IBM PS2 Model 80 Schematics
Revision as of 21:58, 30 September 2026 by Josh (talk | contribs) (Title blocks checked; PAL sheets are connection diagrams, not PAL equations; remove uncited publisher history and 'IBM never published' claim; citing pages from backlinks)
The PS/2 Model 80 schematic set is twenty sheets of third-party logic drawings of the PS/2 Model 80 (8580) system board. Every title block reads "Maintenance Information Technologies", "PS/2 80", "90X9152-01" and "COPYRIGHT APPLIED FOR", with sheet number "n OF 20", revision 1 and date 10/16/91. The notice beside the title block says the content was sold for the buyer's unlimited use and must not be copied for republication or distribution outside the buyer's company, and gives no warranty of accuracy. The scan is image-only.
The drawings are of the board marked 90X9152-01. Check the number on the board in hand before relying on a designator.
Contents
Sheet Title Sheet Title
1 Bus 11 Real Time Clock
2 CPU 12 DMA I/F
3 Video I/F 13 Bus Connectors A
4 Memory 14 Bus Connectors B
5 Clocks 15 I/O Control
6 Interrupts 16 PALs
7 Serial I/O 17 Bus Signals
8 Printer I/O 18 PALs B
9 Keyboard I/F 19 PALs C
10 Disk I/F 20 PALs C (continued)
The drawings carry designators and values for the parts on each circuit. Sheet 11, for example, has the MC146818A real-time clock with its 32.768 kHz crystal and the LM386 audio amplifier with its capacitors. The four PAL sheets show the programmable logic devices as connection diagrams with their pin signals; they do not give the PAL equations.
There is no parts list, bill of materials, board layout or power-distribution sheet, so the set is not a complete capacitor list, and there are no PAL programming equations.
Pages that cite this document
Download: IBM PS2 Model 80 Schematics.pdf
