Macintosh Performa 450
Revision as of 12:12, 10 February 2026 by Josh (talk | contribs) (Add Service Documentation section with embedded Apple Service Source PDF)
The Macintosh Performa 450 is a consumer-oriented personal computer introduced by Apple Computer on April 12, 1993.[1] It is a rebrand of the LC III for the consumer market, featuring the same hardware in the compact "pizza box" LC enclosure.
TypePersonal Computer
ReleasedApril 12, 1993
DiscontinuedNovember 1, 1993
Intro priceUS$1,800
CPUMotorola 68030 @ 25 MHz
Memory4 MB RAM (expandable to 36 MB)
Storage120 MB SCSI hard drive, 1.44 MB floppy
Display512x384-832x624 (up to 16-bit)
Sound8-bit mono
Dimensions2.9" H x 12.2" W x 15.3" D
Weight8.8 lbs (4 kg)
OS / FirmwareSystem 7.1P - 7.6.1
PredecessorPerforma 430
SuccessorPerforma 460
Model no.M1254
The Performa 450 was a significant upgrade from the earlier Performa 400-series models. It uses a Motorola 68030 processor running at 25 MHz with a full 32-bit data path. It shipped with 4 MB of RAM (expandable to 36 MB using a single 72-pin SIMM), 512 KB of VRAM (expandable to 768 KB), and a 120 MB SCSI hard drive.
Component Specification
CPU Motorola 68030 @ 25 MHz (32-bit data path)
FPU None
System Bus 25 MHz
ROM 1 MB
RAM 4 MB onboard (expandable to 36 MB via 72-pin SIMM)
VRAM 512 KB onboard (expandable to 768 KB)
Storage 120 MB SCSI hard drive, 1.44 MB floppy
Expansion 1x LC III PDS slot
Ports ADB, SCSI, 2x Serial (Modem/Printer), Audio out
Display Up to 832x624 @ 8-bit (512 KB), 832x624 @ 16-bit (768 KB)
Power 100V-240V AC, 50 W max
Relationship to LC III
The Performa 450 is identical to the LC III internally. The Performa line was marketed to home consumers through retail channels, while the LC III was sold to educational institutions. The Performa models shipped with bundled software including At Ease, ClarisWorks, and various educational or entertainment titles.
For detailed maintenance procedures including cleaning, PRAM battery management, and connector maintenance, refer to the Macintosh LC III General Maintenance page.
A troubleshooting guide addressing common issues is available on the Macintosh LC III Troubleshooting page.
Capacitor replacement information for the logic board can be found on the Macintosh LC III Capacitor Replacement Guide page.
  1. Macintosh Performa 450 Specs, EveryMac.com—link(accessed 2026-02-10)
