Power Macintosh/Performa 5260, 5280 Series Service Source
The Power Macintosh/Performa 5260, 5280 Series volume of Apple's Service Source is a 216-page service manual. Its cover lists the Power Macintosh 5260/100 and 5260/120 and the international Performa 5260/120 and 5280.[1] Apple notes that the Performa 5260/120 was sold in Canada and Australia, the Performa 5280 in Japan and the Power Macintosh 5260/120 in the United States and Canada.[1] The 5200/5300 volume excludes these models on its cover, so this is the manual for them. The PDF was produced in FrameMaker and is dated 25 April 1997 in its metadata.
Like other Service Source volumes it is a module-level manual: specifications, symptom charts, take-apart procedures, CRT and power-supply adjustments and an exploded view with Apple part numbers. It has no schematics and no component values.
Figures as printed in the Specifications chapter
Item Apple's figure
CPU 5260/100: PowerPC 603e at 100 MHz. 5260/120 and 5280: PowerPC 603e at 120 MHz. 64-bit PowerPC bus[2]
Memory 16 MB DRAM minimum, expandable to 64 MB (72-pin, 80 ns or faster SIMMs); 1 MB DRAM frame buffer; 4 MB ROM; 256K level 2 cache[2]
Storage 1.4 MB SuperDrive; 800 MB, 1.2 GB or 1.6 GB IDE; AppleCD 600i (5260/100) or AppleCD 1200i (5260/120, 5280)[3]
Expansion 112-pin communications slot (68040-bus) for a modem or Ethernet card; 96/114-pin LC-compatible processor-direct slot; 60-pin video-in slot; 10-pin TV tuner port[4]
Sound Records at 11 or 22 kHz; 16-bit mono input, 16-bit stereo output, 0.5 V RMS nominal into 39 ohms[5]
Built-in display 14-inch shadow mask (12.8-inch viewable), 0.28 mm dot pitch, 66.7 Hz vertical, active raster 240 x 185 mm, white point 9,300 K, aluminised P22 phosphor, shipping brightness 25 foot-lamberts; 640x480 at 16-bit colour[6]
Electrical 100-240 V AC, 47-63 Hz; power 240 W maximum; surge 300 V RMS for 100 ms; peak inrush 40 A; 4.0 A maximum for all line and load conditions. The same page also prints "Power: 220 W maximum for all line and load conditions".[7]
Dimensions 445 x 406 x 383 mm (17.5 x 16 x 15.1 in), H x W x D; weight printed as "17 lb. / 19 lb. (21.15 kg)", which do not agree[8]
Clock battery Replace if below 3.0 V, measured with the I/O door, logic board and battery removed[9]
The Specifications chapter also prints monitor timings for 640x480 at 60 Hz and 66.67 Hz and for 800x600 at 60 Hz and 72 Hz, and the phosphor CIE coordinates (red x 0.643, y 0.324; green 0.301, 0.606; blue 0.142, 0.056). The "60 Hz" 640x480 table repeats the 66.67 Hz figures (30.24 MHz dot clock, 35.000 kHz line rate).[6]
Contents
Section starts, with PDF page numbers.
  • Basics (PDF p. 2): System Overview (3), 5260/120 and 5280 (4), Service Strategy (5), User Controls (8), Internal Expansion Connections (9), IDE Hard Drive (10), Processor Direct Slot (11), Video-In Card (12), MPEG Card (13), TV Tuner Module (14), TV/FM Radio Tuner Card (15), External Video Connector (19), Apple Presentation System (20), The Cuda Chip (21), CRT and Degauss Frame (22), Front View (23), Rear View (24), I/O Panel (25), 5260/5280 Logic Board (26)
  • Specifications: Processor (28), Memory (29), Disk Storage (30), I/O Interfaces (31), I/O Devices (34), Sound and Video (35), Electrical (42), Physical (43), Environmental (44)
  • Troubleshooting: General (46), First Checklist (47), Symptom Charts: System (48), Audio (51), Video (53), Floppy Drive (60), Hard Drive (62), CD-ROM Drive (64), Peripheral (67), Miscellaneous (70)
  • Take Apart: Drive and Control Bezel (75), Floppy Drive (78), CD-ROM Drive (82), Front Panel Control Board (86), I/O Door (91), Logic Board (94), Rear Housing (100), Front Bezel (104), Internal Microphone (107), Rear EMI Shield (109), Speakers (113), Hard Drive (117), TV Tuner (121), Power Supply (124), Video Board (129), Analog Shield (132), Analog Board (135), Fan (141), Tilt/Swivel Base (144), CRT (147), Chassis/Wiring Harness (152)
  • Upgrades: TV or TV/FM Tuner (155), SIMM Upgrade (158), Communications Card (160), External Video Connector (165), L2 Cache (171), LC PDS Card (172)
  • Additional Procedures: Battery Verification (174), Battery Replacement (176), Cuda Chip Reset (178), Logic Board Reset (179)
  • Adjustments, headed "5260 and 5280 Adjustments" (PDF p. 183): Light Meter Setup (184), Geometry (190), Video (201), Power Supply (213)
  • Exploded view (PDF pp. 215-216)
What it settles
  • The power-supply adjustment must be made whenever the analog board or power supply has been removed: with the meter's ground lead on the chassis and the other lead on pin 3 of connector P805 on the power supply, R828 is set for 110 V DC. (The figure labels pin 1 of P805 to locate the connector.)[10]
  • The 5260/5280 chassis uses different adjustment controls from the 5200/5300 and 5400/5500: horizontal size is R440 (raster width 240 mm ± 2 mm), vertical size R327 (185 mm ± 2 mm), and the video adjustments use bias controls R910, R940 and R970 (red, green, blue), drive controls R501, R531 and R561 (red, green, blue) and sub-brightness R500 (set for 25 foot-lamberts on a photometer). There is no 29.5 V high-voltage procedure in this volume; the one in the 5200/5300 volume is marked "not for 5260, 5280".[11]
  • The Cuda chip reset is a switch on the logic board, pressed with a plastic tool after removing the power cord, I/O door and logic board.[12]
What it does not contain
No schematics, no board-level parts lists and no component values. The exploded view gives module and hardware part numbers only. Unlike the 5200/5300 volume, it has no REA Procedures chapter.
Pages that cite this document
Related volumes: Power Macintosh/Performa 5200 and 5300 Service Source and Power Macintosh/Performa 5000 Series Service Source (5400 and 5500).
The analog board, power supply and CRT carry lethal voltages. Follow the CRT Discharge Procedure before working inside the case.
Download: Powermac.perf_5260.5280.pdf (5.8 MB)
  1. ↑ 1.0 1.1 Apple Computer, Power Macintosh/Performa 5260, 5280 Series Service Source, cover (PDF p. 1) and Basics, 5260/120 and 5280 (PDF p. 4).
  2. ↑ 2.0 2.1 Power Macintosh/Performa 5260, 5280 Series Service Source, Specifications, Processor and Memory (PDF pp. 28-29).
  3. ↑ Power Macintosh/Performa 5260, 5280 Series Service Source, Specifications, Disk Storage (PDF p. 30).
  4. ↑ Power Macintosh/Performa 5260, 5280 Series Service Source, Specifications, I/O Interfaces (PDF pp. 31-33).
  5. ↑ Power Macintosh/Performa 5260, 5280 Series Service Source, Specifications, Sound and Video (PDF p. 35).
  6. ↑ 6.0 6.1 Power Macintosh/Performa 5260, 5280 Series Service Source, Specifications, Sound and Video (PDF pp. 36-40).
  7. ↑ Power Macintosh/Performa 5260, 5280 Series Service Source, Specifications, Electrical (PDF p. 42).
  8. ↑ Power Macintosh/Performa 5260, 5280 Series Service Source, Specifications, Physical (PDF p. 43).
  9. ↑ Power Macintosh/Performa 5260, 5280 Series Service Source, Additional Procedures, Battery Verification (PDF pp. 174-175).
  10. ↑ Power Macintosh/Performa 5260, 5280 Series Service Source, Adjustments, Power Supply (PDF pp. 213-214).
  11. ↑ Power Macintosh/Performa 5260, 5280 Series Service Source, Adjustments, Geometry and Video (PDF pp. 190-212).
  12. ↑ Power Macintosh/Performa 5260, 5280 Series Service Source, Additional Procedures, Cuda Chip Reset (PDF p. 178).
