Macintosh Classic Memory Upgrade Guide
Revision as of 18:14, 23 September 2026 by Josh (talk | contribs) (Sourced to Apple Classic/Classic II/Performa 200 Service Source: fixed broken wikitable markup, SIMM speed 120ns or faster (Apple), Apple eight-chip rule cited, jumper positions cited, refs and reflist)
The Macintosh Classic has 1 MB of RAM soldered to the logic board and no SIMM sockets of its own. All expansion goes through Apple's optional memory expansion board, which carries a further 1 MB of soldered RAM plus one pair of SIMM connectors. The maximum is 4 MB.[1]
Memory specifications
  • On board: 1 MB soldered, not removable.[1]
  • Expansion board: 1 MB soldered plus two 30-pin SIMM sockets and a configuration jumper.[1]
  • SIMM speed: 120 ns or faster, in Apple's words "You must use 120-ns (or faster) SIMMs".[1]
  • SIMM sizes: 256 KB or 1 MB, fitted as a matched pair.[1]
  • Eight-chip modules only. Apple states that 1 MB SIMMs with fewer than eight chips will not work in the Macintosh Classic.[1]
  • Maximum: 4 MB, expandable no further.[1]
Supported configurations
Macintosh Classic RAM configurations (Apple)
Total RAM Expansion board SIMMs Jumper
1 MB not fitted — —
2 MB fitted none "No SIMMs" position
2.5 MB fitted 2 × 256 KB "With SIMMs" position
4 MB fitted 2 × 1 MB "With SIMMs" position
Macintosh Classic memory expansion board
Tools
  • Long T15 Torx screwdriver (at least 150 mm / 6 in) — two of the case screws sit deep in the handle recess
  • Case separator or plastic spudger
  • Anti-static wriststrap
  • A matched pair of 30-pin SIMMs
See Recommended Tools.
Procedure
1. Prepare. Power off, unplug, work on a grounded surface.
2. Open the case. The Classic contains a CRT. Read CRT Discharge Procedure first, discharge the CRT before disconnecting anything, and do not fit a grounding wriststrap until after it has been discharged.[1]
3. Free the expansion board. Apple's instruction is to slide the memory expansion board upwards to release it from the logic board and the chassis.[1]
4. Fit the SIMMs into the pair of sockets on the expansion board, as a matched pair, with the notch matched to the socket keying.
5. Set the jumper — "No SIMMs" if the board is being installed bare, "With SIMMs" if a pair has been fitted.[1]
6. Refit the expansion board onto the logic board and reassemble.
7. Verify the total in "About This Macintosh".
Common problems
Symptom Likely cause Action
Sad Mac, or Sad Mac with black vertical lines and a screeching sound Jumper set wrongly for the SIMMs actually fitted Apple's own chart puts the jumper first: verify "SIMMs" / "No SIMMs"[1]
Sad Mac on a 4 MB machine 1 MB SIMMs with fewer than eight chips Fit eight-chip modules; Apple states fewer-chip 1 MB SIMMs will not work[1]
Memory figure not as expected Mismatched pair, or a module not fully seated Use two identical modules, reseat both
Random instability A failing module Substitute known-good modules
Why 4 MB is the ceiling
The Classic is a 24-bit-addressing 68000 machine with a fixed memory decode and a ROM that probes only as far as its supported maximum; there is no hardware modification that lifts the limit. If you need more than 4 MB in a compact Macintosh, the Macintosh SE/30 is the machine that provides it.
  1. ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 Apple Computer, Macintosh Classic/Classic II/Performa 200 Service Source — Specifications (Memory), Upgrades (Memory Expansion Board, Memory Upgrade) and Troubleshooting chapters. Hosted on this wiki: File:Classic ii.performa 200.pdf.
