Power Macintosh 6100
The Power Macintosh 6100 is a desktop Macintosh computer based on the PDM (Piltdown Man) architecture, released on March 14, 1994.[1] It was one of the first Power Macintosh computers, featuring a PowerPC 601 processor running at 60 MHz.
| Power Macintosh 6100 | |
| Type | Personal Computer |
| Released | March 14, 1994 |
| Discontinued | January 3, 1995 |
| Intro price | US$1,820 – $2,350 |
| CPU | PowerPC 601 @ 60 MHz |
| Memory | 8 MB soldered (16 MB configuration adds two 4 MB SIMMs); expandable to 72 MB |
| Storage | 160 MB or 250 MB SCSI hard drive |
| Display | External, via HDI-45 DRAM-based video port (no VRAM fitted) |
| Sound | — |
| OS / Firmware | System 7.1.2 – Mac OS 9.1 |
| Predecessor | Macintosh Centris 610 |
| Successor | Power Macintosh 6200 |
| Codename | PDM (Piltdown Man) |
| Model no. | M1596 |
The consumer version is the Performa 6110CD and related models, and the server version is the Workgroup Server 6150/60.
Hardware Overview
Processor and Memory
The Power Macintosh 6100 uses a PowerPC 601 processor at 60 MHz with a 30 MHz system bus. It has a 32-bit processor with a 64-bit data path. The system includes 32K of L1 cache and supports optional 256K L2 cache.
RAM uses 72-pin SIMMs at 80 ns minimum speed. The system has 8 MB of onboard RAM and 2 SIMM slots (SIMMs must be installed in matching pairs). Maximum RAM is officially 72 MB, but can reach 136 MB with two 64 MB SIMMs plus the onboard memory. 640K of system RAM is dedicated to video function.
The system includes a 160 MB or 250 MB internal SCSI hard drive. A 2X CD-ROM drive is optional (standard in some configurations). A 1.44 MB floppy drive is standard.
Display
The system supports a single external display at 512×394 or 640×480 at 16-bit, or 832×624 at 8-bit. A second display can be added with an expansion video card.
Expansion
The system has a single 601 PDS or 7" NuBus slot (NuBus available with PDS-to-NuBus adapter M1402LL/A).
Networking
AAUI-15 Ethernet is standard. Two Geoport serial ports (printer and modem) are included.
Case Design
The 6100 uses the low-profile Macintosh Centris 610 case form factor.
For detailed maintenance practices, refer to the General Maintenance page (shared hardware with Performa 6100 series).
For troubleshooting information, see the Troubleshooting page.
For capacitor replacement guidelines, see the Capacitor Replacement Guide.
Service documentation
Apple's own service manual is hosted here as Power Macintosh 6100/ WS 6150 Service Source. It gives the 6100/60 and WS 6150 as a PowerPC 601 at 60 MHz with built-in MMU and FPU and a 32K on-chip cache, requiring system software 7.1.2 or later; an A/C line input of 100–240 VAC RMS single phase, automatically configured, at 50–60 Hz; 132 W maximum continuous input, 201 W peak excluding the monitor; a power supply DC output of 86 W continuous; and the PRAM cell threshold as replace below 3.2 V.[2]
Its Basics chapter prints the HDI-45 pinout along with the rear panel and logic board connector maps — the HDI-45 pinout appears in only three Apple volumes (the 6100, 7100 and 8100) and is how you work out what an AV monitor cable is actually carrying.[2]
- Macintosh Performa 6100
- Macintosh Performa 6110CD
- Power Macintosh 6100 DOS Compatible
- Power Macintosh 7100
- Macintosh Centris 610
Apple service data
Apple's own figures, from the Power Macintosh 6100/WS 6150 Service Source volume hosted on this wiki.[3]
| Item | Apple's figure |
| Processor | PowerPC 601 at 60 MHz (6100/60, 6150) or 66 MHz (6100/66, 6150/66), with built-in MMU and FPU and 32K of on-chip cache. The 60 MHz machines need system software 7.1.2 or later, the 66 MHz machines 7.5 or later |
| RAM | 8 MB soldered on the board; expandable to 72 MB in two SIMM sockets. SIMMs must go in as a pair of the same size and speed, 80 ns or faster, 72-pin, and must be noncomposite. The 16 MB configuration is the 8 MB soldered plus two 4 MB SIMMs |
| ROM | 4 MB, installed on a SIMM socket |
| VRAM | None. Video on the 6100/60, 6100/66, 6150 and 6150/66 is DRAM-based off the logic board; only the Power Macintosh AV card carries VRAM, 2 MB of it |
| Level 2 cache | Optional 256K on the 6100/60 and 6150; standard 256K on the 6100/66 |
| Video port | One HDI-45 DRAM-based video port for direct connection to Apple AudioVision monitors. With the included HDI-45 to DB-15 adapter it drives 12-, 13-, 14-, 15-inch portrait, 16- and 17-inch monitors. The AV card adds a DB-15 VRAM-based port good to 20- and 21-inch, plus one S-video/composite input and one output — only one monitor may be attached to the AV card at a time |
| Sound | 16-bit stereo in and out; sample rates 48, 44.1, 24 and 22.05 kHz; input/output line level 1 V peak to peak; signal-to-noise ratio 82 dB with no audible discrete tones; bandwidth 20 Hz–20 kHz (± 2 dB) at 44.1 kHz; THD+N less than 0.05% measured 20 Hz–20 kHz with a 1 V rms sine input |
| Serial | Two RS-232/RS-422 LocalTalk/GeoPort ports on mini DIN-9 connectors, backward compatible with mini DIN-8 |
| ADB | One ADB port, mini DIN-4; 500 mA maximum, three devices maximum |
| SCSI | One DB-25 port; up to six external devices, five when a CD-ROM is installed |
| Ethernet | One built-in AAUI-15 Ethernet port (printed "AUUI-15" in Apple's text) |
| Expansion | One internal slot taking either a processor-direct card or a 7-inch NuBus card with the appropriate adapter. On AV models that slot is already filled by the Power Macintosh AV card |
| Electrical | 100–240 VAC RMS single phase, automatically configured, 50–60 Hz. 132 W maximum continuous input, 201 W peak input, not including the monitor; 86 W continuous DC output |
| Case | Height 3.4 in. (85 mm), width 16.3 in. (415 mm), depth 15.6 in. (399 mm); 14.0 lb. (6.4 kg) |
| PRAM battery | Replace below 3.2 V. A lithium cell — neutralise any leakage with sodium bicarbonate, never vinegar |
There is no VRAM in a non-AV 6100, so "replace the VRAM" is not a repair step on this machine. A video fault on a plain 6100 is the logic board, the HDI-45 adapter or the monitor.[3]
On DOS Compatible models, Apple's symptom chart for a black screen at boot or errors in DOS is to remove the DOS Compatibility card and check that the jumper is in the "SX" position, over the two right-most prongs, before replacing anything.[3]
- ↑ Power Macintosh 6100/60 Specs, EveryMac.com—link(accessed 2026-02-10)
- ↑ 2.0 2.1 Apple Computer, Power Macintosh 6100/WS 6150, Service Source, 160 pp, PDF distilled 2 January 1996. Hosted here as the wiki page linked above (File:powermac_6100_series.pdf). Specifications chapter, and Additional Procedures — Battery Verification where a threshold is quoted.
- ↑ 3.0 3.1 3.2 Apple Computer, Power Macintosh 6100/WS 6150, Service Source. Hosted here as Power Macintosh 6100/ WS 6150 Service Source (File:Powermac_6100_series.pdf). Specifications, Take Apart and Additional Procedures — Battery Verification chapters.
