Macintosh Quadra 950
Revision as of 11:39, 10 February 2026 by Josh (talk | contribs) (Created Macintosh Quadra 950 article with full specs, infobox, and maintenance links)
The Macintosh Quadra 950 is a high-end workstation computer introduced by Apple Computer on May 18, 1992.[1] It replaced the Quadra 900 and utilized the same large tower enclosure. The Quadra 950 featured a faster 33 MHz Motorola 68040 processor (up from 25 MHz in the 900), making it one of the most powerful 68k Macintoshes produced.[2]
TypeWorkstation / Personal Computer
ReleasedMay 18, 1992
DiscontinuedOctober 14, 1995
Intro priceUS$8,500–$9,600
CPUMotorola 68040 @ 33 MHz
Memory8 MB or 16 MB RAM (expandable to 256 MB)
Storage230 MB, 400 MB, or 1 GB SCSI hard drive; 1.44 MB floppy
Display512×384 to 1152×870 (via onboard video)
Sound8-bit stereo audio
Dimensions18.6" × 8.9" × 20.6" (47.2 × 22.6 × 52.3 cm)
Weight36.8 lbs (11.5 kg)
OS / FirmwareSystem 7.0.1 – Mac OS 8.1
PredecessorQuadra 900
SuccessorPower Macintosh 9500
CodenameN/A
Model no.M4300
The Quadra 950 was marketed toward professionals requiring maximum expandability and processing power. It remained in production for over three years until being replaced by the Power Macintosh 9500 in 1995. Apple also sold a server variant, the Workgroup Server 95, based on the same hardware.
The Quadra 950 is built around the Motorola 68040 processor running at 33 MHz with an integrated floating-point unit (FPU).[3] The 68040 features an 8 KB instruction cache and 8 KB data cache. The system bus also runs at 33 MHz.
Component Specification
Processor Motorola 68040 @ 33 MHz
FPU Integrated (68040)
L1 Cache 8 KB (4 KB instruction + 4 KB data)
System Bus 33 MHz
ROM 1 MB
Gestalt ID 26
Memory and Storage
RAM Configuration
The Quadra 950 shipped with either 8 MB or 16 MB of RAM. It has 16 30-pin SIMM slots supporting up to 256 MB of RAM using third-party 16 MB SIMMs, though Apple officially supported a maximum of 64 MB.[4] RAM must be installed in matched groups of four identical SIMMs.
Specification Value
RAM Type 30-pin SIMM
Minimum Speed 80 ns
Standard RAM 8 MB or 16 MB
Maximum RAM 256 MB (with 16× 16 MB SIMMs)
SIMM Slots 16 (install in groups of 4)
Storage Systems
Storage options included SCSI hard drives of 230 MB, 400 MB, or 1 GB capacity. The system includes a 1.44 MB SuperDrive floppy and an optional internal 2× CD-ROM drive. The tower case provides three internal 5.25" drive bays (two front-accessible if no CD-ROM is installed).
Display and Graphics
The Quadra 950 includes onboard video with 1 MB of VRAM, expandable to 2 MB via four 80 ns VRAM SIMM slots. Video capabilities depend on VRAM configuration:
VRAM Resolution Color Depth
1 MB 512×384 24-bit (millions)
1 MB 640×480, 832×624, 1152×870 8-bit (256 colors)
2 MB 832×624 24-bit (millions)
2 MB 1152×870 8-bit (256 colors)
Additional displays can be supported via NuBus video cards.
Input/Output and Expansion
Port Configuration
Port Type Quantity
Serial Mini DIN-8 2 (Modem, Printer)
SCSI DB-25 1
ADB Mini DIN-4 2
Floppy DB-19 1
Audio In 3.5mm stereo 1
Audio Out 3.5mm stereo 1
Ethernet AAUI-15 1
Expansion Slots
The Quadra 950 offers extensive expansion capability:
  • 5 NuBus slots — Three provide 15W of power; two provide 25W
  • 1 Processor Direct Slot (PDS) — 68040 PDS for accelerator cards
The tower case accommodates up to three internal drive bays.
For detailed maintenance practices including cleaning, PRAM battery management, and connector corrosion prevention, refer to the dedicated Macintosh Quadra 900 General Maintenance page. The Quadra 950 shares the same case and many components with the Quadra 900.
The Macintosh Quadra 950 shares its service documentation with the Quadra 900 and Workgroup Server 95.
Apple Service Manual
Detailed capacitor replacement guidelines can be found on the Macintosh Quadra 900 Capacitor Replacement Guide page. The Quadra 950 uses the same logic board design as the Quadra 900.
Retrobrite
A comprehensive troubleshooting guide addressing power issues, video problems, and common failures is available on the Macintosh Quadra 900 Troubleshooting page.
Sub-system Specification (Macintosh Quadra 950, 1992)
CPU Motorola 68040 @ 33 MHz
FPU Integrated
ROM 1 MB
RAM 8–256 MB (16 SIMM slots)
VRAM 1–2 MB
Video 512×384 to 1152×870
Sound 8-bit stereo
Storage SCSI (230 MB–1 GB), 1.44 MB floppy
Expansion 5 NuBus, 1 PDS
Networking AAUI-15 Ethernet
Power 100–240V AC, 303W max
  1. Macintosh Quadra 950 Specs, EveryMac.com—link(accessed 2026-02-10)
  2. Macintosh Quadra 950, Low End Mac—link(accessed 2026-02-10)
  3. Quadra 950, Apple History—link(accessed 2026-02-10)
  4. Macintosh Quadra 950 Specs, EveryMac.com—link(accessed 2026-02-10)
