Macintosh Color Classic Capacitor Replacement Guide
The Macintosh Color Classic has surface-mount electrolytic capacitors on its logic board and through-hole electrolytics on its analogue board, which is also the power supply. Recap-a-Mac, which calls the Color Classic the second most popular board for recapping after the SE/30, reports four leaky capacitors around the sound chip at the top left of the logic board and trace damage around that chip on the boards it repairs.[1] The same machine was sold as the Macintosh Performa 250.
Safety
The logic board comes out without opening the case or touching the CRT: open the I/O door at the back and pull the board straight out. On refitting, check that no bent metal tab on the chassis can touch the underside of the board.[2]
Battery first
Apple's procedure is to remove the logic board, measure the cell on the 10 V DC range, and replace it if it reads below 3.0 V.[4] Take an old cell out before recapping. Low End Mac reports that most Color Classics use a 3.6 V half-AA lithium cell but some use a 4.5 V Rayovac 840, so check what is fitted.[5] Clean lithium-cell residue with bicarbonate of soda, then water and isopropyl alcohol, not vinegar. See Battery Explosion, Capacitor or Corrosion Damage.
Capacitor inspection
Recap-a-Mac's finding on this board is leakage, with trace damage round the sound chip.[1] Look for dark haloes or dried crust at the base of the cans, green or dull solder on nearby IC pins, and broken traces, especially around the sound chip. On the analogue board, look for domed tops, crust at the leads and staining under the cans. See Capacitor Failure Symptoms.
Logic board
Color Classic logic board (820-0367-C)
Reference Capacitance Voltage
C2 100 µF 6.3 V
C3 100 µF 6.3 V
C4 47 µF 16 V
C5 47 µF 16 V
C6 47 µF 16 V
C8 10 µF 16 V
C9 47 µF 16 V
C10 47 µF 16 V
C11 47 µF 16 V
Designators from Console5's list for board 820-0367-C.[6] Recap-a-Mac and powercc.org both count six 47 µF 16 V, two 100 µF 6.3 V and one 10 µF 16 V, which agrees, and Recap-a-Mac's photograph of an 820-0367-C board shows them at these positions.[1][7] BOMARC's schematic of the earlier 820-0367-B board draws the same values at the same nine positions: 100 µF 6.3 V at C2 and C3 on the sound chip's supply, 47 µF 16 V at C4, C5, C6, C9, C10 and C11, and 10 µF 16 V at C8.[8]
Recap-a-Mac fits KEMET solid tantalum parts: T491D476K016AT (47 µF 16 V), T491D107K006AT (100 µF 6.3 V) and T491B106K016AT (10 µF 16 V).[1] A tantalum's stripe marks the positive terminal, the opposite of an aluminium electrolytic. Recap-a-Mac warns that the plastic at the bottom edge of the board, near three of the capacitors, is easily melted with a soldering iron.[1]
Color Classic logic board recapping guide (Recap-a-Mac)
Analogue board
Apple's service part is the "Analog Board/Power Supply", 661-0732.[9] Apple publishes no component list for it. The bare board is 630-0349; Console5 notes that the Macintosh TV's 630-0355 is nearly identical, with an extra 47 µF and 1 µF capacitor.[10]
This board numbers its parts in function-prefixed blocks (CD, CF, CL, CP, CS, CV), not in a single Cn run.
Color Classic analogue board (630-0349), electrolytic capacitors
CD3 10 µF 16 V
CF2 4.7 µF 50 V
CF7 100 µF 25 V
CF8 3300 µF 16 V
CF9 220 µF 25 V
CF10 220 µF 35 V
CF11 470 µF 35 V
CL4 100 µF 25 V
CL11 1 µF 50 V
CL13 2.2 µF 200 V
CL14 47 µF 100 V
CL19 10 µF 250 V
CL21 100 µF 100 V
CL23 100 µF 6.3 V
CL24, CL31 1 µF 50 V
CL33, CL34 2.2 µF 100 V
CL35 0.47 µF 100 V
CP9, CP15, CP34 100 µF 25 V
CP10 1 µF 50 V
CP12 100 µF 100 V
CP13 1000 µF 35 V
CP14, CP41 1000 µF 16 V
CP30 330 µF 400 V
CP35, CP47, CP54, CP55 1 µF 50 V
CP39 3300 µF 16 V
CP40, CP42 5600 µF 10 V
CP43, CP44 470 µF 25 V
CP46 1000 µF 10 V
CP56 3300 µF (Console5) or 330 µF (powercc.org) 16 V
CS4 1 µF 50 V
CV13 10 µF 100 V
CV17, CV21 100 µF 25 V
CV18, CV19, CV20 2.2 µF 200 V
CV39, CV40 1 µF 50 V
From Console5's list for 630-0349; powercc.org's list gives the same electrolytics and values except at CP56.[10][7] Recap-a-Mac's photograph of a 630-0349 board marks three 3300 µF 16 V capacitors, the same number as Console5 lists (CF8, CP39 and CP56); powercc.org gives 330 µF at CP56.[11] Read CP56 off your own board. Film, ceramic and safety capacitors on this board (for example CP16, a 10 nF Y-class part) are not in the table.
Recap-a-Mac does not think every capacitor on this board needs replacing; its guide marks the ones most prone to leakage, and it singles out the short, fat 3300 µF 16 V capacitor near the middle of the board, which "can leak and play havoc with the display".[11]
Color Classic analogue board recapping guide (Recap-a-Mac)
Parts that burn besides the capacitors
TinkerDifferent members found the two 18 V zener diodes DL21 and DL22, which are wired in parallel, scorching the board beneath them; one member reported scorch marks under them on every analogue board he had seen. The 47 Ω resistor RL62 burned open on one board and smoked again when its replacement was a 1 W part.[12] Console5 lists uprated replacements drawn from that thread: a single 5 W 1N5355B zener in place of DL21 and DL22, a 5 W 1N5344B at DF2, and 5 W resistors at RF11 (390 Ω), RL22 (100 Ω) and RL62 (47 Ω).[10]
Replacement procedure
  1. Remove the logic board through the I/O door and take the battery out.[2]
  2. Remove the rear housing (four case screws, and the two I/O door security screws if fitted), discharge the CRT and remove the anode cap.[2]
  3. Take out the analogue board: unhook the video board ground wire from the CRT strap, pull the video board off the CRT neck, unplug the degauss cable (BP2), the yoke cable (BD1) and the microphone cable, slide the board out about two inches, lift it, and unplug the speaker cable beneath it.[2]
  4. Confirm with a meter that CP30 has discharged before working on the primary side.
  5. Replace the capacitors, observing polarity.
  6. Clean the boards with isopropyl alcohol and check the traces round every surface-mount position, especially near the sound chip, before fitting new parts.
  7. On reassembly, reconnect the video board ground wire to the CRT strap. Apple warns that switching on without it can damage components.[2]
  8. After replacing the analogue board, Apple's procedure is to perform the cutoff video adjustment.[13]
After the recap
Apple publishes no rail tolerance and no power-supply adjustment for the Color Classic. Its Adjustments chapter covers geometry, video, convergence, geometric distortion, yoke and light meter setup.[14] The "+5 V 4.85–5.15 V / +12 V 11.90–12.75 V" pair quoted for compact Macs is Apple's Macintosh Plus procedure and does not apply; the Color Classic has no 3.3 V rail. Compare each rail with its nominal value at the logic board connector.
Apple's first steps for the display symptoms most often blamed on the supply are worth following before reaching for the meter.[15]
Symptom Apple's first steps
Screen jitters or flashes Check that nearby equipment is grounded, move electrical devices away and switch off fluorescent lights; check the ground cables; disconnect the internal hard and floppy drives; then the analogue board
Raster tilted, distorted or off-centre Move the machine to rule out its surroundings; geometry adjustments; then the analogue board
Flashing or wavy screen, or a high-pitched noise Analogue board
  1. ↑ 1.0 1.1 1.2 1.3 1.4 Recap-a-Mac, "Macintosh Colo(u)r Classic": four leaky capacitors around the PLCC sound chip; trace damage; plastic at the bottom of the board near three capacitors melts easily; KEMET T491D476K016AT (47 µF 16 V), T491D107K006AT (100 µF 6.3 V), T491B106K016AT (10 µF 16 V). Secondary source.
  2. ↑ 2.0 2.1 2.2 2.3 2.4 2.5 Apple Computer, Macintosh Color Classic Service Source (141-page copy, File:Color classic.pdf), Take Apart pp. 1–43 (PDF pp. 38–80): Logic Board, Rear Housing, Analog Board (pp. 8–13, PDF pp. 45–50), Speaker, Floppy Drive, Hard Drive, Chassis, Pushbutton Board, Flat Cable Assembly, Microphone Assembly, CRT, Degauss Coil, Bezel, Fan.
  3. ↑ Apple, Macintosh Color Classic Service Source, Specifications, Electrical p. 11 (PDF p. 15).
  4. ↑ Apple, Macintosh Color Classic Service Source, Additional Procedures, Battery Verification and Battery Replacement pp. 1–5 (PDF pp. 93–97).
  5. ↑ Low End Mac, "Mac Color Classic". Secondary source.
  6. ↑ Console5 TechWiki, "Macintosh Color Classic": logic board 820-0367-C; analogue board 630-0349. Secondary source (a capacitor-kit list).
  7. ↑ 7.0 7.1 powercc.org, "ReCap": logic board counts for the Color Classic, Performa/LC 550 and LC 575 boards, and a Color Classic analogue board list, which the site says may be incomplete. Secondary source.
  8. ↑ BOMARC Services, schematic of Apple 820-0367-B "Color Classic" computer motherboard, eight sheets: sheet 1, C8 10 µF 16 V and C9, C10, C11 47 µF 16 V on the power connector; sheets 6 and 7, C4, C5 and C6 47 µF 16 V; sheet 7, C2 and C3 100 µF 6.3 V (drawn "100/6") on the sound chip's supply. Hosted as File:Macintosh Color Classic Schematic.pdf. Reverse-engineered, not Apple documentation.
  9. ↑ Apple, Macintosh Color Classic Service Source, Exploded View (PDF p. 141).
  10. ↑ 10.0 10.1 10.2 Console5 TechWiki, "Mac Analog Board: 630-0349": capacitor list; resistor and diode upgrade list citing TinkerDifferent. Secondary source.
  11. ↑ 11.0 11.1 Recap-a-Mac, "Macintosh Colo(u)r Classic Analog Board". Secondary source.
  12. ↑ TinkerDifferent, "Color Classic analog board trouble", February–March 2023, posts by YMK and JDW. Secondary source.
  13. ↑ Apple, Macintosh Color Classic Service Source, Adjustments, Video pp. 9–20 (PDF pp. 107–118).
  14. ↑ Apple, Macintosh Color Classic Service Source, Adjustments pp. 1–41 (PDF pp. 99–139).
  15. ↑ Apple, Macintosh Color Classic Service Source, Troubleshooting, Symptom Charts pp. 2–18 (PDF pp. 20–36).
