Macintosh Performa 430
The Macintosh Performa 430 is a desktop Macintosh sold by Apple through consumer retail shops. It is the Macintosh LC II under a Performa name; the Performa 400, 405, 410 and 430 are the same hardware.[1] In Apple's service manual the 430 differs from the Performa 405 only in its 120 MB hard drive and its bundled monitor, the Performa Display Plus.[2]
Apple gives the introduction date as April 12, 1993, with System 7.1P2 as the original system software.[3] EveryMac gives October 18, 1993 for the introduction and November 1, 1993 for the discontinuation, a US price of US$1,500, order number M1721LL/A and model number M1700.[4]
[edit | edit source]| Item | Figure |
| Processor | Motorola 68030 at 16 MHz; 16-bit data bus; no FPU socket |
| RAM | 4 MB on board; two 30-pin SIMM sockets, filled in pairs with 100 ns 1, 2 or 4 MB SIMMs; 10 MB maximum |
| ROM | 512K |
| VRAM | One VRAM SIMM socket: 256K gives 512 × 384 at 8-bit and 640 × 480 at 4-bit; 512K gives 16-bit and 8-bit |
| Floppy drive | Apple SuperDrive, 1.4 MB (auto-inject) |
| Hard drive at introduction | 120 MB SCSI |
| Ports | One ADB, two serial (printer and modem, mini DIN-8), SCSI DB-25, DB-15 video, sound in and out |
| Expansion | One 96-pin processor-direct slot for 020/030 cards |
| Electrical | 100–240 VAC, 50–60 Hz, automatically configured; 50 W maximum excluding monitor (Performa 400 figure) |
| Size and weight | 3.0 × 12.2 × 15.0 in (7.7 × 31.0 × 38.2 cm); 8.8 lb (4.0 kg) |
Sources: Apple's technical specifications and the Performa 400 Series Service Source, pp. 3–15.[3][2] The Service Source prints one maximum-power figure for the 400, 405, 410 and 430, under "Performa 400". Apple's technical specifications give the input range as 90–240 V; the Service Source gives 100–240 VAC. Both agree that the supply configures itself, so there is no voltage selector.
The machine accepts 12 MB (4 MB on board plus two 4 MB SIMMs) but addresses only 10 MB. With 4 MB SIMMs in both sockets, the lower 2 MB of the on-board RAM cannot be addressed.[3][2]
The Service Source lists a 512K VRAM SIMM for the 400, 405, 410 and 430 (p. 6); EveryMac says the 430 shipped with 256 KB.[2][4] Check the SIMM fitted before assuming the colour depth.
The PRAM battery is a 3.6 V lithium cell, Apple part 742-0011; Apple says to replace it below 3.0 V. The power supply is part 661-1733, shared with the whole LC family.[3][2]
Known faults
[edit | edit source]- Leaking surface-mount electrolytic capacitors on the logic board and in the power supply. The LC II board list is on Macintosh LC II Capacitor Replacement Guide.
- A flat PRAM battery: Apple's charts for this family put "Check batteries" first for "No video" and in the no-power entries.[2]
- The 10 MB ceiling above is normal behaviour, not a memory fault.
See Macintosh Performa 430 Troubleshooting and Macintosh LC II Troubleshooting.
Service documentation
[edit | edit source]Apple covers the Performa 430 in the Macintosh Performa 400 Series Service Source, and the same board under its LC II name in the Macintosh LC Series/Quadra 605 Service Source.[2]
[edit | edit source]- Macintosh LC II
- Macintosh Performa 430 Troubleshooting
- Macintosh LC II General Maintenance
- Macintosh LC II Capacitor Replacement Guide
- Macintosh Performa 400
- Macintosh Performa 405
- Macintosh Performa 410
[edit | edit source]- ↑ Low End Mac, "Apple's Performa Line, 1992 to 1997".
- ↑ 2.0 2.1 2.2 2.3 2.4 2.5 2.6 Apple Computer, Service Source: Macintosh Performa 400 Series (1995), File:Performa 400 series.pdf; see Macintosh Performa 400 Series Service Source. Page numbers are PDF pages.
- ↑ 3.0 3.1 3.2 3.3 Apple, "Macintosh Performa 430: Technical Specifications".
- ↑ 4.0 4.1 EveryMac, "Macintosh Performa 430 Specs".
