Sinclair ZX80 Capacitor Replacement Guide
Revision as of 10:54, 4 May 2025 by Josh (talk | contribs) (Automated update by bot)
The Sinclair ZX80 is a pioneering home computer introduced in 1980 by Sinclair Research. Renowned for its compact design and affordability, the ZX80 helped popularize computing in the UK and beyond. Like all vintage electronics, the ZX80 can suffer from aging capacitors, which may cause instability, video issues, or outright failure. This guide details the identification and replacement of capacitors to restore reliable operation.
🧰 General Maintenance
Routine maintenance is vital for the longevity of the ZX80. Common issues include:
  • Electrolytic capacitor degradation leading to power instability or video faults.
  • Keyboard membrane wear causing unresponsive keys.
  • Oxidation of edge connectors and sockets.
  • Power supply aging, risking overvoltage or ripple.
Regular inspection and timely replacement of components—especially capacitors—can prevent damage and maintain system performance. For a full overview, see Sinclair ZX80 General Maintenance.
🔋 Capacitor Replacement Guide
Over time, the ZX80’s original capacitors may dry out or leak, affecting system stability. Replacing these components is a key preventative measure.
📋 Required Tools and Parts
  • Soldering iron (15–30 W) with fine tip
  • Solder sucker or desoldering braid
  • Leaded solder (60/40 or 63/37 Sn/Pb)
  • Small Phillips screwdriver
  • Isopropyl alcohol and brush for cleaning
  • Replacement capacitors (see table below)
🧾 ZX80 Capacitor List
Ref. Designator Value Voltage Type Function
C1 22 μF 16 V Electrolytic Power supply smoothing
C2 1 μF 16 V Electrolytic Video circuit coupling
C3 0.1 μF 50 V Ceramic Logic decoupling
C4 0.1 μF 50 V Ceramic Logic decoupling
C5 0.1 μF 50 V Ceramic Logic decoupling
C6 1 μF 16 V Electrolytic Video sync coupling
C7 22 μF 16 V Electrolytic 5V rail smoothing
  • Note:* Values and designators may vary slightly between early and late ZX80 revisions. Always verify against your unit’s PCB markings.
🛠️ Replacement Procedure
  1. Unplug the ZX80 and disconnect all cables.
  2. Remove the case screws (typically 4) and gently lift the top cover.
  3. Identify the capacitors to be replaced using the table above and PCB silkscreen.
  4. For each capacitor:
    1. Note polarity (for electrolytics: long lead = positive, short = negative).
    2. Heat each solder joint and remove the old capacitor using a solder sucker or braid.
    3. Clean the pads with isopropyl alcohol.
    4. Insert the new capacitor, matching polarity and value.
    5. Solder in place, trim excess leads.
  5. Inspect all work for solder bridges or cold joints.
  6. Reassemble the case and reconnect all cables.
  7. Power on and verify correct operation (stable video, no excessive heat, normal boot).
⚠️ Safety Notes
  • Always observe correct polarity for electrolytic capacitors.
  • Allow the system to cool before working if recently powered.
  • Dispose of old capacitors in accordance with local regulations.
📚 Technical Documentation
For detailed schematics and service information, consult:
