Macintosh Color Classic Troubleshooting
The Macintosh Color Classic (also sold as the Performa 250)[1] and the Color Classic II (Performa 275) share the case, CRT and analog board; Apple's exploded views give the same analog board part number, 661-0732, for both.[2] Apple's troubleshooting for both is a set of symptom charts that end at module level (analog board, logic board, CRT, drives). The component-level faults below come from repairers and are cited to them. Capacitor lists are on Macintosh Color Classic Capacitor Replacement Guide and Macintosh Color Classic II Capacitor Replacement Guide.
Safety
The analog board carries mains voltage and drives the CRT, which holds a high-voltage charge after the machine is unplugged. Apple's manual warns that the product "contains high voltage and a high-vacuum picture tube" and tells the technician to discharge the CRT before removing the analog board, yoke or CRT.[3] Follow CRT Discharge Procedure.
Adjustments are made with the rear housing off and the power on. Apple warns that the metal chassis can then short against the underside of the logic board, and suggests supporting the rear corners of the chassis so it cannot buckle. Use a short, rigid plastic hex adjustment tool; Apple says metal alignment tools are a shock hazard.[4]
Reference data
Figures Apple publishes for these machines
Item Color Classic Color Classic II
Power supply 90-240 V AC universal, 47-63 Hz, 100 W maximum; the supply is part of the analog board[5][2]
CPU 68030, 16 MHz, 16-bit data bus[5] 68030, 33 MHz, 32-bit data path[6]
RAM 4 MB on board; two 30-pin SIMM sockets, 100 ns; 10 MB maximum[5] 4 MB on board; one 72-pin SIMM socket, 80 ns; 36 MB maximum[6]
VRAM 256K on board, plus a 256K VRAM SIMM socket[5] 512K fitted on the board, although Apple's documents say 256K[7]
PRAM battery 3.6 V lithium; replace if it reads below 3.0 V[8][6]
Apple publishes no rail voltages or tolerances for these machines, and the Adjustments chapter has no power-supply adjustment.[4] A table giving +5 V as 4.85-5.15 V and +12 V as 11.90-12.75 V at the external drive port is Apple's Macintosh Plus procedure and does not apply here.
The Color Classic II's own Service Source prints the Color Classic's memory and bus figures (16-bit data bus, 10 MB maximum). Use Apple's Color Classic II technical specifications instead.[9][6]
Power-up faults
The Color Classic uses what Apple calls pseudo soft power: the power key on the keyboard starts the machine, but the switch on the back is wired straight to the power supply and must be on first.[10]
Power and start-up symptoms
Symptom Checks, in order
No video, no sound, no drive activity Power cord connected; rear switch on; try another cord; replace analog board; replace logic board (Apple's order).[11] Before condemning a board: reset PRAM, pull the logic board and clean its edge contacts and the socket, reseat the SIMMs, press the small Cuda button beside the ADB ports, and try again with the PRAM battery removed. Some machines only start after being left plugged in with the rear switch on for a day.[12]
Clicking, chirping or thumping Check the logic board power cable is seated at J12; replace analog board; replace logic board.[11]
Smoke or smell Replace analog board (Apple).[11] At component level, see Analog board below.
Screen is black, too dark or too bright, but sound and drives work Contrast button on the bezel; reset PRAM; yoke cable; video adjustments; analog board; CRT.[11]
Analog board
Two parts on the analog board run hot and are found burnt on many boards. DL21 and DL22 are a pair of 18 V zener diodes wired in parallel; they overheat and scorch the PCB under them. RL62, a 47 Ω resistor, burns open. In the TinkerDifferent thread that documents this, one owner's replacement 1 W resistor at RL62 smoked again during adjustment.[13]
Console5 sells an uprated kit for this board (Apple part numbers 630-0349 and 630-0355). It replaces DL21 and DL22 with a single 1N5355B 5 W 18 V zener, fits 5 W resistors at RL62 (47 Ω), RL22 (100 Ω) and RF11 (390 Ω), and a 1N5344B 5 W zener at DF2.[14] Stand the new parts off the board on their leads so they can cool.[13]
Recap-a-Mac's analog board guide marks the electrolytics most prone to leakage, chief among them the 3300 µF 16 V capacitor near the middle of the board, which can disturb the display.[15] The primary reservoir capacitor sits on rectified mains; because the supply accepts 90-240 V,[5] it sees about 340 V DC on 240 V mains, and the replacement must be rated 400 V. The full list is on Macintosh Color Classic Capacitor Replacement Guide.
After a recap, a screen that is far too bright with visible retrace lines is often a bad joint or an open resistor on the analog board. Turn the G2 (screen) control on the flyback down first; if that does not help, the CRT cathode voltages are missing.[16] The same thread traced an intermittent blue picture to the analog board's edge connector.
Video faults
Apple's display tests use the Display Service Utility test patterns.[4] The chart below is Apple's, with the cures in the order Apple lists them.[11]
Apple's video symptom chart (Color Classic)
Symptom Apple's cures, in order
Bright screen and sound, but no picture Video adjustments; analog board; CRT
Single vertical or horizontal line Analog board; CRT
Colour tint, or colour cannot be adjusted Video adjustments; analog board; CRT if red, green or blue cannot be turned off with the controls
Picture breaks into diagonal lines or rolls Analog board
Out of convergence Convergence adjustment; analog board; CRT
Black spots (burnt phosphor) CRT
Jitter or flashing Check grounding and move nearby electrical equipment and fluorescent lights; check ground cables; disconnect the internal hard and floppy drives; analog board
Out of focus Focus adjustment; analog board; CRT only if one area stays out of focus with the controls at their limits
Flashing or wavy picture, or high-pitched noise Analog board
Raster too tall, short, wide or narrow Size controls; analog board
Poor linearity Analog board
Raster tilted or shifted Check the location; geometry adjustments; yoke adjustment; analog board
Raster distorted (barrel, corners, sides) Check the location; geometry adjustments; analog board; CRT (rarely)
Raster not centred Check the location; centring controls; analog board
A thin grey horizontal line across the bottom third of a lit screen is normal for a Trinitron tube, and Apple says not to replace anything for it.[11]
To straighten a tilted picture, loosen the yoke clamp screw, rotate the plastic yoke collar until the picture edges are parallel with the bezel, then switch off, unplug, discharge the CRT and tighten the clamp without overtightening.[17]
Logic board faults
Leaking capacitors
The Color Classic logic board uses surface-mount electrolytic capacitors that leak. The PLCC sound chip in the top-left corner sits among four of them, and the traces around it are often damaged by the time the board is recapped.[1] Wash the board, recap it and check the traces around the sound chip for continuity. The values and positions are on Macintosh Color Classic Capacitor Replacement Guide.
PRAM battery
Most boards have a 3.6 V lithium half-AA cell, but Low End Mac notes that some use a 4.5 V Rayovac 840, so check what is fitted; Apple's threshold for replacing the cell is 3.0 V.[18][8] Remove any original cell. If it has leaked, neutralise the residue with bicarbonate of soda paste, rinse with distilled water and dry with isopropyl alcohol; vinegar is for alkaline cells, not lithium. See Battery Explosion, Capacitor or Corrosion Damage.
Sad Mac and start-up faults
Apple's start-up symptom chart
Sad Mac icon Known-good disk; replace the RAM SIMMs; logic board
Sad Mac with black vertical lines and a screech Replace the RAM SIMMs; logic board
Disk ejects and a blinking "X" icon appears Known-good system disk; floppy drive; logic board
Source: Apple, Symptom Charts.[11] The codes shown under the Sad Mac icon are decoded on Sad Mac Error Codes.
When Apple's chart says to replace the logic board, it also says to keep the customer's SIMMs, maths coprocessor and PDS card. The board slides out from the rear once the I/O door is open, with no other dismantling.[3]
Drives and peripherals
Apple's drive and peripheral symptom chart
Floppy drive does not work, or runs continuously Known-good disk; floppy drive; logic board; floppy cable
Disk will not insert fully, or will not eject Straightened paper clip in the hole beside the drive; switch on with the mouse button held down to finish the eject cycle; floppy drive
Internal or external hard drive does not work Remove any SCSI loopback card; the internal drive must have all three terminating resistor packs fitted; terminate the external chain; hard drive data cable; hard drive; logic board
Internal or external SCSI device works, but not both External device ID above 0 and not duplicated; replace the external terminator; replace the SCSI select cable
Cursor does not move Mouse connection; move the mouse from the keyboard to the rear ADB port (if it then works, replace the keyboard); reset PRAM; mouse; logic board
No response to the keyboard Keyboard connection; keyboard cable; keyboard; logic board
Source: Apple, Symptom Charts.[11] For the floppy mechanism itself see Floppy Drive Repair.
  1. ↑ 1.0 1.1 Macintosh Colo(u)r Classic, Recap-a-Mac—link(accessed 2026-09-30) Performa 250 name; PLCC sound chip surrounded by four leaking capacitors, trace damage around it; replacement values 47 µF 16 V, 100 µF 6.3 V and 10 µF 16 V (tantalum).
  2. ↑ 2.0 2.1 Apple, Macintosh Color Classic Service Source, Exploded View: analog board/power supply 661-0732, logic board 661-1830, floppy drive 661-0474, CRT 661-0004 (661-0022 European, 661-0024 Australian). The Color Classic II/Performa 275 Service Source exploded view prints the same numbers.
  3. ↑ 3.0 3.1 Apple Computer, Macintosh Color Classic Service Source (1995), File:Color_classic.pdf, Take Apart chapter (CRT warnings and "Discharge the CRT" preliminary steps; logic board removal through the I/O door).
  4. ↑ 4.0 4.1 4.2 Apple, Macintosh Color Classic Service Source, Adjustments chapter (Geometry, Video, Convergence, Geometric Distortion, Yoke, Light Meter Setup), Geometry pp. 1-3.
  5. ↑ 5.0 5.1 5.2 5.3 5.4 Apple, Macintosh Color Classic Service Source, Specifications pp. 2-11: 68030 at 16 MHz, 16-bit data bus, 4 MB on board, 10 MB maximum with 100 ns SIMMs in two 30-pin sockets, 256K VRAM plus a 256K VRAM SIMM socket, 512 × 384 Trinitron display, 90-240 V AC, 47-63 Hz, 100 W.
  6. ↑ 6.0 6.1 6.2 6.3 Macintosh Color Classic II: Technical Specifications, Apple—link(accessed 2026-09-30) 68030 at 33 MHz, 32-bit data path, one 72-pin SIMM slot, 4-36 MB, 80 ns, 3.6 V lithium battery, 100 W, 90-240 V.
  7. ↑ How Much Video Memory Does A Mac Color Classic II Have, Anyway?, Userlandia—link(accessed 2026-09-30)
  8. ↑ 8.0 8.1 Apple, Macintosh Color Classic Service Source, Additional Procedures, Battery Verification p. 2: "If the battery voltage is below 3.0 volts, replace the battery."
  9. ↑ Apple, Macintosh Color Classic II/Performa 275 Service Source (1996), File:Color classic ii.perf 275.pdf, Specifications pp. 2-4.
  10. ↑ Technical Note TN1079: Server Mode and the Cuda Manager, Apple—link(accessed 2026-09-30) "Certain Macintosh models, such as the Color Classic, LC475 and LC575 CPUs, implement a Pseudo Soft Power supply control."
  11. ↑ 11.0 11.1 11.2 11.3 11.4 11.5 11.6 11.7 Apple, Macintosh Color Classic Service Source, Troubleshooting, Symptom Charts pp. 2-18.
  12. ↑ Glenn Chase, Troubleshooting a Color Classic that won't power on, classicmacs.org, 2011-09-07—link(accessed 2026-09-30)
  13. ↑ 13.0 13.1 Color Classic analog board trouble, TinkerDifferent—link(accessed 2026-09-30)
  14. ↑ Macintosh Color Classic / 630-0349 - Resistor / Diode Kit, Console5—link(accessed 2026-09-30)
  15. ↑ Recap-a-Mac, "Macintosh Colo(u)r Classic Analog Board". Secondary source.
  16. ↑ Help diagnosing a Color Classic Analog board, TinkerDifferent—link(accessed 2026-09-30) Blazing-bright screen with retrace lines after recap: cause was a resistor with no solder; later intermittent colour traced to the analog board edge connector.
  17. ↑ Apple, Macintosh Color Classic Service Source, Adjustments, Yoke pp. 33-35.
  18. ↑ Low End Mac, "Mac Color Classic": PRAM battery 3.6 V half-AA most common, some 4.5 V Rayovac 840. Secondary source.
