Macintosh Performa 275
Macintosh Color Classic II, the same machine as the Performa 275 with a different badge
TypeAll-in-one personal computer
ReleasedOctober 1, 1993
DiscontinuedNovember 1, 1995 (EveryMac)
CPUMotorola 68030 at 33 MHz
Memory4 MB on board, expandable to 36 MB
Storage80 or 160 MB SCSI hard drive; 1.4 MB SuperDrive
Display10-inch Trinitron colour CRT, 512 × 384
Sound8-bit mono
Dimensions37.0 × 25.2 × 32.15 cm (14.5 × 9.9 × 12.6 in)
Weight10.2–10.5 kg (22.5–23.2 lb)
OS / FirmwareSystem 7.1 – Mac OS 7.6.1
PredecessorPerforma 250
Model no.M1600
The Macintosh Performa 275 is a compact all-in-one Macintosh with a colour screen, introduced on 1 October 1993. It is the Macintosh Color Classic II sold under a Performa name, and was not sold in the United States.[1][2] EveryMac says it was sold only in Asia, and gives the discontinuation date as 1 November 1995 and the Japanese order number as M2498J/A.[3] Apple lists its original system software as J-7.1, the Japanese release of System 7.1, with System Enabler 403.[1]
Apple's technical specifications
Item Figure
Processor Motorola 68030 at 33 MHz, 32-bit data path; optional 68882
RAM 4 MB on board; one 72-pin SIMM socket (1 to 32 MB SIMMs, 80 ns); 36 MB maximum
ROM 1 MB
VRAM 256K built in; 512K with a 256K VRAM SIMM
Colour depth 512 × 384 at 8-bit with 256K; 16-bit with 512K
Ports Two ADB, printer and modem serial, SCSI DB-25, microphone, speaker
Expansion One LC processor-direct slot
Electrical 90–240 V, 47–63 Hz, 100 W maximum; soft power
PRAM battery 3.6 V lithium
Source: Apple technical specifications.[1]
Apple's Color Classic II/Performa 275 Service Source gives different memory figures: a 16-bit data bus, a dual 30-pin SIMM slot and 10 MB maximum with 100 ns SIMMs. These are the Color Classic's figures, printed unchanged apart from the 33 MHz clock.[4] Apple's technical specifications and EveryMac both give a single 72-pin socket, 80 ns SIMMs and 36 MB.[1][3] Count the sockets on the board before buying memory.
The display is a 10-inch diagonal (9-inch viewable) Trinitron at 512 × 384 and 76 dpi, and the supply is a universal 90–240 VAC unit.[4] Apple's battery rule is to replace the cell below 3.0 V.[5]
The logic board comes out of the back of the machine once the I/O door is removed. Apple's charts send smoke, power and most picture faults to the analogue board, which holds the power supply and the CRT drive circuits.[6] The CRT and analogue board carry dangerous voltages; discharge the CRT before working inside. See CRT Discharge Procedure.
Known faults
Faults, capacitor lists and repairs are those of the Color Classic II:
Service documentation
Apple's Color Classic II/Performa 275 Service Source is hosted at Macintosh Color Classic II/ Performa 275 Service Source (137 pages). Its Adjustments chapter covers geometry, video, convergence, yoke and the light meter; it has no power-supply adjustment.[4]
  1. ↑ 1.0 1.1 1.2 1.3 Apple, "Macintosh Performa 275: Technical Specifications".
  2. ↑ Low End Mac, "Apple's Performa Line, 1992 to 1997".
  3. ↑ 3.0 3.1 EveryMac, "Macintosh Performa 275 Specs".
  4. ↑ 4.0 4.1 4.2 Apple Computer, Service Source: Macintosh Color Classic II/Performa 275, Specifications, PDF pp. 6–8, File:Color classic ii.perf 275.pdf; see Macintosh Color Classic II/ Performa 275 Service Source.
  5. ↑ Apple Computer, Service Source: Macintosh Color Classic II/Performa 275, Battery Verification, PDF p. 91, File:Color classic ii.perf 275.pdf.
  6. ↑ Apple Computer, Service Source: Macintosh Color Classic II/Performa 275, Symptom Charts and Take Apart, PDF pp. 19–39, File:Color classic ii.perf 275.pdf.
