Power Macintosh/Performa 5000 Series Service Source
The Power Macintosh/Performa 5000 Series volume of Apple's Service Source is a 309-page service manual for the Power Macintosh 5400 and 5500 all-in-one computers. Its cover lists the Power Macintosh 5400/120, 5400/180, 5400/200 and 5500/225 and the international Performa 5400/160, 5400/180, 5420 and 5420/180; the Specifications chapter also gives figures for the 5500/250 and 5500/275.[1] Despite the cover title, it does not cover the 5200, 5300, 5260 or 5280, which have their own volumes; every chapter title page reads "Power Macintosh/Performa 5400 and 5500 Series".[2] The PDF was produced in FrameMaker and is dated 1 May 1997 in its metadata.
Like other Service Source volumes it is a module-level manual: specifications, symptom charts, take-apart procedures, CRT adjustments and exploded views with Apple part numbers. It has no schematics and no component values.
Figures as printed in the Specifications chapter
Item Apple's figure
CPU PowerPC 603e: 5400/120, /160, /180, /200 at 120-200 MHz; 5500/225, /250, /275 at 225-275 MHz; 64-bit PowerPC bus[1]
DRAM, 5400/120, /160, /180, 5420/180 8 or 16 MB soldered on board (by model); expandable to 136 MB in two 168-pin JEDEC DIMM slots, 70 ns or faster, 2K refresh[3]
DRAM, 5400/200 24 or 32 MB (8 MB soldered); expandable to 136 MB; 60 ns or faster, 2K refresh, 5-volt buffered EDO DIMMs[3]
DRAM, 5500 series 16 or 32 MB, none soldered; expandable to 128 MB; 60 ns or faster, 2K refresh, 5-volt buffered EDO DIMMs[3]
Frame buffer 5400: 1 MB DRAM on board. 5500: 2 MB SGRAM[3]
ROM and cache 4 MB ROM. Optional 256K level 2 cache on a 160-pin DIMM card; 512K on the 5500/275[3]
Storage 1.4 MB SuperDrive; 1.2 or 1.6 GB IDE (5400), 1.6 or 2.4 GB (5420/180), 2 GB or larger (5500); AppleCD 600i, 1200i or 12x/24x CD-ROM by model[4]
Expansion One 32-bit PCI slot for 7-inch cards (NuBus cards cannot be used); 60-pin video-in (DAV) slot, not compatible with the Quadra 660AV/840AV or Power Macintosh 6100/7100/8100 cards, though 5200/6200 cards fit with an adapter cable; communications slot for a modem or Ethernet card; optional TV/FM tuner[5]
Sound 16-bit record at 11, 22 or 44 kHz; output 0.5 V RMS nominal into 39 ohms; SRS surround-sound mode on the 5500[6]
Built-in display 15-inch shadow mask (12.8-inch viewable), 0.28 mm dot pitch, 66.7 Hz vertical, active raster 240 x 185 mm, white point 9,300 K[7]
Electrical 100-240 V AC, 47-63 Hz; 125 W. Surge 300 V rms for 100 ms; peak inrush 40 A; 2.5 A and 220 W maximum for all line and load conditions[8]
Dimensions 445 x 406 x 383 mm (17.5 x 16 x 15.1 in), H x W x D[9]
Environment Operating 10-40 °C; transit (72 h) -40 to +65 °C; storage (6 months) -40 to +47 °C; 20-95 % humidity non-condensing; altitude 0-3,000 m[10]
Clock battery Replace if below 3.0 V[11]
Apple prints the weight as "Without CD-ROM: 17 lb. With CD-ROM: 19 lb. (21.15 kg)"; the pound and kilogram figures do not agree.[9] The DIMM specification changes within the range: 70 ns DIMMs for the 5400/120, /160, /180 and 5420/180, and 60 ns 5-volt buffered EDO DIMMs for the 5400/200 and the 5500 series.[3]
Contents
Section starts, with PDF page numbers.
  • Basics (PDF p. 2): System Overview (3), Rev. B, 5000 Series (4), Configurations (5), Service Strategy (15), User Controls (18), Internal Expansion Connections (19), IDE Hard Drive (20), Video-In Card (21), TV Tuner Module (22), Digital Audio Video (DAV) Technology (27), External Video Connector (29), Apple Presentation System (30), PCI (31), GeoPort Technology (32), The Cuda Chip (34), DIMMs (35), CRT and Degauss Frame (38), Front View (39), Rear View (40), I/O Panel (41), 5400/5500 Logic Board (42)
  • Specifications (PDF p. 43): Introduction (44), Processor (45), Memory (47), Disk Storage (50), I/O Interfaces (52), I/O Devices (56), Sound and Video (58), Electrical (66), Physical (67), Environmental (68)
  • Troubleshooting (PDF p. 69): General (70), First Checklist (71), Symptom Charts: System (72), Audio (74), Video (76), Floppy Drive (84), Hard Drive (86), CD-ROM Drive (88), Peripheral (91), Miscellaneous (94)
  • Take Apart (PDF p. 98): Drive and Control Bezel (99), Floppy Drive (102), CD-ROM Drive (106), Front Panel Control Board (110), I/O Door (115), Logic Board (118), Video Card (124), PCI Adapter (125), NTSC Video-Out Card (126), Rear Housing (128), Front Bezel (132), Internal Microphone (136), Rear EMI Shield (138), Speakers, Original Version (141) and Rev. B (145), Hard Drive (150), TV Tuner (154), Power Supply, Original Version (157) and Rev. B (169), Video Board (173), Analog Shield (177), Analog Board, Original Version (180) and Rev. B (188), Internal RGB Cable (192), Fan (194), Tilt/Swivel Base (198), CRT (201), Chassis/Wiring Harness (207)
  • Upgrades (PDF p. 210): TV or TV/FM Tuner (211), DIMM Upgrade (214), Communications Card (222), External Video Connector (227), PCI Card (233), L2 Cache (243)
  • Additional Procedures (PDF p. 244): Battery Verification (245), Battery Replacement (247), Cuda Chip Reset (249), Logic Board Reset (250), PM 5500/225 Logic Board Identification (253), Processor Fan (260)
  • Adjustments (PDF p. 262): Light Meter Setup (263), Geometry (269), Video (286), High Voltage (301)
  • Exploded views (PDF pp. 306-309): one for the Power Macintosh 5400 and 5500, one for the Performa 5400/180, 5420 and 5420/180
What it settles
  • After replacing the CRT or deflection board, and with the set warmed up for 10 minutes, the high-voltage control is set so that a meter between the cathode of D713 (Rev. A analog board) or D703 (Rev. B) and chassis ground reads 29.5 V DC ± 0.1 V. The control is VR501 on Rev. A boards and VR702 on Rev. B; both are inside the analog board. The 5500 uses Rev. B parts.[12]
  • VR701 is horizontal shift, used with the three-position centring switch SW701; VR601 is vertical shift. On the CRT/video board, VR301 is sub-contrast, VR302 and VR303 are red and green gain, and VR304 and VR305 are red and green bias.[13]
  • Take Apart gives separate procedures for the original and Rev. B power supply, analog board and speakers, so identify the revision before ordering a part.
  • The exploded views give Apple part numbers for housings, the CRT assembly, boards and small parts.
What it does not contain
No schematics, no board-level parts lists and no component values. The exploded views give module and hardware part numbers only.
Pages that cite this document
Related volumes: Power Macintosh/Performa 5200 and 5300 Service Source and Power Macintosh/Performa 5260, 5280 Series Service Source.
The analog board and CRT carry lethal voltages. Follow the CRT Discharge Procedure before working inside the case.
Download: Powermac.perf_5400.5500.pdf (6.9 MB)
  1. ↑ 1.0 1.1 Apple Computer, Power Macintosh/Performa 5000 Series Service Source, cover (PDF p. 1) and Specifications, Processor (PDF pp. 45-46).
  2. ↑ Power Macintosh/Performa 5000 Series Service Source, chapter title pages (PDF pp. 2, 43, 69).
  3. ↑ 3.0 3.1 3.2 3.3 3.4 3.5 Power Macintosh/Performa 5000 Series Service Source, Specifications, Memory (PDF pp. 47-49).
  4. ↑ Power Macintosh/Performa 5000 Series Service Source, Specifications, Disk Storage (PDF pp. 50-51).
  5. ↑ Power Macintosh/Performa 5000 Series Service Source, Specifications, I/O Interfaces (PDF pp. 52-55).
  6. ↑ Power Macintosh/Performa 5000 Series Service Source, Specifications, I/O Interfaces, I/O Devices and Sound and Video (PDF pp. 53, 57-58).
  7. ↑ Power Macintosh/Performa 5000 Series Service Source, Specifications, Sound and Video (PDF p. 59).
  8. ↑ Power Macintosh/Performa 5000 Series Service Source, Specifications, Electrical (PDF p. 66).
  9. ↑ 9.0 9.1 Power Macintosh/Performa 5000 Series Service Source, Specifications, Physical (PDF p. 67).
  10. ↑ Power Macintosh/Performa 5000 Series Service Source, Specifications, Environmental (PDF p. 68).
  11. ↑ Power Macintosh/Performa 5000 Series Service Source, Additional Procedures, Battery Verification (PDF pp. 245-246).
  12. ↑ Power Macintosh/Performa 5000 Series Service Source, Adjustments, High Voltage (PDF pp. 301-305).
  13. ↑ Power Macintosh/Performa 5000 Series Service Source, Adjustments, Geometry and Video (PDF pp. 270-299).
