Macintosh LC 630 Capacitor Replacement Guide
Revision as of 21:52, 21 September 2026 by Josh (talk | contribs) (Verification drive: flag unverified component data pending check against a primary source)
Replacing electrolytic capacitors (recapping) in your Macintosh LC 630 and related models is essential for long-term reliability. This guide covers the LC 630, Quadra 630, Performa 630 series (630, 631, 635, 636, 637, 638), and LC 630 DOS Compatible. All variants share the same logic board (820-0524) with identical capacitor specifications.
Overview
The LC 630 series uses surface-mount electrolytic capacitors that are prone to leakage after 25+ years. Unlike compact Macs, the LC 630 has no analog board—the power supply is a separate sealed unit. This guide focuses on the logic board capacitors.
The LC 630 logic board contains 9 SMD electrolytic capacitors:
  • 3× 100µF 6.3V
  • 6× 47µF 16V
Capacitor Inspection
Before recapping, inspect the board for signs of failure:
  • Bulging Tops – Capacitors with domed or swollen tops have failed internally. Replace immediately.
  • Leaking Electrolyte – Brown or amber residue around capacitor bases indicates leakage. The electrolyte is corrosive and damages traces.
  • Corrosion or PCB Staining – Discoloration of the PCB surface near capacitors suggests electrolyte has spread. Clean thoroughly before recapping.
  • Crystalline Deposits – White or gray crystals indicate advanced corrosion requiring trace repair.
Macintosh LC 630 Capacitor List
Logic Board Capacitors
Logic Board Capacitor Specifications (820-0524)
Reference Capacitance Voltage Quantity Location/Notes
C1, C2, C3 100µF 6.3V 3 Power filtering section
C4, C5, C6, C7, C8, C9 47µF 16V 6 Various filtering locations
Total: 9 capacitors
Replacement Capacitor Recommendations
For SMD replacements, use high-quality Japanese capacitors:
Recommended Replacement Capacitors
Original Value Replacement Rating Recommended Brands
100µF 6.3V 100µF 10V or 16V Nichicon, Panasonic, Rubycon
47µF 16V 47µF 25V Nichicon, Panasonic, Rubycon
Notes:
  • Use higher voltage rating replacements where available (improves reliability)
  • Match or exceed original capacitance
  • SMD packages preferred for proper fit
  • Through-hole can work with careful positioning
Power Supply Capacitors
The LC 630 power supply is a separate sealed unit. If exhibiting issues:
  • Power supply recapping requires opening the PSU enclosure
  • Contains high-voltage capacitors—discharge before servicing
  • Consider professional service or replacement unit
  • Symptoms of PSU cap failure: no power, clicking, or unstable voltages
Power supply capacitor specifications vary by PSU variant and are not covered in this logic board guide.
Preparation
  1. Disconnect power and all cables from the system
  2. Open rear panel by releasing the latch
  3. Slide out motherboard drawer for full access
  4. Remove logic board if needed for better access
  5. Photograph the board for reference before starting
  6. Document polarity of each capacitor before removal
Tools Required
  • Temperature-controlled soldering iron (recommended: 350–380°C)
  • Fine soldering tip (chisel or conical)
  • Desoldering braid or solder wick
  • Fine solder (0.5–0.6mm leaded or lead-free)
  • Isopropyl alcohol (90%+ concentration)
  • ESD-safe brush (soft bristles)
  • Multimeter with continuity function
  • Magnification (loupe or microscope helpful)
  • ESD wrist strap and mat
  • Flux (no-clean or water-soluble)
Removal Process
  1. Add fresh solder to capacitor leads (helps heat transfer)
  2. Heat one side while gently pushing capacitor
  3. Alternate sides until capacitor releases
  4. Remove residual solder with desoldering braid
  5. Clean pads with isopropyl alcohol
  6. Inspect pads for lifted traces or damage
Alternative method (hot air):
  • Use hot air station at 350–400°C
  • Heat both pads simultaneously
  • Lift capacitor with tweezers when solder flows
  • Clean area immediately
Cleaning Electrolyte Damage
If electrolyte leakage is present:
  1. Remove all leaked electrolyte with cotton swabs and isopropyl alcohol
  2. Use white vinegar to neutralize remaining electrolyte (alkaline residue)
  3. Rinse with isopropyl alcohol to remove vinegar
  4. Inspect traces under magnification
  5. Test continuity of traces near affected areas
  6. Repair damaged traces with wire jumpers if necessary
  7. Allow board to dry completely before proceeding
Installation Process
  1. Verify polarity – Negative stripe on capacitor aligns with board marking
  2. Apply flux to pads
  3. Tin one pad with small amount of solder
  4. Position capacitor and tack one side
  5. Verify alignment before soldering second pad
  6. Solder second pad cleanly
  7. Reheat first pad for good joint if needed
  8. Inspect joints under magnification
  9. Clean flux residue with isopropyl alcohol
Polarity notes:
  • SMD electrolytic capacitors have a stripe indicating negative terminal
  • Board silkscreen typically shows positive terminal or negative bar
  • Double-check against original photos
  • Reversed polarity will damage capacitor and board
Post-Installation Checks
  1. Visual inspection – All joints should be smooth and shiny
  2. Continuity test – Verify no shorts between adjacent traces
  3. Capacitance test – Optional: verify each capacitor with ESR meter
  4. Power-on test – Reconnect power and test system
Voltage Adjustment After Recap
After recapping, verify power supply voltages:
  • +5V rail: 4.85V – 5.15V
  • +12V rail: 11.9V – 12.7V
Measure at logic board power connector with system running. Adjust PSU potentiometer if out of specification.
DOS Compatibility Card
If your system includes a DOS Compatibility Card:
The DOS card is a two-board assembly installed in the CPU socket and PDS slot. It may contain additional capacitors:
  • Inspect both PCBs of the DOS card
  • Card age is similar to logic board (same failure risk)
  • Card capacitors (if present) may require replacement
  • Exercise caution removing/reinstalling dual-board assembly
Through-Hole Conversion
If SMD capacitors are unavailable, through-hole capacitors can be used:
  1. Drill small holes in pads (0.8mm)
  2. Insert through-hole capacitor leads
  3. Solder from bottom of board
  4. Trim leads flush
  5. Verify no shorts with multimeter
Considerations:
  • Through-hole caps are taller—verify clearance
  • May interfere with motherboard drawer mechanism
  • Radial leads preferred over axial
  • Same capacitance and voltage requirements apply
Common Mistakes to Avoid
  • Wrong polarity – Will damage capacitor immediately
  • Too much heat – Lifts pads and traces
  • Cold solder joints – Lead to intermittent failures
  • Skipping cleaning – Residual electrolyte continues damage
  • Wrong capacitor values – System may not function correctly
  • Forgetting to test – Shorts can cause immediate damage on power-up
Sourcing Capacitors
Quality capacitor sources:
  • DigiKey, Mouser, Newark (new stock)
  • Console5 (pre-made kits for vintage systems)
  • eBay (verify authentic Japanese brands)
Avoid:
  • Unknown brand Chinese capacitors
  • Suspiciously cheap "Japanese" capacitors
  • Used or salvaged capacitors
When to Seek Professional Help
Consider professional repair if:
  • You lack SMD soldering experience
  • Significant trace damage is present
  • Board has extensive corrosion
  • Multiple component failures beyond capacitors
  • DOS Compatibility Card requires service
