The Sinclair ZX Spectrum is an 8-bit home computer released by Sinclair Research Ltd in April 1982. It became a defining product of the early home computing era in the UK, known for its distinctive rubber keyboard and vibrant color graphics. The ZX Spectrum sold over 5 million units and is credited with popularizing home computing and gaming in the UK.
Sinclair ZX Spectrum – The Iconic Home Computer
ManufacturerSinclair Research Ltd
TypeHome computer
ReleasedApril 1982
Discontinued1992
Intro price£125 (1982)
CPUZilog Z80A @ 3.5 MHz
Memory16 KB, 48 KB, or 128 KB RAM (varies by model)
StorageExternal cassette tape (300 baud, EAR/MIC jacks)
Display256×192 pixels, 32 characters × 24 lines
SoundBeeper (monophonic)
Dimensions23 cm × 14 cm × 4 cm (9.1" × 5.5" × 1.6")
Weight1.1 kg (2.4 lb)
OS / FirmwareSinclair BASIC in ROM
PredecessorSinclair ZX81
SuccessorSinclair ZX Spectrum+
CodenameZX Spectrum
Model no.ZX Spectrum, ZX Spectrum+
🧠 Architecture
  • CPU – Zilog Z80A microprocessor clocked at 3.5 MHz.
  • ROM – 16 KB or 48 KB ROM containing Sinclair BASIC and system routines.
  • RAM – Available in 16 KB, 48 KB, or 128 KB configurations, expandable via external RAM packs.
  • Logic – Utilizes a combination of discrete logic and custom chips for video output and keyboard scanning.
Video generation
The ZX Spectrum generates video using a technique called "bit-banging," where the Z80 CPU directly controls the display output. The screen resolution is 256×192 pixels with a palette of 15 colors, plus black. The unique attribute system allows for color attributes to be assigned to 8×8 pixel blocks, resulting in colorful graphics but also potential color clash.
💾 Storage
Data is loaded and saved via a standard cassette tape interface operating at 300 baud. The average loading time for a game is approximately 3-5 minutes, depending on the size of the program.
🔌 I/O and Expansion
  • Edge connector (50-way) – provides access to the full Z80 bus, power, and video signals.
  • 9 V DC input – unregulated power supply.
  • Composite video output – for connecting to monitors and TVs.
Commercial peripherals included:
ZX Printer, joystick interfaces, and various RAM expansion packs.
🔧 Known PCB Revisions & Errata
ZX Spectrum PCB Revisions
Issue Visible Clues Key Fixes / Changes
Issue 1 (1982) Original board layout with no solder mask. • Early boards had issues with RAM stability; later revisions improved power distribution.
Issue 2 (1983) Added solder mask and improved trace routing. • Enhanced video output stability and reduced color clash issues.
🛠️ General Maintenance
Issue Cause Remedy
Flickering display Aging capacitors in the power supply Replace with high-quality electrolytic capacitors.
Unresponsive keys Worn rubber contacts on the keyboard Replace keyboard or use conductive paint to restore contact.
Loading errors Dirty cassette connectors Clean connectors and ensure proper tape alignment.
Regular maintenance, including cleaning the keyboard and ensuring proper connections, can help prolong the life of the ZX Spectrum.
📜 Schematic & PCB
The complete schematic for the ZX Spectrum is available for enthusiasts and repair technicians.
ZX Spectrum circuit diagram
Top view of the ZX Spectrum PCB
🔧 Common Modifications
  • RAM upgrade – Adding external RAM packs to increase memory capacity.
  • Composite video mod – For improved video output quality on modern displays.
  • Keyboard replacement – Upgrading to a full-travel keyboard for better typing experience.
  • Turbo mode modification – Overclocking the Z80 for faster performance (requires careful tuning).
🔢 ROM Keyword Map
Each key on the ZX Spectrum keyboard has multiple functions depending on the mode:
Example ZX Spectrum keyboard layer
Key F mode K mode L mode
P PRINT P (
R RETURN R )
G GOTO G >
🔗 Edge-Connector Pin-out
ZX Spectrum 50-way Expansion Bus (viewed from rear, component side up)
1 A15 Address bus MSB 26 D4 Data bit 4
2 A14 27 D5
3 A13 28 D6
4 A12 29 D7
5 A11 30 BUSACK Bus acknowledge
6 A10 31 BUSRQ Bus request
7 A9 32 WAIT Insert wait-states
8 A8 33 HALT
