Macintosh Performa 588CD
The Macintosh Performa 588CD is a Performa version of the Macintosh LC 580 that Apple did not sell in the United States. Apple's specification sheet gives an introduction date of 13 April 1995 and Japanese system software (KanjiTalk 7.5) as shipped.[1] Apple Japan sold it as the Performa 588, with 8 MB of RAM, a 500 MB IDE hard disk, a double-speed tray-loading CD-ROM drive, a 14-inch shadow-mask screen showing 32,768 colours at 640 × 480, and an Apple Keyboard II with JIS layout; there was no fax modem, and video input was an option.[2] EveryMac records it as sold in Europe and Asia, with Japanese order number M4059J/A, until 1 May 1996.[3]
The hardware is the same as the Macintosh Performa 580CD's, and Apple's Macintosh LC 580/Performa 580CD Service Source is the service manual for it.[1][4] The case looks the same as the Performa 575-578's, but the logic board is new, with an IDE hard disk interface and video input and output expansion, and the screen is a shadow-mask tube in place of a Trinitron.[3]
| Processor | Motorola 68LC040 at 33 MHz, built-in MMU, no FPU[4][1] |
| RAM | 8 MB as shipped, 4 MB of it on the logic board; two 72-pin SIMM connectors, 80 ns; 52 MB maximum. The second slot takes only 1, 4 or 16 MB SIMMs[4][1] |
| ROM | 1 MB[4] |
| Video memory | 1 MB of DRAM soldered to the logic board[4] |
| Display | 14-inch diagonal, 11.5-inch viewable; 0.28 mm dot-pitch shadow mask; 640 × 480 at 66.67 Hz[4] |
| Sound | Records and plays at 11 or 22 kHz; mono input; 8-bit stereo output and headphone jack; built-in microphone and speakers[4] |
| Ports | One ADB; two serial (modem port 9-pin mini-DIN, printer port 8-pin); one SCSI (DB-25, up to six external devices)[4] |
| Slots | 114-pin processor-direct slot; 112-pin communications slot; 60-pin video-in slot; 22-pin external video connector slot[4] |
| Power supply | 90-264 V rms, 50-60 Hz; 2.0 A and 120 W maximum[4] |
| Size and weight | 45.5 × 34.4 × 42.0 cm; 18.4 kg (40.5 lb)[4] |
Battery
[edit | edit source]Apple's specification sheet lists a 4.5 V alkaline battery; the Service Source's specification page says "long-life lithium battery" without naming a part.[1][4] Apple's test is to measure the battery on the 10 V DC range with the logic board out and replace it below 3.0 V.[4] Check the pack's markings before buying a replacement. Alkaline leakage is neutralised with a weak acid such as vinegar, lithium leakage with bicarbonate of soda; see Battery Explosion, Capacitor or Corrosion Damage.
Maintenance and repair
[edit | edit source]Service the Performa 588CD as an LC 580: the Macintosh LC 580 page covers the logic board capacitors, analog board and CRT, take-apart, display adjustments and Apple's symptom charts. The analog board and CRT carry high voltage and hold a charge after the machine is unplugged; see CRT Discharge Procedure.
[edit | edit source]- Macintosh LC 580/Performa 580CD Service Source: Apple's service manual.[4]
[edit | edit source]- ↑ 1.0 1.1 1.2 1.3 1.4 Macintosh Performa 588CD: Technical Specifications, Apple—link(accessed 2026-09-30) Introduced 4/13/1995; "This system is not sold in the U.S."; original system software J-7.5; 68LC040, no FPU; 8-52 MB, second SIMM slot 1, 4 or 16 MB only; 1 MB DRAM video, 640 × 480 at 16-bit; 500 MB IDE; Gestalt ID 99; battery type 4.5 V alkaline.
- ↑ Macintosh Performa 588, Apple Japan—link(accessed 2026-09-30) Data sheet: 68LC040 66/33 MHz; no L2 cache; 8 MB, 52 MB maximum (SIMM); 500 MB IDE; double-speed tray CD-ROM; 14-inch shadow mask; 640 × 480, 32,768 colours; built-in stereo speakers and microphone; Apple Keyboard II JIS; no internal fax modem; video input optional; bundle including ClarisWorks 2.0 and At Ease 2.0.
- ↑ 3.0 3.1 Apple Macintosh Performa 588CD Specs, EveryMac—link(accessed 2026-09-30) Introduced 1 April 1995, discontinued 1 May 1996; sold in Europe and Asia; 8 MB RAM; 500 MB IDE; 2X CD-ROM; order number M4059J/A in Japan.
- ↑ 4.00 4.01 4.02 4.03 4.04 4.05 4.06 4.07 4.08 4.09 4.10 4.11 4.12 4.13 Apple Computer, Macintosh LC 580/Performa 580CD Service Source (1995), File:Lc 580.performa 580cd.pdf; see Macintosh LC 580/Performa 580CD Service Source. PDF page numbers: General Information pp. 3-4; Specifications pp. 8-20; Battery Verification pp. 109-110.
