Macintosh LC III+
Revision as of 17:45, 9 February 2026 by Josh (talk | contribs) (Create Macintosh LC III+ article)
The Macintosh LC III+ is a personal computer released by Apple on October 18, 1993.[1] The LC III+ is essentially a faster version of the Macintosh LC III, with the processor clock speed increased from 25 MHz to 33 MHz.[2]
Macintosh LC III+
TypePersonal Computer
ReleasedOctober 18, 1993
DiscontinuedFebruary 14, 1994
Intro priceUS$1,349
CPUMotorola 68030 @ 33 MHz
Memory4 MB RAM (expandable to 36 MB)
Storage80 MB or 160 MB SCSI HDD, 1.44 MB SuperDrive
Display640×480 8-bit (512K VRAM) or 16-bit (768K VRAM)
Sound8-bit stereo input/output
Dimensions2.9" H × 12.2" W × 15.3" D
Weight8.8 lbs (4.0 kg)
OS / FirmwareSystem 7.1 – System 7.6.1
PredecessorMacintosh LC III
SuccessorMacintosh LC 475
CodenameElsie III+
Model no.M1254
Model Variants
The LC III+ was sold under several Performa brand names for consumer markets:
  • Performa 460 — Base configuration
  • Performa 466 — With different bundle
  • Performa 467 — With CD-ROM drive
Design Changes
The LC III+ introduced a redesigned case with a smoother, more curved front bezel compared to the angular design of earlier LC models. This design continued in subsequent LC-series machines.
The LC III+ uses a Motorola 68030 processor running at 33 MHz with a full 32-bit data bus. This provides approximately a 32% speed increase over the 25 MHz LC III.[3]
Like the LC III, the LC III+ includes a socket for an optional Motorola 68882 FPU.
The Gestalt ID for the Macintosh LC III+ is 62.
Memory and Storage
RAM Configuration
The LC III+ shipped with 4 MB of RAM standard, expandable to 36 MB using a single 72-pin SIMM slot.
RAM Configurations
Configuration SIMM Required
4 MB 4 MB onboard
8 MB 4 MB onboard + 4 MB SIMM
12 MB 4 MB onboard + 8 MB SIMM
20 MB 4 MB onboard + 16 MB SIMM
36 MB 4 MB onboard + 32 MB SIMM
Video RAM
The LC III+ includes 512 KB of VRAM onboard, expandable to 768 KB:
  • 512 KB VRAM: 640×480 at 8-bit (256 colors)
  • 768 KB VRAM: 640×480 at 16-bit (thousands of colors)
Storage Systems
Storage options included:
  • 80 MB or 160 MB internal SCSI hard drive
  • 1.44 MB SuperDrive
Input/Output and Expansion
Port Configuration
  • 1× Apple Desktop Bus (ADB) port
  • 1× External SCSI (DB-25)
  • 1× Audio input (3.5mm stereo minijack)
  • 1× Audio output (3.5mm stereo minijack)
  • 2× Serial ports (Mini DIN-8)
  • 1× Video output (DA-15)
Expansion
The LC III+ features a single LC Processor Direct Slot (LC PDS) and an FPU socket for the 68882 coprocessor.
For detailed maintenance practices including cleaning, PRAM battery management, and connector care, refer to the dedicated Macintosh LC III+ General Maintenance page.
A comprehensive troubleshooting guide addressing common issues with the Macintosh LC III+ is available on the Macintosh LC III+ Troubleshooting page.
Capacitor Replacement
The Macintosh LC III+ logic board contains surface-mount electrolytic capacitors that commonly fail due to age. Detailed replacement guidelines can be found on the Macintosh LC III+ Capacitor Replacement Guide page.
Note: The LC III+ shares the same C22 reversed polarity silkscreen error as the LC III.
Macintosh LC III+ Technical Specifications
Component Specification
CPU Motorola 68030 @ 33 MHz
FPU Optional 68882 (socket provided)
PMMU Integrated in 68030
Data Bus 32-bit
System Bus 33 MHz
ROM 1 MB
RAM 4 MB (max 36 MB)
VRAM 512 KB (max 768 KB)
  1. Macintosh LC III+, Apple History—link(accessed 2026-02-09)
  2. Apple Macintosh LC III+ Specs, EveryMac.com—link(accessed 2026-02-09)
  3. Macintosh LC III+, Low End Mac—link(accessed 2026-02-09)
