight4.2 lb (1.9 kg)
OS / FirmwareSystem 7.1 to Mac OS 7.6.1
The PowerBook Duo 250 is a PowerBook Duo with a 33 MHz 68030 and a 9-inch active-matrix greyscale screen, introduced on 21 October 1993 with the PowerBook Duo 270c and sold until 1 May 1994. Apple's specification puts it beside the PowerBook Duo 230 in every respect except the display, the 200 MB hard drive and the higher-capacity Type II battery.[1][2] Low End Mac credits the active-matrix screen and the longer-running battery with the Duo line's rise in popularity.[3]
Apple's specifications[2][1]
Item PowerBook Duo 250
Processor Motorola 68030, 33 MHz; 68882 FPU only in a Duo Dock
RAM 4 MB soldered; one Duo RAM card of 4, 6, 8, 10, 12, 16 or 20 MB, to 24 MB, 70 ns[4]
Display 9-inch (229 mm) active-matrix LCD, 640 × 400, 16 shades of grey, CCFL backlight
Storage 200 MB 2.5-inch SCSI hard drive
Main battery NiMH Type II, 1.5 Ah, 4/5 A size cells; about 2 to 3 hours
Power adapter 24 V DC, 1.04 A (25 W)
Gestalt ID 38
Identifying a Duo 250
Apple sold a 250 upgrade kit for the 210 and 230, made up of a Duo 250 logic board and display assembly, and later a 280 kit that turned a 250 into a PowerBook Duo 280. Because of the second kit, Apple warns that the product label on the bezel does not identify a 250. The display cable does: the 210/230, 250 and 280 cables are all different, and Apple shows each one so a technician can tell them apart.[2] The 280 kit supplied a new display cable for this reason. It is slightly longer than the 250 cable, and Apple says to leave the extra length loose.[2]
The 210/230, 250 and 280 display cables (Service Source, PDF p. 158)
Display
The 250 has an active-matrix greyscale panel with a separate inverter board and brightness actuator inside the display housing.[2] Two of Apple's cautions apply only to the 250 and 280:
  • The inside of the 250/280 display housing has a copper surface that flakes or peels when touched, and the flakes can short the system (PDF p. 151).[2]
  • Protective tape covers the inverter board; peeling it off can short the board (PDF p. 161).[2]
Apple's rule for dead pixels on the 250 and 280: replace the display if more than five pixels stay white, or if two or more such voids are within an inch of each other (PDF p. 50).[2] Apple supplied 250 display assemblies, housings and cables to CPRC and international repairers only.[2] MacDat found no electrolytic capacitors on the 250's LCD and had not checked its inverter board.[5]
Logic board
The 250 shares its logic board design with the 210 and 230, and MacDat gives the same seven-capacitor list for all three.[5] Apple's exploded view lists service boards 661-1653 and 661-1672 for the 250.[2] The capacitor positions are on PowerBook Duo Capacitor Replacement Guide.
Common problems
The faults are those of the other 68030 Duos: leaking electrolytics on the logic board, broken screw posts in the display housing, worn-out NiMH batteries and battery contacts out of alignment.[5][2] See PowerBook Duo Troubleshooting and PowerBook Duo General Maintenance.
  1. ↑ 1.0 1.1 Apple, "Macintosh PowerBook Duo 250: Technical Specifications" (retrieved 2026-10-02). 68030 at 33 MHz; FPU optional in dock; 25 W, 1.04 A; Duo NiMH Type II battery; 4 MB on board, one Duo RAM slot, 4-24 MB; 640 × 400 at 4 bits; introduced 10/21/1993, discontinued 5/1/1994; Gestalt ID 38; 4.2 lb; 1.4 H × 10.9 W × 8.5 D in; System 7.1 with PowerBook Duo Enabler v1.0, supported to 7.6.1; 200 MB SCSI hard drive.
  2. ↑ 2.00 2.01 2.02 2.03 2.04 2.05 2.06 2.07 2.08 2.09 2.10 Apple Computer, PowerBook 200 Series Service Source, hosted here as File:PowerBook Duo 200 Series Service Source.pdf (see PowerBook Duo 200 Series Service Source). PDF page numbers: specifications pp. 14-28; video symptom charts pp. 40-50; display housing pp. 145-153; 210/230/250/280 display cable pp. 154-166; 250 upgrade pp. 209-211; 280/280c upgrade pp. 216-226; exploded view p. 266.
  3. ↑ Low End Mac, "PowerBook Duo 250" (retrieved 2026-10-02). Introduced 1993.10.21 at $2,500, discontinued 1994.05.01; improved battery lasting 2.5 hours; 4 MB to 24 MB; power supply M7783; upgrade path Duo 280. Secondary source.
  4. ↑ Apple Computer, Apple Memory Guide (May 2000), hosted here as File:Apple Memory Guide (May 2000).pdf (see Apple Memory Guide). PowerBook Duo 250, PDF p. 109: 4 MB soldered DRAM; cards of 4, 6, 8, 10, 12, 16 or 20 MB; 24 MB maximum; Apple supplies 4 MB and 8 MB cards.
  5. ↑ 5.0 5.1 5.2 MacDat, "PowerBook Duo 250 Capacitor Reference" (retrieved 2026-10-02). Same logic board list as the 210/230: one 330 µF 16 V, three 100 µF 35 V, two 100 µF 25 V (100 µF 10 V on earlier boards), one 33 µF 25 V; the 250's LCD uses no electrolytic capacitors; inverter not checked; early trackballs have one 10 µF 6.3 V. Secondary source.
