Macintosh Performa 200
The Macintosh Performa 200 is a compact all-in-one Macintosh sold by Apple from September 14, 1992 to October 18, 1993.[1] It is the Macintosh Classic II with Performa badging, sold through consumer retail shops with bundled software; the hardware is the same, and Apple covers both in one service manual.[2][3] It was one of the first three Performa models, with the Performa 400 and 600.[2]
EveryMac gives the US price as US$900; Low End Mac gives US$1,250.[1][2]
[edit | edit source]| Item | Figure |
| Processor | Motorola 68030 at 16 MHz |
| RAM | 2 MB, expandable to 10 MB; Apple prints 120 ns or faster SIMMs |
| ROM | 512K |
| PRAM | 256 bytes |
| Cache connector | 44-pin connector for optional memory expansion |
| Floppy drive | Internal 1.4 MB; optional external 800K or 1.4 MB drive on the DB-19 port |
| Hard drive | Internal 40 or 80 MB SCSI; optional external SCSI drives |
| Ports | SCSI (DB-25), one ADB (mini DIN-4), two RS-422 serial (mini DIN-8), external floppy (DB-19), headphone jack |
| Microphone | Electret, omnidirectional; 4 mV peak to peak at normal volume |
| Sound | 8-bit mono at 22 kHz sampling; the stereo jack carries the same signal on both channels |
| Display | 9-inch monochrome, 512 × 342 |
| Electrical | 100–120 VAC, 47–63 Hz, 100 W maximum |
Apple's processor entry reads "32-bit internal data bus"; the path to memory is 16 bits wide.[3][1] The two 30-pin SIMM sockets on the logic board take SIMMs in matching pairs.[1] Apple's Service Source says 120 ns SIMMs; EveryMac gives 100 ns.[3][1]
The 44-pin connector is described by Apple as a cache connector "for optional memory expansion", taking 256K × 4-bit DRAMs.[3] EveryMac describes it as a slot intended for an FPU that Apple never released.[1]
The electrical figures are Apple's 100–120 V figures. Machines sold for 220–240 V mains have a different power/sweep board; see Macintosh Classic II Capacitor Replacement Guide.
[edit | edit source]The machine has two main boards, the logic board and a combined power/sweep board that holds the power supply and the CRT drive circuits. Apple's manual calls it the power/sweep board throughout; the SE and SE/30 split these functions between an analogue board and a separate power supply.[3] The PRAM battery is a 3.6 V lithium cell; Apple's rule is to replace it below 3.0 V, measured with the cover off, the CRT discharged and the logic board out.[3][1]
Known faults
[edit | edit source]Apple's symptom charts point most video, power and noise faults at the power/sweep board, and memory faults at the SIMMs and logic board.[3] In practice the surface-mount electrolytics on the logic board and the capacitors on the power/sweep board have aged, and the PRAM battery can leak. See Macintosh Classic / Classic II Troubleshooting and Macintosh Performa 200 Troubleshooting.
The CRT and the power/sweep board carry dangerous voltages. Discharge the CRT before working inside; see CRT Discharge Procedure.
Service documentation
[edit | edit source]Apple's Macintosh Classic/Classic II/Performa 200 Service Source is hosted at Macintosh Classic/ Classic II/Performa 200 Service Source (115 pages). Its Adjustments chapter covers the light meter, video and yoke; it has no power-supply voltage adjustment.[3]
[edit | edit source]- Macintosh Classic II
- Macintosh Performa 200 Troubleshooting
- Macintosh Classic / Classic II General Maintenance
- Macintosh Classic / Classic II Troubleshooting
- Macintosh Classic II Capacitor Replacement Guide
- Macintosh Classic II Memory Upgrade Guide
- Retrobrite
[edit | edit source]- ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 EveryMac, "Macintosh Performa 200 Specs".
- ↑ 2.0 2.1 2.2 Low End Mac, "Apple's Performa Line, 1992 to 1997".
- ↑ 3.0 3.1 3.2 3.3 3.4 3.5 3.6 3.7 Apple Computer, Service Source: Macintosh Classic/Classic II/Performa 200, File:Classic ii.performa 200.pdf; see Macintosh Classic/ Classic II/Performa 200 Service Source. Page numbers are PDF pages.
