Macintosh Performa 5320CD
Performa 5300CD; the 5320CD uses the same enclosure
TypeAll-in-one personal computer
ReleasedNovember 14, 1995[1]
DiscontinuedAugust 1, 1996[2]
CPUPowerPC 603e at 120 MHz[3]
Memory16 MB; two 72-pin SIMM slots, 64 MB maximum[3]
Storage1.2 GB IDE hard drive, AppleCD 600i CD-ROM, 1.4 MB SuperDrive[3]
DisplayBuilt-in 15-inch shadow-mask colour display[3]
Sound16-bit stereo output, 16-bit mono input[3]
Power100–240 V AC, 47–63 Hz, 125 W[3]
Dimensions17.5 × 16 × 15.1 in (445 × 406 × 383 mm), H × W × D[3]
Weight47 lb (21.3 kg)[1]
OS / FirmwareSystem 7.5.1 (Japanese J-7.5.1) with System Enabler 406[1]
PredecessorPerforma 5300CD
SuccessorPerforma 5400CD
The Macintosh Performa 5320CD is an all-in-one Macintosh that Apple sold outside the United States from November 14, 1995.[1] Apple's Service Source describes it as the successor to the Performa 5300CD, with a 120 MHz PowerPC 603e and 16 MB of RAM, and "all other hardware features ... the same as the Performa 5300CD".[4]
EveryMac describes the 5320CD as shipping with a TV/video system and gives Japanese order number M4450J/A; order numbers elsewhere differed.[2] Apple's own configuration note for the model mentions only the faster processor and the extra memory, so a TV tuner or video-in card in a surviving machine may or may not be original.[4]
Performa 5320CD specifications (Apple)
Item Specification
Processor PowerPC 603e at 120 MHz with integrated FPU; 64-bit PowerPC bus[3]
Cache 32 KB level 1; 256 KB level 2[1]
ROM 4 MB[3]
RAM 16 MB in two 72-pin SIMM slots (80 ns or faster), 64 MB maximum; nothing soldered to the board[3][1]
Video 1 MB DRAM frame buffer; 640 × 480 at 16-bit, 800 × 600 and 832 × 624 at 8-bit (no video input at 832 × 624)[3]
Display 15-inch shadow mask, 12.8-inch viewable; 0.28 mm dot pitch; 66.7 Hz[3]
Storage 1.2 GB IDE hard drive; AppleCD 600i CD-ROM; 1.4 MB SuperDrive, manual insert[3]
Expansion LC processor-direct slot, communications slot, 60-pin video-in slot, TV tuner port, external video connector slot[3]
Power 100–240 V AC, 47–63 Hz, 125 W[3]
Clock battery 4.5 V alkaline pack; Apple's threshold is 3.0 V[1][5]
Service notes
The 5320CD is serviced as a Performa 5300CD. Apple's Repair Extension Program procedures for system freezes and colour-hue changes cover the 52xx and 53xx machines other than the 5260 and 5280, and the faults, part numbers and adjustments are described on Macintosh Performa 5300CD.[6] The CRT holds a charge after the machine is unplugged; read CRT Discharge Procedure before opening it.
Guides for this chassis:
Download: Powermac.perf_5200.5300.pdf. Description page: Power Macintosh/Performa 5200 and 5300 Service Source.
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 Macintosh Performa 5320CD: Technical Specifications, Apple—link(accessed 2026-09-30) Source for the introduction date, "not sold in the U.S.", 16 MB, 256K level 2 cache, 4.5 V alkaline battery, 47 lb, J-7.5.1 with System Enabler 406.
  2. ↑ 2.0 2.1 Macintosh Performa 5320CD Specs, EveryMac.com—link(accessed 2026-09-30)
  3. ↑ 3.00 3.01 3.02 3.03 3.04 3.05 3.06 3.07 3.08 3.09 3.10 3.11 3.12 3.13 3.14 Apple Computer, Power Macintosh/Performa 5200 and 5300 (not 5260, 5280) Service Source, 1997, Specifications chapter: Processor (p. 1), Memory (pp. 2–3), Disk Storage (p. 4), I/O Interfaces (pp. 5–7), Sound and Video (pp. 9–11), Electrical (p. 17), Physical (p. 18). Hosted as File:Powermac.perf_5200.5300.pdf.
  4. ↑ 4.0 4.1 Apple Computer, Power Macintosh/Performa 5200 and 5300 (not 5260, 5280) Service Source, 1997, cover (models covered) and Basics chapter, p. 4 ("Performa 5320CD"). Hosted as File:Powermac.perf_5200.5300.pdf; see Power Macintosh/Performa 5200 and 5300 Service Source.
  5. ↑ Apple Computer, Power Macintosh/Performa 5200 and 5300 Service Source, 1997, Additional Procedures chapter, Battery Verification, pp. 1–2. Hosted as File:Powermac.perf_5200.5300.pdf.
  6. ↑ Apple Computer, Power Macintosh/Performa 5200 and 5300 Service Source, 1997, REA Procedures chapter, p. 1. Hosted as File:Powermac.perf_5200.5300.pdf.
