Macintosh Performa 5430
Revision as of 12:19, 10 February 2026 by Josh (talk | contribs) (Convert from redirect to standalone article with full specs)
The Macintosh Performa 5430 is an all-in-one personal computer manufactured by Apple Computer, Inc., introduced on August 1, 1996.[1] It is an upgraded variant of the Performa 5400CD with a faster 160 MHz processor and 8X CD-ROM drive, sold exclusively in Europe.
ReleasedAugust 1, 1996
DiscontinuedDecember 1, 1997
CPUPowerPC 603e @ 160 MHz
Memory16 MB RAM (expandable to 136 MB)
Storage1.6 GB IDE hard drive, 8X CD-ROM
Display15" shadow mask CRT (800×600 16-bit, 1024×768 8-bit)
Sound16-bit stereo output, 16-bit mono input, SRS surround
Dimensions17.5" H × 15.1" W × 16.0" D (44.5 × 38.4 × 40.6 cm)
Weight47 lbs (21.3 kg)
OS / FirmwareSystem 7.5.3 – Mac OS 9.1
PredecessorPerforma 5400CD
SuccessorPerforma 5500
CodenameAlchemy
The Performa 5430 is also known as the Performa 5400/160 and shares the same Alchemy logic board as the base 5400CD, but with the faster processor option.
Differences from Performa 5400CD
The Performa 5430 differs from the Performa 5400CD in the following ways:
  • CPU Speed: 160 MHz (vs 120 MHz)
  • CD-ROM: 8X (vs 4X)
  • Display Resolution: Supports 800×600 at 16-bit (vs 640×480)
  • Market: Europe only
  • Introduction: August 1996 (vs April 1996)
The Performa 5430 uses a PowerPC 603e processor running at 160 MHz on a 40 MHz system bus. The 603e is a 32-bit processor with a 64-bit data path and integrated floating-point unit.
Cache Configuration
  • L1 Cache: 32 KB (16 KB instruction, 16 KB data)
  • L2 Cache: 256 KB (optional)
Memory and Storage
RAM Configuration
Specification Details
RAM Type 168-pin DIMM
Minimum Speed 70 ns
Motherboard RAM 8 MB soldered
Standard RAM 16 MB
Maximum RAM 136 MB
RAM Slots 2
Storage Systems
  • Hard Drive: 1.6 GB IDE internal drive
  • Floppy Drive: 1.44 MB 3.5" manual-eject
  • CD-ROM: 8X
Display and Graphics
The built-in 15" shadow mask CRT supports:
  • 640×480 at 16-bit color
  • 800×600 at 16-bit color
  • 832×624 at 8-bit color
  • 1024×768 at 8-bit color (external mirroring)
For detailed maintenance practices, refer to the dedicated Macintosh Performa 5400CD General Maintenance page.
Detailed capacitor replacement guidelines can be found on the Macintosh Performa 5400CD Capacitor Replacement Guide page.
A comprehensive troubleshooting guide is available on the Macintosh Performa 5400CD Troubleshooting page.
  1. Apple Macintosh Performa 5400/160 Specs, EveryMac.com—link(accessed 2026-02-10)
