Macintosh SE/30 Troubleshooting
This guide provides solutions to common faults experienced in the Macintosh SE/30. From power issues to Simasimac patterns and SCSI failures, these diagnostics will help identify, isolate, and resolve problems.
π Preliminary Checks and Power Supply Basics
Begin by verifying the analog board delivers proper voltages:
- +5V rail: 4.90V β 5.10V
- +12V rail: Confirmed at floppy or hard drive connectors
If the unit is completely dead (no fan, CRT glow, or chime), inspect:
- Fuses
- Rectifiers CR2 and CR3
- Transistor Q2
- Resistor R22
Also:
- Disconnect external peripherals and cards
- Check logic board for PRAM battery corrosion
- Replace all electrolytic capacitors on the logic board
πΊ "Simasimac" β Horizontal Stripe Pattern
The infamous "Simasimac" pattern shows horizontal black-and-white lines with no startup chime. Causes include:
- Leaking capacitors disrupting the reset circuit
- Corroded traces or vias near RAM/ROM
Solutions:
- Clean and reseat ROM and RAM SIMMs
- Replace PRAM battery if < 3V
- Check for reset pulse at CPU
- Test for 16 MHz clock at CPU
- Inspect Apple Sound Chip (ASC) at UB11 and filter RP2
- Use multimeter or oscilloscope to confirm continuity
π Chimes of Death and Sad Mac Codes
The Chimes of Death signify early boot failureβcommonly RAM or ROM faults.
Checklist:
- Use 4 matched SIMMs per bank
- Larger-capacity SIMMs go in Bank A
- Clean/reseat ROM SIMM
- Check address/data continuity near capacitors
- Replace 74F258 multiplexers or RAM if needed
- Check VIA chips for overheating or corrosion
See: Sad Mac Error Codes for detailed interpretation.
π₯οΈ Video Display Issues
π No Video but Chime Present
- Verify brightness knob
- Confirm CRT glow
- Check UE8 (video multiplexer)
- Probe video/sync signals at P1 connector
πΆ Vertical "Jailbar" Stripes
- Indicates incorrect RAM configuration
- Use identical SIMMs per bank (larger ones in Bank A)
π§© Checkerboard Pattern
- Typically a ROM failure
- Clean/reseat the ROM SIMM
- Confirm compatibility (use SE/30 or IIsi ROMs only)
πΎ Disk Drive and SCSI Issues
βοΈ Frozen Mouse on Gray Screen
- Possible failure of SCSI controller (NCR 53C80)
- Disconnect all internal/external SCSI devices
- Inspect and replace termination resistors
π₯ Floppy Drive Issues
- Dirty mechanism
- Faulty SWIM controller
- Cold solder joints on VIA or SWIM ICs
For more, see:
π Audio and ADB Issues
π No Sound
- Test audio at the headphone jack
- Inspect ASC (Apple Sound Chip)
- Inspect analog board audio amplifier
β¨οΈ ADB Malfunction
- Blown fuse F1
- Failed ADB microcontroller (Egret)
- VIA chip solder cracks or corrosion
β±οΈ Reset and Clock Problems
- Random resets: Check power rail stability
- No time retention: Dead PRAM battery or failed 32.768 kHz crystal
- Check surrounding electrolyte residue near Egret or VIA chips
β‘ Brief Analog Board Troubleshooting
- Vertical line only: Horizontal deflection fault β reflow P1 connector and replace C15
- Horizontal line only: Vertical deflection fault β reflow P1 and replace TDA1170A
- Wavy or distorted video: Failing flyback transformer
- PSU clicking repeatedly: Shorted logic board or failed CR2, CR3, Q2, or R22
