Power Macintosh 7100 Series Service Source
The Power Macintosh 7100 Series Service Source is Apple's 132-page service manual for the Power Macintosh 7100/66, 7100/66AV, 7100/80 and 7100/80AV. The PDF was created on 10 November 1995. Page numbers below are PDF pages.
It is module-level: Apple's specifications, symptom charts, take-apart procedures, upgrade procedures and an exploded view with part numbers. It has no schematics and no component values.
Specifications as Apple prints them
Selected specifications
Item As printed Page
CPU PowerPC 601 at 66 MHz (needs system software 7.1.2 or later) or 80 MHz (7.5 or later, with enabler 1.1.1 or later); built-in MMU and FPU; 32K on-chip cache 20
RAM 8 MB soldered; four SIMM sockets taking pairs of the same size and speed, 80 ns or faster, 72-pin, noncomposite; 136 MB maximum 21
VRAM 1 MB, expandable to 2 MB with four 256K VRAM SIMMs (7100/66, 7100/80); 2 MB (AV models) 22
Level-2 cache Optional 256K (7100/66); standard 256K (7100/80) 22
A/C line input 100–240 V AC RMS single phase, automatically configured; 50–60 Hz 31
Input power 167 W maximum continuous, 230 W peak (excluding monitor) 31
Power supply DC output 112 W continuous 31
Clock battery Long-life lithium; replace below 3.2 V 22, 120
Contents
  • Basics: Power Macintosh System Overview (p. 3), HDI-45 Pinouts (p. 9), Rear Panel Connectors (p. 15), Logic Board Connectors (p. 17)
  • Specifications: Processor (p. 20), Memory (p. 21), Disk Storage (p. 23), I/O Interfaces (p. 25), I/O Devices (p. 28), Video Display (p. 29), Electrical (p. 31), Physical (p. 32), Environmental (p. 33)
  • Troubleshooting: General (p. 35), Symptom Charts (p. 36)
  • Take Apart: Top Cover (p. 53), Power Supply (p. 55), Drive Chassis (p. 59), Floppy Drive (p. 66), Hard Drive (p. 68), CD-ROM Drive (p. 71), Video Card (p. 76), Fan (p. 78), Speaker (p. 83), Logic Board (p. 85)
  • Upgrades: Expansion Cards (p. 90), CD-ROM Upgrade (p. 92), Power Macintosh Upgrade (p. 98)
  • Additional Procedures: Battery Verification (p. 119), Battery Replacement (p. 121), Reset Logic Board (p. 124), Reset/Interrupt (p. 129)
  • Exploded View (p. 132)
Notable content
The Basics chapter prints the HDI-45 video connector pinout (pp. 9–14). The Power Macintosh Upgrade section describes the 7100/66 upgrade kit for the Centris 650 and Macintosh Quadra 650, which contains a 7100/66 logic board, top housing, bottom chassis, manual-insert floppy drive, video card, SCSI power cable and CD-ROM EMI shield (pp. 98–99). The logic board reset removes the battery, presses the power-on button on the rear panel beneath the power outlet and waits 5 to 10 minutes (pp. 124–128). A separate procedure covers removing the reset/interrupt actuator (pp. 129–130).
  • No schematic, no parts list below module level, no component values.
  • No Adjustments chapter and no rail voltages.
Pages that cite this document
Related volumes: Power Macintosh 6100/ WS 6150 Service Source and Power Macintosh 8100/ WS 8150 Service Source. Apple's developer notes for the 7100/66 and 7100/80 are hosted as File:Power Macintosh Computers Developer Note (1994).pdf and File:Enhanced Power Macintosh Computers Developer Note (1994).pdf.
Download: Powermac_7100_series.pdf (938 KB)
