Power Macintosh 7100 Capacitor Replacement Guide
The Power Macintosh 7100 logic board, 820-0597-A, uses surface-mount tantalum capacitors. Console5 lists 26 of them: twenty-five 47 µF 16 V parts and one 100 µF 6.3 V part, and sells them as a "tantalum main PCB cap kit".[1] Apple's Power Macintosh 7100 Series Service Source is module-level and names no capacitors; it treats the power supply as one part, 661-0758, and the logic board as 661-0897 or 661-0208.[2]
Logic board capacitors
[edit | edit source]| Position | Value | Rating |
| C13 | 47 µF | 16 V |
| C15 | 47 µF | 16 V |
| C18 | 47 µF | 16 V |
| C19 | 47 µF | 16 V |
| C22 | 47 µF | 16 V |
| C25 | 47 µF | 16 V |
| C26 | 47 µF | 16 V |
| C29 | 47 µF | 16 V |
| C30 | 47 µF | 16 V |
| C31 | 47 µF | 16 V |
| C33 | 47 µF | 16 V |
| C34 | 47 µF | 16 V |
| C35 | 47 µF | 16 V |
| C38 | 47 µF | 16 V |
| C40 | 47 µF | 16 V |
| C42 | 47 µF | 16 V |
| C43 | 47 µF | 16 V |
| C44 | 47 µF | 16 V |
| C45 | 47 µF | 16 V |
| C46 | 47 µF | 16 V |
| C53 | 47 µF | 16 V |
| C56 | 47 µF | 16 V |
| C58 | 47 µF | 16 V |
| C62 | 100 µF | 6.3 V |
| C63 | 47 µF | 16 V |
| C65 | 47 µF | 16 V |
Source: Console5.[1] This is a community list, not an Apple one; read the marking on each part before removing it and go by what is on the board.
Do they need replacing?
[edit | edit source]Apple's 7100 symptom charts do not mention capacitor faults. Recap-a-Mac's verdict on the related Power Macintosh 6100 board, which uses the same 47 µF 16 V tantalums, was that it "probably" does not need recapping yet.[3] Replace a part when it is visibly damaged, shorted or out of value, or when there is corrosion round it. The Recap-a-Mac finding is for the 6100 board, not the 7100.
Inspection
[edit | edit source]Remove the top housing, power supply, drive chassis, video card and reset/interrupt actuator, take out the SIMMs, cache and ROM, and lift out the logic board as Apple describes (pp. 53–88).[2] The procedure is summarised on Power Macintosh 7100 General Maintenance. Look for:
- cracked, scorched or discoloured tantalum bodies
- corrosion or residue round the battery holder; a leaking lithium cell leaves acidic residue (see Battery Explosion, Capacitor or Corrosion Damage)
- corrosion on the SIMM, ROM and cache sockets
Capacitor Failure Symptoms describes what failing parts look like.
Replacement
[edit | edit source]- Photograph the board and note the value, voltage and polarity of each part before removing anything.
- Remove the tantalum with hot air or two irons without lifting the pads.
- Fit the new part the right way round. On a tantalum capacitor the band marks the positive terminal, the opposite of the band on an aluminium electrolytic.[4]
- Use a replacement of the same capacitance and at least the same voltage rating. If you fit aluminium electrolytics in place of tantalums, their band marks the negative lead.
- Clean off flux with isopropyl alcohol and check for bridges.
- Before the first power-up, measure across each new part for a short to ground.
- Refit the logic board, ROM, cache and SIMMs (the ROM and cache sockets are interchangeable; check which module goes where), video card, drive chassis and power supply, then reset the logic board as Apple describes (pp. 86, 124–128).[2]
[edit | edit source]Neither Apple's manual nor Console5 lists the capacitors of the 661-0758 supply. Record the values from the board before removing anything and fit parts of the same capacitance and at least the same voltage rating. The supply is auto-ranging for 100–240 V (p. 31), so the primary-side reservoir charges to about 340 V on 240 V mains (240 × √2). Discharge it and confirm with a meter before touching the primary side.[2]
[edit | edit source]- Power Macintosh 7100
- Power Macintosh 7100 General Maintenance
- Power Macintosh 7100 Troubleshooting
- Power Macintosh 6100 Capacitor Replacement Guide
- Capacitor Failure Symptoms
[edit | edit source]- ↑ 1.0 1.1 Console5 Tech Wiki, "Power Macintosh", section "7100: 820-0597-A", with a link to Console5's "Power Macintosh 7100 Tantalum Main PCB Cap Kit 820-0597-A" (secondary source).
- ↑ 2.0 2.1 2.2 2.3 Apple Computer, Service Source: Power Macintosh 7100 Series (1995), File:Powermac_7100_series.pdf; see Power Macintosh 7100 Series Service Source. Exploded view, PDF p. 132; take-apart procedures pp. 53–88.
- ↑ Recap-a-Mac, "Power Macintosh 6100" (secondary source). Recap verdict for the 6100 logic board: "probably" not needed.
- ↑ KEMET, T491 Industrial Grade MnO2 datasheet, "Reverse Voltage", p. 15, content.kemet.com. Solid tantalum capacitors are polar and may be destroyed if connected the wrong way; "the positive terminal is identified on the capacitor body by a stripe".
