Power Macintosh 6100/ WS 6150 Service Source
The Power Macintosh 6100/WS 6150 Service Source is Apple's 160-page service manual for the Power Macintosh 6100/60, 6100/60AV, 6100/66, 6100/66AV, 6100/DOS Compatible and Workgroup Server 6150. The PDF was created on 2 January 1996. Page numbers below are PDF pages.
Like other Service Source volumes it is module-level: Apple's specifications, symptom charts, take-apart procedures, upgrade procedures and an exploded view with part numbers. It has no schematics and no component values.
Specifications as Apple prints them
Selected specifications
Item As printed Page
CPU PowerPC 601 at 60 MHz (6100/60, 6150) or 66 MHz (6100/66, 6150/66), built-in MMU and FPU, 32K on-chip cache 23
RAM 8 MB soldered; two SIMM sockets taking a pair of the same size and speed, 80 ns or faster, noncomposite; 72 MB maximum 24
A/C line input 100–240 V AC RMS single phase, automatically configured; 50–60 Hz 35
Input power 132 W maximum continuous, 201 W peak (excluding monitor) 35
Power supply DC output 86 W continuous 35
Clock battery Long-life lithium; replace below 3.2 V 25, 103
Contents
  • Basics: Power Macintosh System Overview (p. 3), HDI-45 Pinouts (p. 9), Rear Panel Connectors (p. 15), Logic Board Connectors (p. 17), Apple RAID Software (p. 19)
  • Specifications: Processor (p. 23), Memory (p. 24), Disk Storage (p. 26), I/O Interfaces (p. 28), I/O Devices (p. 32), Video Display (p. 33), Electrical (p. 35), Physical (p. 36), Environmental (p. 37)
  • Troubleshooting: General (p. 39), Symptom Charts (p. 40), including a Global Village modem "Busy Serial Port" chart (p. 55)
  • Take Apart: Top Housing (p. 58), Power Supply (p. 60), Logic Board (p. 66), DOS Compatibility Card (p. 72), Floppy Drive (p. 80), Hard Drive (p. 84), CD-ROM Drive (p. 88), Bottom Housing Assy (p. 92), Speaker & Floppy Cable (p. 94)
  • Additional Procedures: Battery Verification (p. 102), Battery Replacement (p. 104), Reset Logic Board (p. 107)
  • Upgrades: Expansion Cards (p. 114), CD-ROM Upgrade (p. 119), DOS Compatibility Upgrade (p. 126), Power Macintosh Upgrade (p. 140)
  • Exploded View (p. 160)
Notable content
The Basics chapter prints the HDI-45 video connector pinout (pp. 9–14), with the rear panel and logic board connector maps. Apple's troubleshooting tips (pp. 6–8) say that on these machines a dialog box reports bad SIMMs and there are no death chimes, and that a machine that will not power up should have its logic board reset first. The DOS Compatibility Upgrade section (pp. 126–139) covers fitting the 486DX2 card and warns that its J10 jumper is mismarked and must be in the "SX" position. The Power Macintosh Upgrade section (pp. 140–158) covers the logic board kits that turned other machines into a 6100/60 or WS 6150.
  • No schematic, no parts list below module level, no component values.
  • No Adjustments chapter and no rail voltages.
  • The exploded view does not say which of the two logic board part numbers (661-0207, 661-1022) is which model.
Pages that cite this document
Related volumes: Power Macintosh 7100 Series Service Source and Power Macintosh 8100/ WS 8150 Service Source cover the other first-generation Power Macintosh models. Apple's developer notes for the 6100/60 and 6100/66 are hosted as File:Power Macintosh Computers Developer Note (1994).pdf and File:Enhanced Power Macintosh Computers Developer Note (1994).pdf.
Download: Powermac_6100_series.pdf (1.6 MB)
