Amstrad GX4000 Service Manual
The file held under this title is not a GX4000-only manual. It is Amstrad plc's combined 464 PLUS / 6128 PLUS / GX4000 / MM 12 / CM 14 Service Manual — same printed cover, same contents list — scanned at higher detail as 95 PDF pages, with the large schematics and parts lists split across several images each. The GX4000 occupies printed pages 23 to 36 of it.
The same document is also hosted here, in a 51-page scan, at Amstrad 464 Plus / 6128 Plus / GX4000 Service Manual.
Which copy to use. This 95-page scan renders the schematics and parts lists larger and is the better one for reading component values off. The 51-page scan is smaller to download and keeps each printed page on one image. Both are complete.
Contents
Amstrad's own contents list, with printed page numbers:
  • Safety tests — 2
  • 464 PLUS section — 3: technical specification 3, electrical adjustments 4, main/cassette/hold/LED PCB top and bottom views 5–6, tape PCB 6, gate array / output interface schematic 7, CPU / connection interface schematic 8, video conversion / memory schematic 9, cassette interface schematic 10, key matrix (464 and 6128) 11, mechanical exploded view and parts list 12, deck exploded view 13, electrical parts list 14
  • 6128 PLUS section — 15: electrical adjustment 15, main/cassette/hold/LED PCB top and bottom views 16–17, gate array / output interface schematic 18, CPU / connection interface schematic 19, video conversion / memory schematic 20, mechanical exploded view and parts list 21, electrical parts list 22
  • GX4000 section — 23: electrical adjustment 23, main PCB top and bottom views 24–25, gate array / output interface schematic 26, CPU / connection interface schematic 27, video conversion / memory schematic 28, power regulator schematic 29, RGB convertor schematic 30, cabinet exploded view and parts list 31, main PCB (FRANCE) top and bottom views 32–33, power regulator schematic (FRANCE) 34, output interface schematic (FRANCE) 35, electrical parts list 36
  • MM-12 monitor section — 37: electrical adjustments 37, monitor/CRT PCB component layout 38, cabinet and parts list 39, monitor/CRT schematic 40–41, electrical parts list 42
  • CM-14 monitor section — 43: electrical adjustments 44–46, electrical parts list 47–48, monitor/CRT PCB component layout 49, power/sound schematic 50, monitor schematic 51, cabinet exploded view and parts list 52
The GX4000 pages specifically
Printed pages 23–36 cover the console: electrical adjustment, main PCB top and bottom views, the gate array / output interface, CPU / connection interface and video conversion / memory schematics, the power regulator schematic, the RGB convertor schematic, the cabinet exploded view and parts list, then the entire set again for the France board — separate top and bottom views, a separate power regulator schematic and a separate output interface schematic — and finally the GX4000 electrical parts list with value, circuit reference and Amstrad part number for every component.
The two board variants are the thing to take away: check which GX4000 board is in front of you before comparing it against a regulator drawing.
  • No text layer, so nothing can be searched.
  • No fault-finding flowcharts.
  • No coverage of the original CPC 464, 664 or 6128.
  • Nothing on the GX4000's cartridges or controllers beyond the connectors.
Download here: Amstrad GX4000 Service Manual.pdf
