Retrobrite (often stylized as Retr0bright) is a process for removing the yellow discoloration from aged plastic, commonly used on vintage computers, consoles, and other electronics. It typically involves applying a hydrogen peroxide-based solution to yellowed ABS plastic parts and exposing them to ultraviolet (UV) light or heat to restore their original color. The yellowing occurs due to chemical reactions, specifically photo-oxidation of bromine flame retardants, resulting in a yellow or brown tint and brittleness. Retrobrite chemically reverses this discoloration, improving the appearance of collectible electronics.
Methods of Retrobrite
Hydrogen Peroxide Gel Application
One popular method uses a gel form of hydrogen peroxide (hair bleaching cream, approximately 12% peroxide), applied evenly to the yellowed plastic surfaces. Items are wrapped in cling film to prevent drying and ensure even bleaching, then exposed to UV light or sunlight. This method is cost-effective and convenient but requires careful application to prevent streaking.
Liquid Peroxide Bath (Immersion)
Plastic parts are immersed in a diluted hydrogen peroxide solution (6–12%), ensuring complete submersion. UV exposure or heat accelerates the whitening process. This method provides uniform whitening results but requires a large volume of peroxide and careful handling to prevent damage.
Oxygenated Detergent Method
Using oxygen-based detergents or bleach boosters (e.g., OxiClean), mixed with warm water or peroxide, creates an accessible and cost-effective alternative to pure peroxide. It is slower and less potent but helpful for mild yellowing and can be enhanced with UV exposure.
UV Light vs. Heat Activation
Both UV light and heat activate the chemical reaction in Retrobrite. UV light significantly accelerates the process, while heat can provide a gentler but slower activation. Combinations of both methods are common, balancing speed with gentle handling of delicate plastics.
Alternative Techniques
Other techniques include:
  • Vapor Method: Peroxide vapors in a sealed chamber slowly whiten plastics without direct liquid contact.
  • Ozone Treatment: Ozone gas in combination with UV can bleach plastics but is slower and requires specialized equipment.
  • Sunlight-Only Fading: Using strong sunlight alone, without peroxide, for gradual whitening.
  • Abrasive Removal: Sanding or polishing the surface to physically remove discoloration (risking damage to texture).
Comparison of Methods
Method Effectiveness Risks / Challenges Longevity of Results
Hydrogen Peroxide Gel Very effective, ideal for large items. Possible streaking if unevenly applied. Monitoring required. Temporary; re-yellowing can occur.
Liquid Peroxide Bath Highly effective, uniform High peroxide volume, risk of plastic warping Temporary; yellowing may return.
Oxygenated Detergent Moderate; good for mild cases Slower, potential residues Temporary; may re-yellow.
UV Light Emphasis Fast; significantly speeds up bleaching Excessive UV can degrade plastics Temporary; re-yellowing possible.
Heat Emphasis Gentle but slower Risk of warping at high heat Temporary; controlled storage recommended.
Vapor Method Effective but slower; gentle on delicate parts Slow process; peroxide vapors safety Temporary; re-yellowing may occur.
Ozone or Other Alternatives Less predictable; slower than peroxide methods Ozone hazards; special equipment required Temporary; plastics may re-yellow.
Retrobrite Treatment Duration Guide
Below is a detailed guide indicating recommended treatment durations, peroxide concentrations, and effectiveness for various Retrobrite methods. Duration can vary based on factors such as UV intensity, ambient temperature, and severity of yellowing.
Recommended Retrobrite Treatment Durations & Peroxide Concentrations
Method Hydrogen Peroxide Concentration Typical Duration Effectiveness Cautions
Hydrogen Peroxide Gel (Cream) + Sunlight (UV) 10–12% 3–8 hours Very effective; rapid results Risk of uneven bleaching if not regularly monitored; may dry quickly under sunlight
Hydrogen Peroxide Gel (Cream) + UV Lamp 10–12% 4–8 hours Effective and controlled Gel may dry unevenly; wrap items in plastic cling film for uniform bleaching
Liquid Peroxide Bath + UV Lamp 6–10% 6–12 hours Highly uniform and thorough results Requires significant quantity of peroxide; safe handling required
Hydrogen Peroxide (Liquid Bath) + Sunlight 6–10% 4–10 hours Very effective; good uniformity Larger peroxide volumes required; exposure to UV should be even
Hydrogen Peroxide + Heat (35–40°C) + UV 6–10% 2–4 hours Rapid results; accelerates bleaching significantly Increased risk of plastic warping; precise temperature control necessary
Hydrogen Peroxide Vapor Chamber 30–35% 2–6 hours Fast, even bleaching; minimizes risk of streaking Highly concentrated peroxide; significant safety precautions required; suitable protective gear mandatory
UV Lamp Only (No peroxide) N/A 24–72 hours Mildly effective; safer for sensitive plastics Very slow results; less dramatic bleaching
Peroxide Paste (Homemade Gel + UV) 10–12% 4–8 hours Moderately effective; economical alternative Risk of uneven bleaching or streaking; consistency and monitoring are key
Liquid Peroxide Bath + Heat (35–40°C) without UV 6–10% 4–8 hours Moderately effective; useful for delicate or UV-sensitive plastics Risk of plastic warping or softening; careful temperature control essential
Troubleshooting Common Issues
Streaking
Streaking occurs if peroxide gel dries unevenly. Prevent by even gel application, using cling film, or immersion methods. Correct by re-treating in a peroxide bath or gentle polishing.
Over-brightening
Occurs if treated too long or at excessive concentrations. Prevent by monitoring closely and removing the item promptly. Mitigate with surface treatments (conditioner, wax) or careful polishing if needed.
Re-yellowing
Yellowing often returns due to continued exposure to UV, heat, or air. Limit UV and heat exposure, store in cool environments, and apply UV-blocking protectants to prolong results.
Safety Precautions
  • Always wear gloves, eye protection, and protective clothing when handling peroxide.
  • Work in a well-ventilated area, avoid inhaling fumes or peroxide vapors.
  • Dispose peroxide safely by diluting heavily and flushing with water.
  • Never mix peroxide with ammonia or bleach.
  • Properly ventilate when using UV or heat sources.
Material-Specific Recommendations
ABS Plastics
Most commonly retrobrited; avoid excessive heat. Watch for brittleness post-treatment. Fully disassemble for best results.
Other Plastics
Polycarbonate and colored plastics require milder treatments and careful monitoring to avoid unwanted color changes. Avoid retrobriting painted or stickered areas.
Fragile and Valuable Items
Use gentle methods (vapor method, mild peroxide) for fragile or rare items. Consider non-chemical methods or protective clear coatings for highly valuable pieces.
