Power Mac G4
The Power Mac G4 is Apple's family of tower Macintoshes built around the PowerPC G4 processor, sold from 1999. Apple's service manual describes the Power Mac G4 as "the first Power Mac computer based on the PowerPC G4 processor" and lists six tower models up to early 2002: PCI Graphics, AGP Graphics, Gigabit Ethernet, Digital Audio, QuickSilver and QuickSilver 2002.[1] The Mirrored Drive Doors models followed in 2002 and 2003 with their own manual.[2] The Power Mac G4 Cube used the same name and processor in a separate small enclosure, and the Macintosh Server G4 was the tower sold with server software.
EveryMac describes the tower case as the design introduced with the blue and white Power Macintosh G3.[3] To open it, lift the latch on the right side panel and lower the panel until it lies flat, exposing the logic board (p. 28).[1]
Models
[edit | edit source]| Model | Introduced | Processors | System bus | Memory | Slots |
| PCI Graphics | 15 September 1999 (Apple) | 350, 400 MHz | 100 MHz | PC100, 4 DIMM slots | 4 PCI, one holding the video card |
| AGP Graphics | 15 September 1999 (Apple); announced 31 August 1999 (Low End Mac) | 350–500 MHz | 100 MHz | PC100, 4 DIMM slots | 3 PCI and AGP 2X |
| Gigabit Ethernet | 19 July 2000 (Low End Mac) | 400 MHz; dual 450 or 500 MHz | 100 MHz | PC100, 4 DIMM slots | 3 PCI and AGP 2X |
| Digital Audio | 9 January 2001 (Low End Mac) | 466, 533, 733 MHz; dual 533 MHz | 133 MHz | PC133, 3 DIMM slots | 4 PCI and AGP 4X |
| QuickSilver | 18 July 2001 (Low End Mac) | 733, 867 MHz; dual 800 MHz | 133 MHz | PC133, 3 DIMM slots | 4 PCI and AGP 4X |
| QuickSilver 2002 | 28 January 2002 (Low End Mac) | 800, 933 MHz; dual 1 GHz | 133 MHz | PC133, 3 DIMM slots | 4 PCI and AGP 4X |
| Mirrored Drive Doors | 13 August 2002 (Low End Mac) | Dual 867 MHz, 1 GHz or 1.25 GHz | 133 or 167 MHz | DDR SDRAM, 4 DIMM slots | 4 PCI and AGP 4X |
| Mirrored Drive Doors (FW800) and 2003 | 2003 (Apple) | 1 GHz to dual 1.42 GHz; single 1.25 GHz (2003) | 133 or 167 MHz | DDR SDRAM, 4 DIMM slots | 4 PCI and AGP 4X |
Sources: Apple's specification pages,[4][5][6][7] the model pages and Low End Mac.[8][9]
Telling the models apart
[edit | edit source]Apple's service manual identifies the 1999–2002 towers like this (pp. 4–5, 23–25):[1]
- QuickSilver and QuickSilver 2002: silver case with a recessed speaker in the front panel.
- PCI Graphics: graphite case; the sound ports run horizontally in the lower half of the rear I/O panel.
- AGP Graphics and Gigabit Ethernet: graphite case; the sound ports run vertically. AGP Graphics logic boards have an internal FireWire connector at J9 and Gigabit Ethernet boards do not.
- Digital Audio: graphite case; the sound ports sit in the upper half of the I/O panel, and there are four PCI slots plus the AGP slot instead of three.
The Mirrored Drive Doors model has a speaker in the top of the case and mirrored optical drive bezels.[2]
PCI Graphics
[edit | edit source]The first G4 tower, which Low End Mac calls the "Yikes!" model, used a modified blue and white G3 logic board with PCI video.[8] It differs from every later G4 in ways that matter for repair (pp. 207, 212–219, 239):[1]
- It has a Cuda microcontroller with its own reset button beside the battery, not a PMU. Apple's board reset for this model is to unplug it, press the front power button, take out the battery for at least ten minutes, and refit it the right way round.
- Its processor module needs a jumper block at J25 of the right colour for the processor fitted, with all its inner metal clips, the right way round; without it the machine does not boot. Apple supplies the block with a replacement logic board and warranty sticker (076-0760 for 350 MHz, 076-0758 for 400 MHz).
- Seven diagnostic LEDs on the board (DS1, DS4–DS9) show ATA activity, USB power, Ultra ATA activity, power and processor bus requests.
- Four or five beeps at start-up mean a bad boot ROM checksum.
Apple's parts for it are logic board 661-2253 and power supply 661-2256, the same supply number as the AGP Graphics model (pp. 276, 291).[1]
[edit | edit source]The last G4 towers take DDR memory: PC2100 in 133 MHz machines and PC2700 in 167 MHz machines. PC2100 memory in a 167 MHz machine stops it booting with a single tone and a flashing front light. They hold four hard drives in two carriers, with the 100 MHz ATA cable in the rear carrier and the 66 MHz cable in the front, which Apple says must not be swapped.[2] Apple also notes that several bus-powered FireWire devices with an Apple ADC 17-inch CRT display can exceed the supply's capacity and shut the system down (p. 112).[2] The supply connector and test points are tabulated on Power Mac G4 (Mirrored Drive Doors) Service Source.
Common service points
[edit | edit source]- Every tower model to the QuickSilver 2002 has a supply voltage switch that must be set for the local mains (115 V in North America) whenever a supply is replaced, and Apple's first check for a dead machine includes it (pp. 143, 149, 237).[1]
- The clock battery is a 3.6 V lithium cell (part 922-4028 on every tower model in Apple's exploded views). The PMU-based boards want it between 3.3 and 3.7 V before a PMU reset (pp. 210, 276–291).[1][5]
- The logic board needs a standby "trickle" supply to start: +5 V on the PCI and AGP Graphics, +28 V on the Gigabit Ethernet and Digital Audio, +25 V on the QuickSilvers (p. 220).[1]
- All the 1999–2002 towers share the 922-3295 case fan (pp. 276–291).[1]
- Low End Mac reports that G4 towers before the QuickSilver 2002 do not support ATA drives over 128 GB on the internal bus without third-party help, and that some 2001 QuickSilvers with a later logic board do.[10]
The step-by-step procedures are on the shared guides:
- Power Mac G4 General Maintenance: opening the case, battery, PMU reset, memory, processor and power supply removal
- Power Mac G4 Troubleshooting: power-on self test, power supply verification, Apple's symptom charts and community power supply repair notes
Model pages
[edit | edit source]- Power Mac G4 (AGP Graphics)
- Power Mac G4 (Gigabit Ethernet)
- Power Mac G4 (Digital Audio)
- Power Mac G4 (Quicksilver)
- Power Mac G4 Cube
- Macintosh Server G4
[edit | edit source]- Power Mac G4/Macintosh Server G4 Service Source: PCI Graphics to QuickSilver 2002 and the Macintosh Server G4
- Power Mac G4 (Mirrored Drive Doors) Service Source
- Power Mac G4 Cube Service Source
Gallery
Apple's views of the AGP Graphics and Gigabit Ethernet models
Power Mac G4 (QuickSilver). Photo: baku13, CC BY-SA 3.0
Graphite G4 with the side door open. Photo: Marco Stadelmaier, CC BY-SA 3.0
Power Mac G4 Cube. Photo: Binarysequence, CC BY-SA 4.0
[edit | edit source]- ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 Apple Computer, Service Source: Power Mac G4/Macintosh Server G4 (2002), File:Power Mac G4 and Macintosh Server G4 Service Source (2002).pdf; see Power Mac G4/Macintosh Server G4 Service Source. Page numbers are PDF pages: Product Description p. 3, Identifying Versions pp. 4–5, Standard Configurations pp. 6–11, Views p. 13, Logic Boards pp. 15–17, Troubleshooting pp. 199–266, Exploded Views pp. 276–293.
- ↑ 2.0 2.1 2.2 2.3 Apple Computer, Service Source: Power Mac G4 (Mirrored Drive Doors) (2002), File:Power Mac G4 Mirrored Drive Doors Service Source (2002).pdf; see Power Mac G4 (Mirrored Drive Doors) Service Source. Page numbers are PDF pages.
- ↑ EveryMac, "Macintosh Server G4" index. The G4 servers use "the wonderfully easy-to-upgrade case design introduced with the Power Macintosh G3 (Blue)"; each server model is architecturally identical to a Power Mac G4 model.
- ↑ Apple, "Power Mac G4 (PCI Graphics) - Technical Specifications". G4 at 350 or 400 MHz; 128-bit, 100 MHz data path; L2 512K or 1 MB; 4 PCI slots, one dedicated to video; 15-pin VGA; 200 max watts; battery type 3.6V lithium; four PC100 DIMM slots, 64 MB–1 GB; introduced 9/15/1999; discontinued 12/31/1999; ROM 1 MB; 30 lb; 17 H × 8.9 W × 18.4 D in.
- ↑ 5.0 5.1 Apple, "Power Mac G4 (AGP Graphics) - Technical Specifications". Introduced 9/15/1999.
- ↑ Apple, "Power Mac G4 (Mirrored Drive Doors) - Technical Specifications". Dual 867 MHz, 1 GHz or 1.25 GHz; 133 or 167 MHz bus; PC2100 or PC2700 DDR SDRAM in four DIMM slots, 2 GB maximum; four PCI slots and AGP 4X; ADC and DVI; line voltage 100–125 V AC or 200–240 V AC; maximum current 6.5 A (low range) or 7.5 A (high range); 42 lb.
- ↑ Apple, "Power Mac G4 (FW800) - Technical Specifications"; Apple, "Power Mac G4 (Mirrored Drive Doors 2003) - Technical Specifications". 1 GHz, dual 1.25 GHz and dual 1.42 GHz (FW800); single 1.25 GHz (2003).
- ↑ 8.0 8.1 Low End Mac, "Sawtooth Power Mac G4". 450 MHz model introduced 31 August 1999; the Yikes! (PCI) models use a modified blue and white G3 logic board; PRAM battery 3.6 V half-AA.
- ↑ Low End Mac, "Quicksilver 2002 Power Mac G4". Introduced 28 January 2002; replaced by the Mirrored Drive Doors model on 13 August 2002.
- ↑ Low End Mac, "Quicksilver Power Mac G4". Citing Mac OS 9 Lives: logic board 820-1276-A limited to 128 GB drives, 820-1342-B supports larger drives.
