Commodore PET 2001
Revision as of 08:10, 12 May 2025 by Josh (talk | contribs)
The Commodore PET 2001 (Personal Electronic Transactor) was Commodore’s first all-in-one personal computer, introduced in 1977 during the formative years of the personal computing industry. Designed by Chuck Peddle and his team, the PET 2001 was one of the first consumer computers to offer a fully integrated package — combining a keyboard, monochrome CRT monitor, cassette tape drive, power supply, and motherboard into a single steel enclosure.
Commodore PET 2001
Commodore PET 2001 with built-in cassette drive
ManufacturerCommodore International
TypePersonal Computer
Released1977
Discontinued1982
Intro priceUS$795 (2001-4), US$995 (2001-8)
CPUMOS Technology 6502 @ 1 MHz
Memory4 KB – 8 KB (expandable to 32 KB)
StorageIntegrated cassette deck, external IEEE-488 floppy drive (optional)
Display9" monochrome built-in CRT (40x25 text)
SoundNone (no built-in audio hardware)
Dimensions19" H × 17" W × 19" D (approx.)
Weight~20 kg
OS / FirmwareCommodore BASIC 1.0 / 2.0
PredecessorNone
SuccessorCommodore PET 4000 Series
CodenamePET
Model no.2001-4, 2001-8
The initial PET 2001-4 model shipped with 4 KB of RAM, while the PET 2001-8 offered 8 KB of RAM. Later versions allowed expansion up to 32 KB. The system featured a built-in 9-inch monochrome CRT display with a resolution of 40 columns × 25 rows, driven by a simple character generator and video controller circuit.
At the core of the PET 2001 is the MOS Technology 6502, an 8-bit microprocessor running at 1 MHz. This same CPU would go on to power many other popular systems including the Apple II and Commodore 64. The CPU was tightly integrated with the machine’s system ROM and I/O through custom logic and support chips.
The ROM contained 8 KB of Commodore BASIC 1.0, developed by Microsoft, and additional routines for input/output operations and system startup. All ROM and RAM chips were socketed on the early PET boards, making upgrades and repairs relatively straightforward.
Storage and I/O
Storage on the PET 2001 was provided by an integrated Datassette unit — a Commodore-branded cassette tape drive that used compact audio cassettes for digital storage. While slow and prone to alignment issues, it was far cheaper than floppy disk alternatives at the time.
For I/O, the system included:
  • A built-in IEEE-488 (GPIB) parallel interface — an uncommon but high-speed bus primarily used for connecting disk drives and printers.
  • A standard PET edge connector expansion port, allowing hardware add-ons.
  • Audio output via a simple piezoelectric speaker, typically used for beeps and tones.
Video Hardware
The video system was entirely character-based, using a 1 KB video RAM buffer mapped to screen memory. Each character was represented by an 8×8-pixel bitmap from a fixed character ROM, providing a consistent and readable text output. The 40-column display became standard in early PETs, though later models introduced an 80-column mode for business applications.
Over decades of operation, PET 2001 systems are prone to failures caused by aging electrolytic capacitors, worn-out ROM sockets, and stuck cassette mechanisms. Routine cleaning, contact reseating, and power supply testing are essential.
For detailed cleaning, CRT safety, keyboard servicing, and PRAM battery handling (where present), see the Commodore PET 2001 General Maintenance Guide.
PCB Schematics & Service Guide
The PET 2001 logic board layout is relatively simple, with discrete TTL logic, a MOS 6502 CPU, and rows of DRAM chips depending on the model.
Motherboard Images
Logic Board Schematic Diagrams
Commodore PET 2001 Logic Board
PET 2001 Logic Board Schematic
Resources
The following pages contain the complete internal schematics and service manuals:
Common Issues & Troubleshooting
  • Blank screen on power-up: Check the 6502, RAM, and character ROMs.
  • "garbage characters" on boot: Often caused by faulty RAM or ROM chips.
  • Cassette load errors: Clean or replace the drive belt; inspect the tape head for alignment.
  • Keyboard not responding: PETs used a capacitive keyboard matrix prone to oxidation; see the Commodore PET 2001 Keyboard Repair Guide.
For a full list of common faults and fixes, visit the Commodore PET 2001 Troubleshooting Guide.
Capacitor Replacement
While the PET series lacks the surface-mount capacitor plague seen in later machines, their power supplies and logic boards still suffer from degraded electrolytics.
Refer to the Commodore PET 2001 Capacitor Replacement Guide for a complete bill of materials and safe removal/replacement procedures.
