Macintosh Color Classic II Capacitor Replacement Guide
The Macintosh Color Classic II logic board and analog board contain electrolytic capacitors that leak after 30+ years. This guide provides capacitor specifications and replacement procedures.
The Color Classic II uses the same logic board as the LC 550/Performa 550, so capacitor specifications are identical.[1]
Why Recap?
[edit | edit source]Electrolytic capacitors contain liquid or gel electrolyte that leaks over time. The leaked electrolyte is:
- Conductive — creates short circuits between traces
- Corrosive — destroys copper traces and attacks solder joints
The Color Classic II's logic board has capacitors clustered around the sound chip (343S0129). Leakage in this area commonly destroys traces, requiring repair beyond simple capacitor replacement.[2]
CRT Safety Warning
[edit | edit source]Discharge the CRT anode before working on the analog board. The CRT retains 10,000+ volts even when unplugged. See CRT Discharge Procedure.
Logic Board Capacitors
[edit | edit source]The Color Classic II / LC 550 logic board contains 9 surface-mount electrolytic capacitors:[3]
| Capacitance | Voltage | Qty | Package | Recommended Replacement |
| 47 µF | 16V | 6 | SMD electrolytic | KEMET T491D476K016AT (tantalum) |
| 100 µF | 6.3V | 2 | SMD electrolytic | KEMET T491D107K006AT (tantalum) |
| 10 µF | 16V | 1 | SMD electrolytic | KEMET T491B106K016AT (tantalum) |
Replacement Options
[edit | edit source]Tantalum (recommended):
- Solid electrolyte — cannot leak
- Available from Mouser, Digi-Key
- Slightly larger footprint than original SMD electrolytics
Polymer electrolytic:
- Panasonic OS-CON or similar
- No liquid electrolyte
- Lower ESR than tantalum
Standard electrolytic:
- Matches original footprint
- Will eventually leak again (but buys another 20-30 years)
- Use 105°C rated, low-ESR types
Analog Board Capacitors
[edit | edit source]The Color Classic II analog board contains the power supply, deflection circuits, and video amplifier. It has 40+ capacitors. The most failure-prone capacitor is the 3300µF 16V main filter capacitor.
Critical Capacitors
[edit | edit source]| Reference | Capacitance | Voltage | Type | Notes |
| CF8, CP39 | 3300 µF | 16V | Radial electrolytic | Main filter — causes display problems when failed |
| CP30 | 330 µF | 400V | Radial electrolytic | Primary filter — high voltage, use quality replacement |
| CP13, CP14 | 1000 µF | 16-35V | Radial electrolytic | Secondary filter |
| CP40, CP42 | 5600 µF | 10V | Radial electrolytic | Low voltage rail filter |
Complete Analog Board Capacitor List
[edit | edit source]The following list is from powercc.org. Board revisions may vary — always verify against your specific board:[4]
| Ref | Value | Voltage | Type |
| CD3 | 10 µF | 16V | Electrolytic |
| CF2 | 4.7 µF | 50V | Electrolytic |
| CF7 | 100 µF | 25V | Electrolytic |
| CF8 | 3300 µF | 16V | Electrolytic |
| CF9 | 220 µF | 25V | Electrolytic |
| CF10 | 220 µF | 35V | Electrolytic |
| CF11 | 470 µF | 35V | Electrolytic |
| CL4 | 100 µF | 25V | Electrolytic |
| CL11 | 1 µF | 50V | Electrolytic |
| CL13 | 2.2 µF | 200V | Electrolytic |
| CL14 | 47 µF | 100V | Electrolytic |
| CL19 | 10 µF | 250V | Electrolytic |
| CL21 | 100 µF | 100V | Electrolytic |
| CL23 | 100 µF | 6.3V | Electrolytic |
| CL24, CL31 | 1 µF | 50V | Electrolytic |
| CL33, CL34 | 2.2 µF | 100V | Electrolytic |
| CL35 | 0.47 µF | 100V | Electrolytic |
| CP9, CP15, CP34 | 100 µF | 25V | Electrolytic |
| CP10 | 1 µF | 50V | Electrolytic |
| CP12 | 100 µF | 100V | Electrolytic |
| CP13 | 1000 µF | 35V | Electrolytic |
| CP14, CP41 | 1000 µF | 16V | Electrolytic |
| CP30 | 330 µF | 400V | Electrolytic |
| CP35, CP47, CP54, CP55 | 1 µF | 50V | Electrolytic |
| CP39 | 3300 µF | 16V | Electrolytic |
| CP40, CP42 | 5600 µF | 10V | Electrolytic |
| CP43, CP44 | 470 µF | 25V | Electrolytic |
| CP46 | 1000 µF | 10V | Electrolytic |
| CP56 | 330 µF | 16V | Electrolytic |
| CS4 | 1 µF | 50V | Electrolytic |
| CV13 | 10 µF | 100V | Electrolytic |
| CV17, CV21 | 100 µF | 25V | Electrolytic |
| CV18, CV19, CV20 | 2.2 µF | 200V | Electrolytic |
| CV39, CV40 | 1 µF | 50V | Electrolytic |
Note: Film and ceramic capacitors (marked "poly capacitor" or with values like .22µF 250V) do not typically need replacement unless visibly damaged.
Tools Required
[edit | edit source]- Soldering iron with temperature control (for SMD: fine tip; for through-hole: chisel tip)
- Hot air rework station (optional but helpful for SMD removal)
- Solder (60/40 or 63/37, 0.5-0.8mm for SMD, 0.8-1.0mm for through-hole)
- Flux (no-clean or rosin)
- Solder wick and desoldering pump
- Isopropyl alcohol (>90%) and brushes
- Multimeter
- Safety glasses
Logic Board Procedure
[edit | edit source]Removal
[edit | edit source]- Heat one terminal while gently tilting the capacitor
- Alternate terminals until the capacitor releases
- Or use hot air at 350-380°C with heat shields around plastic connectors
Cleaning
[edit | edit source]- Remove all electrolyte residue with isopropyl alcohol
- Inspect traces for corrosion damage
- Use a multimeter to check continuity on traces near capacitors
- Repair damaged traces with conductive pen or jumper wire
Installation
[edit | edit source]- Tin one pad with fresh solder
- Position new capacitor (verify polarity — tantalum: stripe marks positive)
- Tack one terminal
- Solder second terminal
- Reflow first terminal
- Clean flux residue
Analog Board Procedure
[edit | edit source]Safety
[edit | edit source]- Discharge CRT first
- The analog board contains high-voltage capacitors (250V, 400V) — treat them with respect
- Wait for large capacitors to discharge before removing (or discharge manually with resistor)
Through-Hole Replacement
[edit | edit source]- Desolder old capacitor using solder wick or pump
- Clean holes with solder wick
- Insert new capacitor (verify polarity — stripe marks negative on electrolytic)
- Solder both leads
- Trim excess leads
- Inspect for solder bridges
High-Voltage Capacitors
[edit | edit source]- CP30 (330µF 400V) — use quality 105°C capacitor rated for switching power supplies
- Do not substitute lower voltage ratings
- Observe polarity carefully
Post-Recap Testing
[edit | edit source]- Visual inspection — check all polarities and solder joints
- Continuity test — verify no shorts between power rails and ground
- Power-on test — start with logic board disconnected; verify PSU voltages
- Full test — reconnect logic board; verify startup chime and video
Expected Voltages
[edit | edit source]| Rail | Voltage | Tolerance |
| +5V | 5.00V | ±5% |
| +12V | 12.00V | ±10% |
| -5V | -5.00V | ±10% |
Purchasing Kits
[edit | edit source]Pre-assembled capacitor kits are available from:
- Console5 (console5.com) — logic board and analog board kits
- Recap-a-Mac (recapamac.com.au) — tantalum kits with guides
- Various eBay sellers
