Commodore 64 General Maintenance
The Commodore 64 (C-64, C64 C, “bread bin”, 64C, Aldi C64, SX-64) is now 40-plus years old. Aging electrolytic capacitors, brittle plastics, and the infamous “death‐brick” PSU all put these machines at risk.
This page collects best-practice hardware care, preventive service, fault-pre-emption, and periodic checks for every board revision from 1982 ASSY 250407 to the late 250469-05 short board. Follow the sections below to keep a C-64 healthy for the next four decades.
Identify Your Board Revision
| ASSY | Year(s) | Key Differences |
| 326298 (“Rev A”) | 1982 | 5-pin A/V DIN, 6567R56A / 6569R1 VIC-II, ceramic SID (6581R1), fully socketed |
| 250407 / 250425 | 1983-84 | 8-pin A/V DIN, original long board, PLA 906114-01, discrete DRAM (8×4164) |
| 250466 | 1984-85 | Long board, HMOS-II 6510 CPU & 8701 clock chip, “short” color RAM, improved RF modulator |
| 250469 rev 3/4/5 (“64C short”) | 1986-92 | Short board, 64-pin CSG 8500 CPU + PLA inside 64-pin “Super PLA” (Chips #252535-xx), HMOS-II 8565 VIC-II, 8580 SID, 2×128-kbit DRAMs |
| SX-64 portable | 1984-86 | 5″ RGB CRT, 1541 mechanism inside; logic equivalent to 250425 |
Find the ASSY number silkscreened near the cartridge port or RF modulator.
Regular Cleaning
Case & Keyboard
- Wipe ABS plastic with a damp micro-fiber cloth & mild dish-soap.
- Keys pop off vertically; clean plungers with 99 % IPA. De-yellow with retro-brite only if you can monitor surface temp.
- Lube space-bar stabiliser wire with plastic-safe grease.
PCB Dust & Oxidation
- Disconnect PSU; wait 5 min for the +5 V rail to drain.
- Blow dust with compressed air, brush gently with anti-static brush.
- Re-seat every socketed IC to wipe oxidised contacts.
Power Supply: The “Death Brick”
Original Commodore linear bricks often drift above 5.5 V DC, frying PLA, DRAM and SID.
| Pin | Function | Healthy Range |
| 1 (red) | +5 V DC | 4.95 – 5.20 V |
| 2 (white) | GND | 0 V |
| 6 (yellow) | 9 VAC @ 1 A | 9.0 – 11.0 V rms |
Measure with a multimeter before every session. Safe replacements: modern switch-mode “C64RMK2”, Ray Carlsen’s CR adapter, or over-voltage-protected DIY bricks.
Capacitor Health
C-64 boards generally fare better than Amigas, but filter cans in the RF modulator and 5 V/12 V regulators dry out. Early long boards: replace the 1000 µF / 16 V +5 V filter, 470 µF / 25 V +12 V, and the two 220 µF caps in the cassette/9 VAC rectifier path. Short board 250469-05 uses SMD tantalums—rarely fail, but the modulator still contains 22 µF / 16 V electrolytics. See Commodore 64 Capacitor Replacement Guide for more detailed replacement information.
Known Failure-Prone ICs
| IC | Part # | Typical Symptom | Quick Test / Hint |
| PLA | 906114-01 251064-01 |
Black screen, random colors, crash on cartridge | Replace with GAL-based PLAnkton or EPROM “PLA20V8” |
| SID | 6581 / 8580 | No sound, stuck keys, overheating | Touch pin 28 audio-out—hear hum? Swap with known good SID |
| VIC-II | 6567/6569 / 8565 | Black screen, jail-bars, bad color, sparkle pixels | Check 12 V @ pin 13 (long board) |
| CIA #1 / #2 | 6526 | Dead keyboard / joystick / IEC, time -outs | Swap the two CIAs—fault moves? Easy socket test |
| DRAM | 4164 ×8 or 41464 ×2 | Random chars, “OUT OF MEMORY”, intermittent crash | Dead-test cart pinpoints bad bit |
📏 Voltage & Clock Test Points
| Node | Board Pad / IC Pin | Expected Reading |
| +5 V DC | 6510 pin 40 | 4.95 – 5.20 V |
| +12 V DC (long boards) | 7812 VR1 out or VIC pin 13 | 11.8 – 12.3 V |
| 9 VAC | User-port pin 10 vs 12 | 9–11 V rms (scope shows 50/60 Hz sine) |
| CPU φ2 clock | 6510 pin 2 | 985 kHz (PAL) / 1.022 MHz (NTSC) |
| Reset | 6510 pin 3 | Low ≤ 100 ms then High (+5 V) |
Essential Tools
- ESD wrist-strap & soft bristle brush
- Digital multimeter (check PSU every session)
- Solder station + flux & desolder braid (for PLA/SID sockets)
- Diagnostic cartridges: C-64 Dead Test 781220 & Diagnostic Rev. 586220
- Freeze spray or hot-air pencil for thermal fault hunts
- Test PSU – verify +5 V & 9 VAC before connecting computer.
- Inspect regulators 7805 / 7812 for cracked solder joints; re-flow if dull.
- Re-seat chips annually; apply DeoxIT to sockets.
- Add heat-sinks to VIC-II, SID, PLA (especially early ceramic packages).
- Clean cartridge & expansion edge-connectors with isopropyl + pink eraser.
- Replace RF modulator electrolytics if video shows shimmering border.
- Ventilation – leave 2 cm clearance above vents; consider modern transparent top-shell or fan for hot climates.
Quick-Fix Flowcharts
No Video / Black Screen
- Check PSU rails → OK?
- Feel PLA & VIC: burning hot = replace.
- Swap PLA → CPU / VIC → both CIAs → ROMs.
- Still black? probe φ2 clock & Reset; if missing, suspect 8701 clock generator or bad crystal.
Garbled Characters / Checkerboard
- Run Dead Test cart: code flashes DRAM bank; count flashes to identify bad 4164.
- If only colors wrong → replace 2114 color RAM.
- If only certain glyphs wrong → character ROM (901225-01) socket issue.
No Sound
- Confirm volume & cable → check SID pin 27 audio-out with scope; flat-line = dead SID.
- Audio present before modulator but silent on TV = RF modulator electrolytic or bad audio-mix resistor.
Keyboard / Joystick Dead
- Swap CIAs; if fixed, replace bad 6526.
- If row/column missing → inspect keyboard ribbon; repair broken trace with conductive ink.
