SuperCPU and Turbo Accelerators
Revision as of 22:25, 23 September 2026 by Josh (talk | contribs) (Rewrite: remove the fabricated Dhrystone/PI benchmark table and the HD6120 glue-logic claim (the SuperCPU uses an Altera CPLD in both versions); add the real CMD specification and register map; note the Chameleon is EOL and cite the Commodore 64 Ultimate's Artix-7 and launch pricing)
A turbo accelerator replaces or bypasses the Commodore 64's 1 MHz 6510 with a faster processor while keeping the rest of the machine working. The best known is Creative Micro Designs' SuperCPU.
SuperCPU and turbo accelerators for the Commodore 64/128
Caption The Creative Micro Designs SuperCPU
Type Cartridge-port CPU accelerators
Designer Unknown
Manufacturer Creative Micro Designs and others
First released Unknown
Latest revision —
Operating voltage —
Layers / PCB —
Compatibility Commodore 64, 64C, SX-64 and Commodore 128 in 64 mode
Features —
Model No. —
This page carries only figures that can be checked against a maker's documentation or a community reference that mirrors it.[1][2]
The SuperCPU
CMD SuperCPU
Released 1996
Discontinued 2001
Release price US$199
Processor WDC 65C816S
Clock 20 MHz
Opcodes Documented 6510 opcodes only
Support chip Altera CPLD
On-card RAM 128 KB SRAM
ROM 64 KB SuperCPU DOS
Expansion Cartridge pass-through, SuperRAM Card (1–16 MB), "Rocket Socket" header
Installation External, cartridge port
[1]
v1 against v2. The first SuperCPU was released with an Altera CPLD too small to hold all the compatibility logic CMD wanted, and it was buggy as a result. The second version fitted a higher-capacity CPLD and generally solved the problem. If you are buying one, that is the difference that matters.[1]
Register map
The SuperCPU is controlled and detected through registers in the $D0xx space. This matters beyond the SuperCPU itself, because later hardware imitates it.[1]
SuperCPU registers
Address Purpose
$D074 (53364) VIC bank 2 / GEOS optimisation (mirror $8000–$BFFF)
$D075 (53365) VIC bank 1 optimisation (mirror $4000–$7FFF)
$D076 (53366) BASIC optimisation (mirror $0400–$07FF)
$D077 (53367) No optimisation — mirror all memory (v1 default)
$D07A (53370) Software speed select — normal
$D07B (53371) Software speed select — turbo (20 MHz)
$D07E / $D07F Hardware register enable / disable
$D0B0 (53424) SuperCPU mode detect register
$D0B3 (53427) Enhanced optimisation register (v2 only)
$D0B4 (53428) Optimisation mode flags (v1 and v2)
$D0B5 (53429) JiffyDOS switch flag / CPU speed switch flag
$D0B6 (53430) Processor emulation mode flag (v1 only)
$D0B8 (53432) Software speed flag / master speed flag
$D0BC (53436) DOS extension mode flag / RAMLink hardware registers flag
$D200–$D2FF System RAM
$D300–$D3FF User RAM, available to user programs
The SuperCPU's afterlife
The register interface outlived the hardware. The Ultimate 64 implements SuperCPU-compatible software speed-select registers at $D07A and $D07B and a SuperCPU detect register at $D0BC, so software written for a SuperCPU can find and drive its turbo.[2]
The U64 is also worth reading for one lesson that applies to every accelerator: on that board, disabling badline timing gives the CPU more slots but does not change the BA signal at the cartridge port, so anything reaching an external device — or a real SID in a socket — is still throttled by badlines. Accelerating the processor never accelerates the bus it has to share.[2]
Other accelerators
The following are recorded as C64/C128 CPU accelerators:[1]
  • Turbo Process
  • Turbo Master CPU
  • Flash 8
  • Turbo Chameleon 64
  • F7 Turbo Card
  • Turbo Demo Card (TDC)
This wiki has not verified the processor, clock, RAM fit or release date of any of these against its maker's documentation, and does not state them. Specification tables for these machines circulate widely and contradict each other; several published comparisons attribute one product's parts to another.
The Turbo Chameleon 64 is end-of-life at Individual Computers — its wiki page is filed under their EOL category — so do not treat it as a current purchase.[3]
The modern route to a fast 64
If the object is speed rather than period hardware, the practical options today are FPGA boards rather than cartridges:
  • Ultimate 64 and Ultimate 64 Elite-II — up to 48 MHz and 64 MHz respectively, with SuperCPU-compatible control registers.[2]
  • Commodore 64 Ultimate — the board Commodore now sells, built on an AMD Xilinx Artix-7 FPGA with 128 MB of DDR2 and 16 MB of flash. Pre-orders opened at US$299.99 for the base machine, with a Starlight edition at $349 and a Founders edition at $499, and shipping was announced for October 2025. Ultimate64.com states that Commodore has taken over sales of their version of the Elite-II board.[4][5]
Power
Any cartridge-port accelerator adds load to the C64's +5 V rail, which the original Commodore supplies were never generous about. If you are running one on a period brick, read Commodore 64 Power-Supply Protector (C64 Saver) first — an ageing supply that has begun to drift high will take the accelerator with it.
This wiki has no measured current figure for any accelerator on this page. Measure yours rather than trusting a published one.
  1. ↑ 1.0 1.1 1.2 1.3 1.4 SuperCPU, C64-Wiki, https://www.c64-wiki.com/wiki/SuperCPU . Community reference. Source for the manufacturer, release and discontinuation years, release price, processor, clock, support-chip type, on-card RAM and ROM, expansion options, the v1-to-v2 CPLD change, and the SuperCPU register map at $D074–$D0BC with system and user RAM at $D200–$D3FF. It also lists the other accelerators named below.
  2. ↑ 2.0 2.1 2.2 2.3 Gideon Zweijtzer, Ultimate Documentation — Turbo mode settings, https://1541u-documentation.readthedocs.io/ . Source for the Ultimate 64's SuperCPU-compatible registers at $D07A, $D07B and $D0BC, for the 48 MHz and 64 MHz subsystem clocks and CPU speed indices, and for the statement that disabling badline timing does not affect the BA signal at the cartridge port.
  3. ↑ Individual Computers, Chameleon, https://wiki.icomp.de/wiki/Chameleon . Filed under the manufacturer's EOL category.
  4. ↑ Announcement coverage of the Commodore 64 Ultimate, e.g. Tom's Hardware, https://www.tomshardware.com/video-games/retro-gaming/the-commodore-64-ultimate-computer-is-the-companys-first-hardware-release-in-over-30-years-pre-orders-start-at-usd299 . Source for the Artix-7 FPGA, 128 MB DDR2, 16 MB flash, the three editions and their launch prices, and the announced October 2025 shipping date. Prices are launch figures, not current ones.
  5. ↑ Ultimate Products B.V., https://ultimate64.com/ — front-page notice that the Ultimate 64 Elite-II black short boards are sold out and that Commodore has taken over the sales of their version of this board. Read September 2026.
