Macintosh Performa 5410CD
| Performa 5200. The 5410CD uses the same enclosure. | |
| Released | April 22, 1996[1] |
| Discontinued | February 1, 1997[2] |
| CPU | PowerPC 603e at 120 MHz[1] |
| Memory | 16 MB (8 MB on the logic board); two 168-pin DIMM slots, 136 MB maximum[1] |
| Storage | 1.6 GB IDE hard drive, 4× CD-ROM, 1.4 MB SuperDrive[1] |
| Display | Built-in 15-inch shadow-mask colour display[3] |
| Sound | — |
| Power | 100–240 V AC, 47–63 Hz, 125 W[3] |
| Dimensions | 17.5 × 16 × 15.1 in (445 × 406 × 383 mm), H × W × D[3] |
| Weight | 47 lb (21.3 kg)[1] |
| OS / Firmware | System 7.5.3 with System Enabler 410[1] |
| Predecessor | Performa 5300CD |
| Successor | Power Macintosh 5500 |
The Macintosh Performa 5410CD is a 120 MHz model of the Performa 5400 series that Apple sold outside the United States from April 22, 1996.[1] Its hardware matches the Performa 5400CD except that it has no Ethernet card, leaving the communications slot empty.[1][4] EveryMac says it was sold in Europe and Asia and gives the Japanese order number as M4798J/A.[2]
| Processor | PowerPC 603e at 120 MHz with integrated FPU; 64-bit PowerPC bus; 40 MHz bus[1][3] |
| Cache | 32 KB level 1; optional 256K level 2 on a 160-pin DIMM card[3] |
| RAM | 8 MB on the logic board; two 168-pin DIMM slots for 70 ns or faster, 2K-refresh DIMMs; 136 MB maximum[3] |
| Video | 1 MB DRAM frame buffer; 640 × 480 at 16-bit; 800 × 600 and 832 × 624 at 8-bit on Apple's technical-specification page (16-bit at 800 × 600 in the Service Source); no video input at 832 × 624[3][1] |
| Storage | 1.6 GB IDE hard drive; 4× CD-ROM; 1.4 MB SuperDrive, manual insert[1] |
| Expansion | One 32-bit PCI slot (7-inch cards); communications slot (empty); 60-pin video-in slot; TV/FM tuner option[3] |
| Ports | Two serial (LocalTalk and GeoPort), one SCSI (DB-25), one ADB; DB-15 mirror video output with the optional video connector kit[3] |
Service notes
[edit | edit source]The 5400 series is serviced at module level from Apple's Service Source; the module part numbers, the original and Rev. B chassis, and the known faults are on Macintosh Performa 5400. The machine contains a CRT; read CRT Discharge Procedure before opening it. The clock battery is a 4.5 V alkaline pack that Apple replaces below 3.0 V, and alkaline leakage is neutralised with dilute white vinegar; see Battery Explosion, Capacitor or Corrosion Damage.
- Macintosh Performa 5400 General Maintenance
- Macintosh Performa 5400 Troubleshooting
- Macintosh Performa 5400 Capacitor Replacement Guide
Download: Powermac.perf_5400.5500.pdf. Description page: Power Macintosh/Performa 5000 Series Service Source.
[edit | edit source]- ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 Macintosh Performa 5410CD: Technical Specifications, Apple—link(accessed 2026-09-30) Source for the introduction date, "not sold in the U.S.", no Ethernet, 8 MB on the logic board, 16 MB standard, 1.6 GB drive, 4× CD-ROM, 4.5 V alkaline battery, 47 lb and System 7.5.3 with System Enabler 410.
- ↑ 2.0 2.1 Macintosh Performa 5410CD Specs, EveryMac.com—link(accessed 2026-09-30)
- ↑ 3.0 3.1 3.2 3.3 3.4 3.5 3.6 3.7 3.8 Apple Computer, Power Macintosh/Performa 5000 Series (5400 and 5500) Service Source, 1997, Specifications chapter: Processor (pp. 2–3), Memory (pp. 4–6), Disk Storage (pp. 7–8), I/O Interfaces (pp. 9–12), Sound and Video (pp. 15–17), Electrical (p. 23), Physical (p. 24). Hosted as File:Powermac.perf_5400.5500.pdf; see Power Macintosh/Performa 5000 Series Service Source.
- ↑ Macintosh Performa 5400CD: Technical Specifications, Apple—link(accessed 2026-09-30)
