File:Apple IIe Reference Manual 1982.pdf
Link to the index page
Original file (0 × 0 pixels, file size: 9.45 MB, MIME type: application/pdf)
Apple II Reference Manual - For //e Only (Apple Computer, Inc., 1982; Apple part number 030-0357-B). Apple's own hardware reference for the Apple IIe.
This is the source this wiki cites for the Apple IIe's published hardware figures, including:
  • Table 7-2, Power Supply Specifications - line voltage 107 to 132 V AC; maximum power consumption 60 W continuous, 80 W intermittent; supply voltages +5 V +-3%, +11.8 V +-6%, -5.2 V +-10%, -12 V +-10%; maximum supply currents +5 V 2.5 A, +12 V 1.5 A continuous and 2.5 A intermittent, -5 V 250 mA, -12 V 250 mA; maximum case temperature 55 degrees C. Unlike the 1979 Apple II Reference Manual, which gives nominals only, this manual does publish per-rail tolerances - but they are the IIe's, not the Apple II's.
  • The supply's self-protection behaviour: all four outputs are turned off if any output is shorted to ground, if the supply cable is disconnected, or if any output leaves its normal range.
  • The single-wire shift-key modification at the broken circle marked X6, the note that early boards with a part number ending in A have it already made, and Apple's warning that closing a hand-control switch while SHIFT is pressed short-circuits and shuts the supply down.
  • Cassette input and output, the auxiliary slot signal tables, and the 6502B timing data.
This is the searchable (OCR text layer) edition scanned by the Internet Archive.
Internet Archive item Apple_IIe_Reference_Manual (text-layer edition).
Licensing
Copyright Apple Computer, Inc., 1982. Apple has never placed this manual under a free licence. It is hosted here for reference and repair use only, as an out-of-print manual for long-discontinued hardware, on the same basis as the other Apple documentation on this wiki. It is not public domain and is not freely licensed.
Date/TimeDimensionsUserComment
current05:26, 23 September 20260 × 0 (9.45 MB)Josh (talk | contribs)Upload: primary source for the Apple II/III family verification drive
