Apple Desktop Bus Mouse II
Revision as of 00:48, 6 September 2025 by Josh (talk | contribs) (Restoration)
The Apple Desktop Bus Mouse II was the second and final Apple Desktop Bus mouse produced by Apple Computer, introduced in January 1993. Marking Apple's third major mouse redesign in a decade, it abandoned the angular blocky design of its predecessor for a curved, ergonomic "teardrop" shape that influenced mouse design industry-wide. The mouse served as the standard pointing device for all Macintosh desktop computers from 1993 until its discontinuation on May 6, 1998, when it was replaced by the Apple USB Mouse accompanying the original iMac.
Apple Desktop Bus Mouse II (Model M2706)
Type Pointing device
Discontinued May 6, 1998
Price US$89 (retail)
Interface Apple Desktop Bus
Compatible All ADB-equipped Macs, Apple IIGS, PowerBook (with adapter)
Dimensions 108 mm L × 62 mm W × 38 mm H
Weight 140 g (4.9 oz)
Predecessor Apple Desktop Bus Mouse
Successor Apple USB Mouse
Model M2706 (Platinum), M2706 (Black), M2707 (PowerBook Gray)
Design Evolution
The Apple Desktop Bus Mouse II represented a significant departure from Apple's previous angular mouse designs, drawing inspiration from the successful third-generation Microsoft Mouse. The teardrop-shaped body featured smooth, rounded curves with the tracking ball positioned forward of center and an enlarged button encompassing the entire front portion of the mouse. This ergonomic design proved so successful that it established the basic form factor for computer mice that persists in modern designs across the industry.
The mouse maintained Apple's commitment to single-button simplicity, with the button spanning approximately 40% of the mouse surface area. The smooth curves eliminated the sharp edges of earlier models while maintaining an ambidextrous design suitable for both left and right-handed users.
Model Variants
Three distinct color variants were produced during the mouse's five-year production run:
M2706 Platinum
The standard Platinum gray version (Pantone 423C) shipped with all Macintosh desktop computers from 1993-1998. This was the most common variant, matching Apple's standard computer coloring of the era.
M2706 Black
A rare black version was produced exclusively for:
The black variant featured identical internals but commanded premium prices on the collector market due to its scarcity.
M2707 PowerBook Gray
A dark gray version matching the PowerBook 100 series aesthetic was offered as an optional accessory for PowerBook users. Model M2707 featured the same internal design but utilized the darker "Smoke" gray coloring to coordinate with portable systems.
Manufacturing Variations
Four distinct internal designs were produced across different manufacturing facilities:
Taiwan Manufacture (Logitech)
Characteristics:
  • Black tracking ball (19mm)
  • Black ball cage
  • Removable cable assembly
  • Two screws under label
  • PCB: Logitech 200343
  • Part numbers: 400791-400793, 400685
Identification: Large label with two screws, serial numbers starting with 'M'
China Manufacture
Characteristics:
  • Gray tracking ball (22mm)
  • Integrated ball cage (no separate component)
  • Single screw under serial number sticker
  • Two-piece PCB design with Logitech controller
  • Stamped label (unique among variants)
Identification: Serial numbers starting with 'L', second letter 'C' for China
Ireland/Malaysia Manufacture (Mitsumi)
Characteristics:
  • Separate ball cage component
  • Single consolidated PCB
  • Mitsumi controller chip
  • Embossed text in plastic case
Identification: Serial numbers starting with 'M', second letter 'I' (Ireland) or 'B' (Malaysia)
USA Manufacture
Characteristics:
  • White or black ball cage
  • Three-screw PCB mounting
  • Various controller chips
Identification: Serial numbers with USA designation
Technical Specifications
Physical Specifications
  • Dimensions: 108mm × 62mm × 38mm
  • Weight: 140g (without cable)
  • Cable length: 1.2m (4 feet)
  • Button: Single mechanical button
  • Tracking: Opto-mechanical ball system
Tracking System
  • Ball diameter: 19mm (early) or 22mm (later models)
  • Resolution: 100 counts per inch (CPI)
  • Encoder wheels: 36-slot optical
  • Maximum tracking speed: 10 inches/second
  • Sampling rate: 200 Hz mechanical
Electrical Specifications
  • Interface: Apple Desktop Bus (ADB)
  • Connector: 4-pin mini-DIN
  • Power consumption: 50mA typical, 100mA maximum
  • Operating voltage: 4.75V - 5.25V
ADB Protocol
  • Device address: $3 (default)
  • Handler ID: $01 (standard mouse)
  • Polling rate: 100 Hz typical
  • Data format: 2-byte movement packets
Internal Components
Controller Chips
Various manufacturers supplied controller ICs:
  • Logitech: Custom ADB controller (Taiwan models)
  • Mitsumi: Proprietary ASIC (Malaysia/Ireland models)
  • IC Designs: Custom controller (some variants)
Mechanical Components
  • Microswitch: Omron D2F series or equivalent
  • Encoder wheels: Injection-molded plastic with 36 slots
  • LED/Phototransistor pairs: Infrared 940nm
  • Ball: Rubber-coated steel (black) or solid rubber (gray)
Circuit Board Design
Two primary PCB configurations existed:
  • Single board: Most common, integrated design
  • Dual board: Separate boards for switch and electronics (China manufacture)
Maintenance & Repair
Disassembly Procedure
The disassembly process varied by manufacturing variant:
Taiwan models (two screws):
  1. Locate screw positions under label edges
  2. Pierce label or carefully peel to access screws
  3. Remove Phillips screws
  4. Separate case halves gently
Later models (single screw):
  1. Find screw under serial number sticker
  2. Remove single Phillips screw
  3. Release internal clips carefully
Common Maintenance Tasks
Ball and Roller Cleaning
Required tools: Isopropyl alcohol (90%+), cotton swabs, compressed air
Procedure:
  1. Rotate ball retainer counterclockwise to remove
  2. Extract tracking ball
  3. Clean ball with isopropyl alcohol
  4. Clean encoder wheels with cotton swab
  5. Remove debris from encoder slots with compressed air
  6. Verify roller spring tension
  7. Reassemble in reverse order
Microswitch Replacement
Compatible switches:
  • Omron D2F-01, D2F-01F, D2F-01F-T
  • Panasonic EVQ-P0E07K (light touch)
  • Panasonic EVQ-P0D07K (firm touch)
Replacement procedure:
  1. Disassemble mouse completely
  2. Desolder failed switch (note orientation)
  3. Clean PCB pads with flux and wick
  4. Install new switch maintaining alignment
  5. Test operation before reassembly
Cable Repair
Common failure points:
  • Cable entry to mouse body
  • Strain relief area
  • Near connector
Repair options:
  • Splice repair at break point
  • Complete cable replacement
  • Reinforcement with heat shrink tubing
Troubleshooting Guide
Common Issues and Solutions
Symptom Likely Cause Solution
Erratic cursor movement Dirty encoder wheels Clean wheels and ball thoroughly
No cursor movement Broken cable, failed encoder Test cable continuity, check encoders
Button doesn't click Worn microswitch Replace switch with compatible part
Intermittent operation Cable damage, dirty contacts Check cable, clean connectors
Double-clicking Switch bounce Replace microswitch
System doesn't recognize ADB port issue Test on different port/system
Preventive Maintenance
Monthly:
  • Clean ball and check movement
  • Inspect cable for damage
Quarterly:
  • Deep clean including encoder wheels
  • Check button operation
  • Clean ADB connector
Annually:
  • Full disassembly and cleaning
  • Inspect PCB for damage
  • Test on known-good system
Modern Retrofits
Optical Sensor Conversion
TT Design offers retrofit boards that replace the mechanical ball system with modern optical sensors:
  • Model-specific boards for different manufacturing variants
  • PixArt optical sensor technology
  • Maintains original 100 CPI specification
  • USB-C configuration port for adjustment
  • Compatible with original ADB protocol
USB Conversion
While the mouse can be used with ADB-to-USB adapters (Griffin iMate, Wombat), internal USB conversion requires significant modification and is generally not recommended due to the availability of purpose-built adapters.
Parts & Specifications
Replacement Parts
Service Parts Reference
Component Specification Notes
Tracking ball 19mm or 22mm diameter Variant-specific
Microswitch Omron D2F series Universal fit
Ball retainer Model-specific Not interchangeable between variants
Encoder wheels 36-slot optical Donor part required
Cable assembly 4-conductor shielded Some models detachable
Cleaning Supplies
  • Isopropyl alcohol 90%+
  • Lint-free cotton swabs
  • Compressed air
  • Plastic-safe contact cleaner
  • Microfiber cloths
Historical Impact
The Apple Desktop Bus Mouse II's teardrop design proved remarkably influential in the computer industry. The ergonomic shape established design principles that influenced not only subsequent Apple mice but also became widely adopted by other manufacturers. The curved form factor addressed ergonomic concerns while maintaining Apple's design philosophy of simplicity and elegance.
Despite criticism for retaining the single-button design when multi-button mice were becoming standard on other platforms, the mouse served successfully throughout the PowerPC transition era. Its five-year production run saw it bundled with systems ranging from the Quadra series through the Power Macintosh G3.
Software Compatibility
System Requirements
  • Minimum: System 7.1
  • Maximum: Mac OS 9.2.2
  • Optimal: System 7.5 through Mac OS 8.6
Control Software
  • Mouse control panel: Standard tracking speed adjustment
  • Third-party utilities: SteerMouse, USB Overdrive (with adapters)
  • Accessibility: CloseView, Easy Access
Collector Information
Authentication
  • Check serial number format for manufacturing location
  • Verify label type (printed vs. embossed)
  • Confirm ball color matches variant
  • Inspect internal PCB configuration
Condition Grading
  • Mint: No yellowing, perfect button action
  • Excellent: Minimal yellowing, fully functional
  • Good: Moderate yellowing, normal wear
  • Fair: Significant yellowing, functional issues
Market Value
  • Platinum M2706: Common, modest value
  • Black M2706: Rare, commands premium
  • Gray M2707: Uncommon, moderate premium
Restoration
  • Retrobrighting: Effective but may damage texture
  • Case swapping: Possible between compatible variants
  • Internal upgrades: Optical conversion available
Production Statistics
While exact production numbers remain unpublished, the Apple Desktop Bus Mouse II was manufactured continuously from 1993 to 1998, with estimates suggesting over 6 million units produced across all variants. The Platinum version comprised approximately 95% of production, with black variants accounting for less than 2% of total units manufactured.
Legacy
The Apple Desktop Bus Mouse II represented the culmination of Apple's ADB-era input device development. Its ergonomic design successfully bridged the gap between Apple's early angular aesthetic and the organic forms that would characterize later products. The mouse's influence extended beyond Apple, with the teardrop shape becoming a de facto standard for mouse design throughout the 1990s.
The transition to USB with the original iMac in 1998 marked the end of the ADB era, but the Desktop Bus Mouse II's design DNA lived on in the controversial "hockey puck" USB Mouse, which attempted to further refine the circular ergonomic concept, though with less success.
