Macintosh Performa 550
Performa 550 with keyboard and mouse (photo: Mondoshawan22, CC BY-SA 4.0)
TypeAll-in-one personal computer
ReleasedOctober 18, 1993[1]
DiscontinuedApril 1, 1996[2]
CPUMotorola 68030 at 33 MHz; socket for a 68882 FPU[3]
Memory4 MB on the logic board; one 72-pin SIMM slot, 36 MB maximum[3]
Storage80 or 160 MB SCSI hard drive, AppleCD 300i CD-ROM, 1.4 MB SuperDrive[3]
DisplayBuilt-in 14-inch Trinitron, 640 × 480[3]
SoundStereo output, mono input[3]
Power100–240 V AC, 47–63 Hz, 120 W maximum[3]
Dimensions17.9 × 13.5 × 16.5 in (45.5 × 34.4 × 42.0 cm), H × W × D[3]
Weight40.5 lb (18.4 kg)[3]
OS / FirmwareSystem 7.1P3 with System Enabler 332[1]
PredecessorPerforma 520
SuccessorPerforma 575
Model no.M1640[2]
The Macintosh Performa 550 is an all-in-one Macintosh with a 33 MHz Motorola 68030, a built-in 14-inch Trinitron display and a CD-ROM drive, introduced by Apple on October 18, 1993.[1] It is the retail version of the Macintosh LC 550; the Performa 560 is the same hardware with a different software bundle.[4] Low End Mac notes that the LC 550 and Performa 550 logic board is the one used in the Color Classic II.[5]
EveryMac gives the US launch price as US$2,000 and the Apple order number as M2147LL/A; Low End Mac gives US$1,200.[2][5]
Performa 550 specifications (Apple)
Item Specification
Processor Motorola 68030 at 33 MHz with built-in MMU; socket for an optional 68882 maths coprocessor[3]
RAM 4 MB on the logic board; one 72-pin SIMM slot for 80 ns or faster SIMMs; 36 MB maximum[3]
ROM and PRAM 1 MB ROM; 256 bytes of parameter memory kept by a lithium battery[3]
Video 512K VRAM on the board for 256 colours at 640 × 480; a 68-pin VRAM SIMM brings it to 768K for thousands of colours[3][1]
Display 14-inch Trinitron CRT with high-contrast glass, 13-inch viewable; 0.26 mm aperture grille pitch; 640 × 480 at 70 dpi[3]
Storage 80 or 160 MB internal SCSI hard drive; internal AppleCD 300i double-speed CD-ROM (caddy loading); 1.4 MB Apple SuperDrive, manual insert[3][4]
Sound Stereo output port and front headphone jack; mono input port; built-in microphone; records and plays at 11 or 22 kHz[3]
Ports Two RS-232/RS-422 serial ports (mini DIN-8); one SCSI port (DB-25, up to six external devices); two ADB ports (500 mA total)[3][1]
Expansion One processor-direct slot for 96- or 114-pin cards. The communications slot of the 575, 577 and 578 is not fitted[3][4]
Power Universal supply, 100–240 V AC, 47–63 Hz, 120 W maximum[3]
Clock battery 3.6 V lithium; Apple replaces it below 3.0 V[1][6]
The Service Source's Basics chapter describes the 550 and 560 processor as a 68LC030, while its Specifications chapter and Apple's technical-specification page give a 68030 with an optional 68882.[4][3][1] Apple's technical-specification page also lists the power as 40 W, which does not match the 120 W in the Service Source.
Service notes
The battery is a lithium cell in a holder with a clip-on cover on the logic board, reached by removing the I/O door and the logic board. Apple's test is to measure it on the 10 V DC range and replace it below 3.0 V, and Apple warns that a mishandled lithium cell can explode.[6] Lithium cell leakage is neutralised with bicarbonate of soda solution; see Battery Explosion, Capacitor or Corrosion Damage.
A thin grey horizontal line across the lower third of a lit screen is not a fault. Apple's symptom chart says it "is inherent in the design of Trinitron monitors. Do not replace modules."[7] Apple's charts send most display faults, smoke or smell, and clicking or chirping noises to the analogue board, and a Sad Mac with black vertical lines to the SIMMs and then the logic board.[7] The display adjustments (geometry, video, convergence, geometric distortion and yoke) are in the Service Source; it gives no power-supply adjustment or rail tolerances.[8] The CRT holds a charge after the machine is unplugged; read CRT Discharge Procedure before opening it.
For general repair work see Capacitor Failure Symptoms, Macintosh Floppy Drive Maintenance and Macintosh HDD Maintenance.
Apple's Performa 500 Series Service Source (1995, 161 pages) covers the Performa 550, 560, 575, 577 and 578 at module level. The LC 550 has its own manual, Macintosh LC 520/550/575 Service Source.
Download: Performa_500_series.pdf. Description page: Performa 500 Series Service Source.
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 Macintosh Performa 550: Technical Specifications, Apple—link(accessed 2026-09-30) Source for the introduction date, optional 68882 FPU, two ADB ports, 3.6 V lithium battery, 4 MB on the logic board, VRAM options, System 7.1P3 with System Enabler 332, Mac OS 7.6.1 as the last supported version and the 2× CD-ROM.
  2. ↑ 2.0 2.1 2.2 Macintosh Performa 550 Specs, EveryMac.com—link(accessed 2026-09-30)
  3. ↑ 3.00 3.01 3.02 3.03 3.04 3.05 3.06 3.07 3.08 3.09 3.10 3.11 3.12 3.13 3.14 3.15 3.16 3.17 3.18 Apple Computer, Performa 500 Series Service Source, 1995, Specifications chapter: Processor (p. 1), Memory (pp. 2–3), Disk Storage (p. 4), I/O Interfaces (pp. 5–6), I/O Devices (p. 7), Sound and Video (p. 8), Electrical (p. 9), Physical (p. 10). Hosted as File:Performa_500_series.pdf.
  4. ↑ 4.0 4.1 4.2 4.3 Apple Computer, Performa 500 Series Service Source, 1995, cover (Performa 550, 560, 575, 577, 578) and Basics chapter, Product Information, pp. 1–2. Hosted as File:Performa_500_series.pdf; see Performa 500 Series Service Source.
  5. ↑ 5.0 5.1 Mac LC 550 (Performa 550), Low End Mac—link(accessed 2026-09-30)
  6. ↑ 6.0 6.1 Apple Computer, Performa 500 Series Service Source, 1995, Additional Procedures chapter: Battery Verification (pp. 2–3), Battery Replacement (pp. 4–6). Hosted as File:Performa_500_series.pdf.
  7. ↑ 7.0 7.1 Apple Computer, Performa 500 Series Service Source, 1995, Troubleshooting chapter, Symptom Charts, pp. 2–17 (Trinitron line, p. 3). Hosted as File:Performa_500_series.pdf.
  8. ↑ Apple Computer, Performa 500 Series Service Source, 1995, Adjustments chapter: Geometry (pp. 1–8), Video (pp. 9–20), Light Meter Setup (pp. 21–26), Convergence (pp. 27–29), Geometric Distortion (pp. 30–34), Yoke (pp. 35–38). Hosted as File:Performa_500_series.pdf.
