Macintosh Centris 650 Capacitor Replacement Guide
Capacitor diagnosis and replacement for the Macintosh Centris 650 and the Macintosh Quadra 650, which Apple services together in one Service Source volume.[1] On this machine the logic board is not the recap job; the power supply is.
Safety
[edit | edit source]The power supply is a mains-rectified switching supply. Its primary side is at mains potential and the two large reservoir capacitors hold a lethal charge after the machine is unplugged.
- Switch off and unplug the mains lead.
- Discharge each large reservoir capacitor through a 1 kΩ, 5 W resistor across its terminals, then confirm with a meter that it reads near zero before touching anything.
- Do not probe a powered primary side without an isolation transformer.
The system unit has no CRT. Apple's displays contain their own tube and supply; see CRT Discharge Procedure when working on one.
The supply accepts 100–240 V AC at 50–60 Hz with no voltage selector, and Apple rates the machine at 112 W maximum, not including display power.[2]
What fails
[edit | edit source]- The logic board has no surface-mount aluminium electrolytics. Retro Viator found none on a Quadra 650 logic board, only tantalums, while the supply did contain electrolytics and had a patch scorched by a hot resistor.[3] A TinkerDifferent member says the Centris 650, Quadra 650 and Quadra 800 boards all came with tantalums from the factory.[4] Check your own board.
- Solid tantalums most often fail short. A shorted filter tantalum pulls its rail down, and the supply shuts down or its fuse blows.[5] Look for a cracked or scorched moulded body.
- The power supply does use aluminium electrolytics.[6]
Apple published no capacitor values for this machine. The Service Source has no capacitance, voltage-rating or designator data; power faults in its symptom charts end at "Replace power supply".[7]
Identifying the power supply
[edit | edit source]Apple's service part number for the supply is 661-0758.[8] Apple's developer note says it is the same physical size as the Quadra 700's supply but delivers up to 112 W.[9] Apple Rescue of Denver lists the same supply as Apple 614-0009 (service part 661-0758), 112 W, made by Delta (SMP-120EB) or ASTEC (AA16870), and fitted to the Centris and Quadra 650, IIvi, IIvx, Performa 600 and Power Macintosh 7100.[10][11] Two makers means two different capacitor lists: open the supply and read the maker and board markings before ordering.
Power supply capacitors
[edit | edit source]Console5's community list, read from a Delta SMP-120EB supply, has fifteen electrolytics. It has no list for the ASTEC AA16870 version; read the markings on that one.[6]
| Designator | Value |
| C1, C2 | 470 µF 200 V (680 µF on some revisions) |
| C103 | 2200 µF 10 V |
| C104, C153, C154 | 1000 µF 16 V |
| C252 | 470 µF 25 V |
| C253 | 470 µF 16 V |
| C302, C522, C612, C684 | 10 µF 50 V |
| C505 | 2.2 µF 50 V |
| C551 | 1000 µF 35 V |
| C807 | 470 µF 35 V |
The 200 V reservoir pair
[edit | edit source]C1 and C2 are 200 V parts on a supply that accepts 240 V mains, which rectifies to about 340 V DC; a single 200 V capacitor cannot hold that, so the two work as a series pair across the rectified bus. Replace both together with matching parts of the same value and at least the same voltage rating, and never fit a single 200 V capacitor in place of the pair.
Logic board capacitors
[edit | edit source]There is no routine work to do here. If a tantalum has failed:
- Find it: look for a cracked, split or scorched body, and for a rail that measures as a short to ground with the supply disconnected.
- Note its orientation. The bar on a tantalum marks the positive end, the opposite of an aluminium electrolytic's stripe.
- Remove it with hot air, or by alternating a fine iron between the two terminations.
- Fit a replacement of the same capacitance, derated by 50 %: a part on the 5 V rail wants a 10 V or higher rating, and one on 12 V wants 25 V.[5] Some restorers use solid polymer electrolytics instead.[5]
For the signs of failure in general see Capacitor Failure Symptoms.
Replacement procedure
[edit | edit source]- Discharge the supply as above and confirm with a meter.
- Photograph each board before removing anything. The supply is built from stacked sub-boards.
- Desolder with a temperature-controlled iron and a pump or wick. The reservoir capacitors sit on heavy copper and need more heat.
- Clean the pads with isopropyl alcohol.
- Fit the replacements the right way round; the stripe on an aluminium electrolytic marks the negative lead.
- Trim leads, then check for bridges and stray clippings.
- Test the supply on a dummy load before connecting it to the logic board.
Use 105 °C, low-ESR parts suited to switching supplies. See Recommended Tools.
Battery
[edit | edit source]Apple's check: set a voltmeter to the 10 V DC range, measure the battery in its holder (positive end marked "+" on the logic board), and replace it if it reads below 3.2 V. The holder has a latched cover; prise the latch with a small flat-blade screwdriver and lift the battery out.[12] If it has leaked, see Battery Explosion, Capacitor or Corrosion Damage.
Apple's symptom charts and the power supply
[edit | edit source]Apple's charts include "Replace power supply" among the cures for:[7]
- no power, black screen, fan not running and LED off;
- clicking, chirping or thumping (power supply first, then logic board);
- intermittent shutdown, after checking the air vents (thermal protection can shut the machine down for 30 to 40 minutes), the power cord and the battery;
- intermittent crashes or lock-ups, after software, SCSI and SIMM checks;
- a dark screen with no sound and no drive activity while the fan runs and the LED is lit, after removing peripherals and NuBus cards and trying DRAM and VRAM;
- no CD-ROM icon on the desktop.
[edit | edit source]- Macintosh Centris 650
- Macintosh Centris 650 Troubleshooting
- Macintosh Centris 650 General Maintenance
- Macintosh Quadra 650
- Capacitor Failure Symptoms
- Recommended Tools
[edit | edit source]- ↑ Apple Computer, Centris 650/Quadra 650 Service Source. Hosted as File:Quadra.centris_650.pdf; see Centris 650/Quadra 650 Service Source.
- ↑ Centris 650/Quadra 650 Service Source, Specifications, Electrical, p. 9 (PDF p. 13).
- ↑ Apple Macintosh Quadra 650, Retro Viator, 2021-09-02—link(accessed 2026-10-12) Source for the tantalum-only Quadra 650 logic board, the electrolytics in the supply and the scorched resistor.
- ↑ TinkerDifferent forum thread "A 'NEW' quadra 800?", July 2022: -SE40- finds "all tantalum caps" on a Quadra 800 logic board; Volvo242GT replies that the Centris/Quadra 650 and Quadra 800 boards came with tantalums from the factory, and the Power Macintosh 7100 boards with electrolytics. Secondary source.
- ↑ 5.0 5.1 5.2 TinkerDifferent forum thread "Tantalum vs Electrolytic. Can I just always use tantalum?", January 2025. Secondary source for the 50 % voltage derating of solid tantalums and their short-circuit failure mode.
- ↑ 6.0 6.1 6.2 Console5 Tech Wiki, "Delta SMP-120EB", capacitor list (page revision 7206, retrieved 2026-10-01). Secondary source; Console5 sells the parts as a kit.
- ↑ 7.0 7.1 Centris 650/Quadra 650 Service Source, Troubleshooting, pp. 1-14 (PDF pp. 17-30).
- ↑ Centris 650/Quadra 650 Service Source, Exploded View (PDF p. 81).
- ↑ Apple Computer, Developer Note: Macintosh Centris 610, Macintosh Centris 650, and Macintosh Quadra 800 Computers (1993), "Power Supplies", p. 9 (PDF p. 21). Hosted as File:Macintosh Centris 610 Centris 650 and Quadra 800 Developer Note.pdf.
- ↑ Quadra 650, IIvi, IIvx, Power Mac 7100, Performa 600 – Power Supply, Apple Rescue of Denver—link(accessed 2026-09-30) "Apple 614-0009, 661-0758. 112w. ... Delta SMP-120EB, Astec AA16870."
- ↑ 68kMLA forum thread "Compact Desktop Power Supply Capacitor Lists (by make and model)". Secondary source for the 614-0009 makers and models.
- ↑ Centris 650/Quadra 650 Service Source, Additional Procedures, Battery Verification and Battery Replacement, pp. 1-5 (PDF pp. 60-64).
