Macintosh Color Classic II Troubleshooting
This guide covers common faults with the Macintosh Color Classic II, including startup failures, video problems, audio issues, and storage errors.
Safety Warning
[edit | edit source]The Color Classic II contains a CRT that retains high voltage when unplugged. Discharge the CRT anode before touching any internal components. See CRT Discharge Procedure.
Preliminary Checks
[edit | edit source]Before detailed troubleshooting:
- Verify the power cable is secure
- Test with a known-good outlet
- Disconnect all external SCSI devices
- Remove any PDS cards
- Check for visible capacitor leakage or battery corrosion
No Power
| Symptom | Possible Cause | Action |
| Completely dead | Blown fuse, failed power supply, bad cord | Check wall outlet; test power cord; check analog board fuse (2A 250V) |
| Clicking or ticking | Failed capacitors, shorted component | Recap analog board; check for shorts on logic board |
| Powers on briefly then dies | Overload protection tripping | Disconnect logic board; test analog board alone |
| Fan spins but no startup | Logic board failure, dead PRAM battery | Replace PRAM battery; check for capacitor damage |
Fuse Location
[edit | edit source]The main fuse is on the analog board near the power inlet. It's a 2A 250V slow-blow fuse. If the fuse blows repeatedly, do not simply replace it — find the underlying short circuit.
Startup Failures
[edit | edit source]| Symptom | Possible Cause | Action |
| No chime, no video | Dead logic board, failed capacitors | Recap logic board; check PRAM battery; reseat RAM |
| Chime but no video | CRT failure, analog board fault, neck board | Check CRT connections; verify flyback output; check brightness pot |
| Sad Mac error | Hardware failure (RAM, ROM, logic) | Decode error code; test RAM; reseat VRAM SIMM |
| Flashing question mark | No boot device | Check SCSI drive; verify termination; test with boot floppy |
| Chimes of death (different tones) | RAM failure | Reseat or replace RAM SIMM |
Chimes of Death
[edit | edit source]| Chime Pattern | Meaning |
| Single tone, then silence | Normal startup (no fault) |
| 4 tones (rising) | RAM test failure — bad SIMM or slot |
| 1 long, 3 short | RAM addressing error |
| Continuous tone | No RAM installed or complete RAM failure |
Sad Mac Error Codes
[edit | edit source]When a Sad Mac appears, the hexadecimal codes indicate the failure type:
| Code Range | Meaning | Action |
| 01XXXX | ROM test failure | Reseat ROM (if socketed); check for corrosion |
| 02XXXX – 05XXXX | RAM test failure | Try different SIMM; clean SIMM slot; test with known-good RAM |
| 0DXXXX | NuBus/PDS card failure | Remove expansion cards |
| 0EXXXX | SCSI controller failure | Check for capacitor damage near SCSI chip |
| 0FXXXX | Data bus failure | Logic board damage — check for corroded traces |
See Sad Mac Error Codes for complete reference.
Video Problems
| No image (dark screen) | CRT heater failure, flyback, brightness | Check CRT neck glow; measure flyback output; adjust brightness pot |
| Horizontal line only | Vertical deflection failure | Check vertical output IC and associated capacitors |
| Vertical line only | Horizontal deflection failure | Flyback or HOT (Horizontal Output Transistor) failure |
| Dim or faded image | Weak CRT, low HV, brightness pot | Measure HV at anode; clean brightness control; CRT may be worn |
| Distorted geometry | Bad capacitors, failed deflection | Recap analog board; check yoke connections |
| Wrong colors or missing colors | VRAM failure, logic board issue | Reseat VRAM SIMM; check for capacitor damage near video DAC |
| Rolling or unstable image | Sync problems, analog board | Check capacitors in sync circuits; verify ground connections |
CRT Neck Glow
[edit | edit source]With the machine powered on in a dark room, the CRT neck should glow faint orange (heater filament). No glow indicates:
- Failed CRT
- Bad neck board connection
- Missing heater voltage from analog board
Audio Problems
| No startup chime | Sound chip failure, capacitor damage | Recap logic board; check for damage around 343S0129 chip |
| Distorted or crackling audio | Failed capacitors in audio circuit | Recap logic board; check speaker cone |
| Audio through headphone only | Internal speaker disconnected or failed | Check speaker wire; test speaker with multimeter (8Ω) |
| No audio at all | Logic board failure near audio section | Inspect capacitors around sound chip; check for trace damage |
The Color Classic II's sound chip (343S0129 DFAC) is surrounded by capacitors that commonly leak and damage traces. Trace repair may be required after recapping.
SCSI and Storage
| Flashing question mark | No bootable System found | Check SCSI cable; verify drive spins up; test with boot floppy |
| Drive not recognized | Wrong SCSI ID, termination error | Verify unique SCSI IDs (internal usually ID 0); check termination |
| System freezes during boot | SCSI bus conflict | Disconnect all SCSI devices; add back one at a time |
| Floppy not reading | Dirty heads, failed drive | Clean heads with IPA; test with different disks |
| Floppy won't eject | Mechanical failure | Check eject gear; may need lubrication or gear replacement |
SCSI Termination
[edit | edit source]- Internal drive: terminated (resistor pack on drive)
- If adding external devices: terminate only the last device in the chain
- The Color Classic II does not provide termination power internally
Capacitor-Related Failures
[edit | edit source]Many Color Classic II problems are caused by leaking capacitors:
| Board | Symptom | Likely Failed Cap |
| Logic | No audio / distorted audio | Capacitors near sound chip |
| Logic | Random crashes | General logic board recap needed |
| Analog | No video or dim video | 3300µF 16V main filter or HV section caps |
| Analog | Wrong voltages | Power supply section capacitors |
| Analog | Geometry distortion | Deflection circuit capacitors |
See Macintosh Color Classic II Capacitor Replacement Guide for full capacitor lists and procedures.
Thermal Issues
| Random shutdowns after warming up | Thermal protection, cracked solder joint | Check for cold solder joints; ensure fan works; verify ventilation |
| System works when cold, fails when warm | Marginal component, bad capacitor | Recap; reflow suspicious solder joints |
The Color Classic II runs hot. Ensure the fan spins and vents are clear.
⚠️ Recap and PRAM battery
[edit | edit source]The Macintosh Color Classic II is built on an LC-series logic board and uses surface-mount electrolytic capacitors that leak with age, corroding the board — recap and clean it as a first step. It also carries a lithium PRAM battery that leaks/bursts; remove it from any un-serviced unit and clean any corrosion.[1] [2]
All-in-one analog board
[edit | edit source]As an all-in-one with a built-in CRT, the Macintosh Color Classic II has an analog board like the compact and Color Classic Macs. No video with a chime, a collapsed raster, vertical lines, dim or distorted video point to the analog board — reflow cracked solder joints (deflection yoke and flyback) and recap the analog board. It uses the LC 550 logic board (33 MHz 68030) in the Color Classic case, and shares the Color Classic's Trinitron convergence/geometry adjustments.[2]
[edit | edit source]- ↑ 68kMLA — exploding Maxell PRAM batteries. Source for the leaking/exploding lithium PRAM battery.
- ↑ 2.0 2.1 Recap-a-Mac and 68kMLA recap threads. Source for the LC-family / all-in-one Macintosh surface-mount electrolytic leakage and the analog-board faults.
[edit | edit source]Surface-mount capacitor leakage
[edit | edit source]The Macintosh Color Classic II logic board uses surface-mount electrolytic capacitors whose electrolyte turns corrosive with age and creeps across the board, eating through traces, pads and IC pins. Typical signatures are a machine that will not chime, chimes but shows no video, plays distorted or missing audio, or shows a garbled or checkerboard screen. Wash the affected area and replace every electrolytic with a tantalum or polymer part, then repair any lifted traces. The switch-mode power supply (ASTEC or TDK on the LC-family machines) holds its own electrolytics and fails the same way, so recap it alongside the board.[1]
PRAM battery
[edit | edit source]The Macintosh Color Classic II backs up its clock and Parameter RAM from a 3.6 V ½AA lithium cell. These cells — red Maxell parts especially — leak or burst and corrode the board, so remove an aged one on sight. A flat cell can also stop a soft-power machine booting or disturb the video; left plugged in, trickle power preserves the settings, but a machine switched off at the wall with a dead cell loses them. Clean the area and fit a fresh 3.6 V cell.[2]
Analog board
[edit | edit source]On the all-in-one Macintosh Color Classic II the analog board is the usual failure. The DL21/DL22 18 V 1 W zeners overheat and char the PCB, the RL62 47 Ω 3 W resistor burns open, and the main filter capacitors drift and make the rails unstable. A dead set with no fan and no CRT glow, or a set that powers on the instant mains is applied (a soft-power fault), points here; a clicking or ticking analog board is a failing flyback. Four capacitors around the PLCC sound chip cause lost sound.[3]
Boot chime and Sad Mac
[edit | edit source]Read the start-up sound first: a normal chime with a black screen points to the display path or the monitor, an absent chime or a "chord of death" points to RAM or a core fault, and a Sad Mac shows a numeric code — see Sad Mac Error Codes.
Related Pages
[edit | edit source]- Macintosh Color Classic II
- Macintosh Color Classic II General Maintenance
- Macintosh Color Classic II Capacitor Replacement Guide
- Sad Mac Error Codes
- CRT Discharge Procedure
- ↑ Mac84, Macintosh LC series power-supply recapping guide; the MacCaps capacitor reference; and iFixit. Source for surface-mount electrolytic leakage eating traces, pads and pins, the ASTEC/TDK LC power-supply cap failures, and Apple's use of tantalum (non-leaking) capacitors on the Quadra 700/900 logic boards.
- ↑ Color Classic analog board trouble, TinkerDifferent; and iFixit. Source for the DL21/DL22 18 V 1 W zeners charring the PCB, the RL62 47 Ω 3 W resistor going open, the flyback clicking/ticking, and the four capacitors around the PLCC sound chip.
