Apple Lisa Troubleshooting
Revision as of 12:52, 16 July 2026 by Josh (talk | contribs) (Add representative photo (sourced from Wikimedia Commons, attributed on file page))
Troubleshooting is essential for diagnosing and resolving issues with your Apple Lisa. This guide covers the most common problems encountered with Lisa systems.
Preliminary Checks
  • Verify power outlet is working
  • Check that all cables are properly connected
  • Ensure the power supply voltage selector (if present) is set correctly for your region
  • Allow adequate time for capacitor discharge before internal work (24+ hours)
No Power / Dead System
Apple Lisa. Source: Wikimedia Commons.
No Power Diagnostics
No response when power switched on Failed RIFA safety capacitors Inspect and replace RIFA capacitors in power supply
Clicking or ticking from power supply Power supply overload or short Check for shorts on motherboard; replace power supply capacitors
Trips circuit breaker Shorted RIFA capacitor Replace all RIFA safety capacitors immediately
Power supply smokes RIFA capacitor failure Disconnect immediately; replace all safety capacitors
Intermittent power Failing electrolytic capacitors Full power supply recap recommended
Powers on briefly then shuts off Power supply protection circuit triggering Check for shorts; verify output voltages
RIFA Capacitor Failure
RIFA-brand safety capacitors are the most common cause of Lisa power problems:
  • These capacitors absorb moisture over decades and fail catastrophically
  • They may emit smoke, loud pops, or acrid smell when failing
  • ALWAYS replace preventatively before powering on a long-stored Lisa
  • Replace with modern X2-rated capacitors of equivalent value
Self-Test Error Codes
The Lisa displays error codes during its self-test sequence:
Common Lisa Error Codes
Error Code Component Description
10-19 CPU Board CPU board failure; check RAM, ROM, or processor
20-29 I/O Board I/O board error; check IWM, serial ports, or ROM
57 Disk Controller Disk controller failure on I/O or CPU board
70-79 Memory Memory card error (icon shows affected slot: MEM1 or MEM2)
80-89 Storage Hard drive or floppy drive error
82 Widget Generic Widget drive failure
Error 57 (Disk Controller)
  • Reseat all socketed chips on the I/O board
  • Check the IWM (Integrated Woz Machine) chip
  • Verify I/O ROM is correct version (H/88 for Lisa 2/10)
  • Inspect for cracked solder joints
Error 70 (Memory)
  • The error icon shows which memory slot is affected (MEM1 or MEM2)
  • Try each memory card individually
  • Clean the edge connector contacts with isopropyl alcohol
  • Individual RAM chip testing may be required
Error 82 (Widget)
  • Generic Widget drive failure code
  • Widget may require low-level format (no utility publicly available)
  • Consider ProFile emulator (X/ProFile, IDEfile) as replacement
  • Check Widget cable connections
Video Problems
Display Issues
No display, system runs CRT failure or analog board issue Check CRT connections; test analog board
Horizontal line only Vertical deflection failure Check vertical output IC and capacitors on analog board
Vertical line only Horizontal deflection failure Check horizontal output transistor and flyback
Image shifted horizontally H-position adjustment needed Adjust horizontal position potentiometer
Garbled/checkered display Memory or video RAM issue Test with known-good memory cards
Bright flash/line at shutdown Normal CRT behavior CRT discharge is expected at power-off
Dim or faded display CRT aging or brightness adjustment Adjust brightness; CRT may need replacement
CRT Adjustments
  • Horizontal and vertical position/size controls are on the analog board
  • Focus adjustment may be on the flyback transformer
  • Always discharge CRT before making adjustments
Keyboard Problems
Keyboard Issues
No keys working Keyboard cable disconnected Check cable connection to I/O board
Most keys not working Deteriorated foam pads Replace capacitive foam and foil pads
Some keys work, others don't Individual pad failure Replace foam/foil on affected keys
Keyboard error on boot Keyboard not detected Check cable; verify keyboard controller chip
Foam Pad Replacement
The Lisa keyboard uses capacitive foam pads that deteriorate with age:
  • Purchase Lisa keyboard foam/foil replacement kit
  • Each key requires a new foam pad and conductive foil
  • This is the most common Lisa keyboard repair
Floppy Drive Problems
Floppy Drive Issues
Drive won't accept disk Seized eject mechanism Clean and lubricate mechanism with isopropyl alcohol
No disk spinning Motor or motor controller failure Check TA7259 motor IC; may require spindle repair
Read errors Dirty heads or alignment Clean heads; check for alignment issues
Intermittent reads Failing capacitors near drive controller Check/replace associated capacitors
Floppy Emu Compatibility
  • FloppyEmu can be used with Lisa systems
  • Requires appropriate cable adapter
  • External connection may require modification
Widget Drive Problems
The Widget (internal hard drive in Lisa 2/10) has known reliability issues:
Widget Issues
Widget not recognized Cable connection or controller failure Check cables; verify controller on I/O board
Error 82 on boot Generic Widget failure Drive may need replacement with ProFile emulator
Widget spins but won't boot Corrupted data or head issues Attempt boot from floppy; consider drive replacement
Clicking sounds from Widget Head or mechanism failure Drive likely requires replacement
ProFile Emulator Options
Modern alternatives to the Widget drive:
  • X/ProFile — Drop-in Widget replacement using CompactFlash
  • IDEfile — ProFile emulator using IDE drives
  • Both provide higher reliability than original Widget drives
⚠️ The I/O-board battery pack — remove it now
The Lisa keeps its real-time clock alive with a 4 × AA NiCd pack strapped to the bottom-right of the I/O board. These packs leak corrosive electrolyte and are the single most destructive Lisa fault — when they let go they can destroy the I/O board and the motherboard, and in rare cases the CPU and RAM boards. Remove the battery pack from any Lisa immediately, and clean and repair any corrosion before powering up.[1]
Boot self-test and error codes
The Lisa boot ROM runs a self-test and, on a fault, shows a numeric error code and draws a cross (X) over the icon of the failing board. Useful codes:
  • 40 — CPU-board / MMU fault (a failed MMU register test loops endlessly; the CRT goes blank once warm).
  • 57 — disk-controller fault.
The card-based design makes diagnosis a matter of swapping the CPU, memory and I/O boards; almost everything is user-replaceable except the CRT and video board.[1]
A Lisa that runs for a few minutes and then switches off, or will not power on at all, has a failing power supply — a known weak point that should be serviced/recapped.[1]
Twiggy drives (Lisa 1)
The Lisa 1 used two Apple "Twiggy" 5.25-inch 860 KB drives, which were unreliable; most Lisa 1s were upgraded to the Lisa 2 with a Sony 400 KB 3.5-inch drive. Twiggy read errors and disk-boot failures are why so few Lisa 1s survive — a Lisa 2 conversion or a modern floppy emulator is the usual path.[1]
  1. 1.0 1.1 1.2 1.3 The Apple Lisa FAQ; Lisa 2 repair journey, TinkerDifferent; Rejuvenating an Apple Lisa 2/10, Tezza's Classic Computers; and the Apple Lisa Do-It-Yourself Guide. Source for the I/O-board battery-pack leakage, the PSU failure, the Twiggy-drive unreliability, and the boot-ROM error codes (40 = CPU/MMU, 57 = disk controller).
