Centris 650/Quadra 650 Service Source
Revision as of 07:42, 25 September 2026 by Josh (talk | contribs) (P4: turn document holder into a real documentation page (verification drive))
The Centris 650/Quadra 650 volume of Apple's Service Source is an 81-page service manual covering both machines, which share a chassis and differ mainly in processor speed. The PDF was distilled on 21 October 1995.
Specifications as printed
Item Centris 650 Quadra 650
CPU Motorola 68040 at 25 MHz, built-in MMU Motorola 68040 at 33 MHz, built-in MMU
Coprocessor optional FPU
Addressing 32-bit internal registers, 32-bit address bus, 32-bit data bus
RAM 4 or 8 MB, expandable to 132 MB (72-pin SIMM)
ROM 1 MB
PRAM 256 bytes non-volatile
VRAM 512K, expandable to 1 MB
Clock/calendar CMOS custom chip with a long-life lithium battery
Line voltage 100-240 VAC, 50-60 Hz
Power 112 W maximum, not including display power
Size 6.0 in (152 mm) H x 13.0 in (330 mm) W x 16.5 in (419 mm) D
Weight varies with the internal devices fitted
The 112 W maximum excluding the display figure is the one to use when judging whether a supply is adequate for an added drive or card.
Contents
  • Basics - Overview (pdf p. 3)
  • Specifications - Processors, Memory, Disk Storage, I/O Interfaces, I/O Devices, Sound and Video, Electrical, Physical, Environmental (pdf pp. 5-15)
  • Troubleshooting - General; symptom charts for Error Chords, System, Video, Floppy Drive, Hard Drive, CD-ROM Drive and Peripheral (pdf pp. 17-30)
  • Take Apart - Top Cover, Power Supply, Drive Chassis, Floppy Drive, Hard Drive, CD-ROM Drive, Speaker, Logic Board (pdf pp. 32-58)
  • Additional Procedures - Battery Verification, Battery Replacement, Reset/Interrupt (pdf pp. 60-66)
  • Upgrades - Expansion Cards, CD-ROM Drive Upgrade, Power Macintosh Card, Power Macintosh Upgrade (pdf pp. 68-79)
  • Exploded View (pdf pp. 80-81)
The Error Chords symptom chart is worth knowing about: these machines signal startup faults by sound as well as by the screen, and Apple's chart maps the chords to causes.
Module-level. No parts list, no schematic, no component values and no capacitor table - any capacitor list for this machine elsewhere is not sourced from this document. No supply-rail voltages or tolerances are printed, and no fuse rating.
Pages that cite this document
Download: Quadra.centris 650.pdf
