Macintosh Performa 6300CD
The Macintosh Performa 6300CD is a PowerPC-based desktop personal computer manufactured by Apple Computer, Inc. and released on January 27, 1996.[1] It features a 100 MHz PowerPC 603e processor, 16 MB of RAM, a 1.2 GB IDE hard drive, and a 4X CD-ROM drive in a compact desktop case based on the Macintosh Quadra 630 form factor. The system shipped with a 15" Apple color monitor.
| Macintosh Performa 6300CD | |
| Type | Personal Computer |
| Released | January 27, 1996 |
| Discontinued | October 1, 1996 |
| Intro price | US$2,800 |
| CPU | PowerPC 603e @ 100 MHz |
| Memory | 16 MB RAM (expandable to 64 MB) |
| Storage | 1.2 GB IDE hard drive, 4X CD-ROM |
| Display | DB-15 video output (640×480 16-bit, 800×600 8-bit) |
| Sound | Monophonic input, stereo output |
| Dimensions | 4.3" H × 12.6" W × 16.5" D (10.9 × 32 × 41.9 cm) |
| Weight | 19 lbs (8.6 kg) |
| OS / Firmware | System 7.5.1 – Mac OS 9.1 |
| Predecessor | Performa 6200CD |
| Successor | Performa 6360 |
| Model no. | M3076 |
The Performa 6300CD shares its logic board with the Performa 5300CD all-in-one system and is part of Apple's consumer-oriented Performa line.[2]
Model Variants
editThe Performa 6300 series includes several regional and specification variants that share the same logic board (Model M3076, Gestalt ID 42):
| Model | CPU | RAM | Storage | Region | Release Date | Notes |
| Performa 6290CD | 100 MHz 603e | 8 MB | 1.2 GB | North America | January 27, 1996 | Base model without bundled monitor |
| Performa 6300CD | 100 MHz 603e | 16 MB | 1.2 GB | North America | January 27, 1996 | Includes 15" monitor |
| Performa 6310CD | 100 MHz 603e | 16 MB | 1.2 GB | Europe/Asia | February 14, 1996 | International version of 6300CD |
| Performa 6320CD | 120 MHz 603e | 16 MB | 1.2 GB | North America | April 22, 1996 | Includes TV/Video input card |
The Performa 6360 uses a different logic board ("Alchemy") with DIMM RAM and PCI expansion.
editThe Performa 6300CD is powered by a 100 MHz PowerPC 603e processor with integrated FPU. The processor communicates over a 100 MHz front-side bus to 256 KB of L2 cache and 4 MB of ROM.[3]
The internal bus structure consists of three buses:
- A 64-bit 100 MHz 603 bus connecting the CPU, L2 cache, and ROM
- A 32-bit 40 MHz 68040-compatible bus connecting memory, video, and I/O controllers via the Capella chip
- A 32-bit 16 MHz I/O bus managed by the PrimeTime II chip
Memory and Storage
editRAM Configuration
editThe system includes two 72-pin SIMM slots supporting 80 ns or faster memory:
- Standard RAM: 16 MB
- Maximum RAM: 64 MB
- No onboard RAM; all memory installed via SIMMs
Storage Systems
edit- Hard Drive: 1.2 GB IDE internal drive
- Floppy Drive: 1.44 MB 3.5" SuperDrive (manual insert)
- CD-ROM: 4X internal CD-ROM drive
The system uses an IDE interface for the hard drive rather than SCSI, though an external SCSI port is available for peripherals.
Display and Graphics
editVideo is handled by integrated graphics using 1 MB of system RAM dedicated to video function:
| Resolution | Color Depth |
| 640×480 | 16-bit (Thousands) |
| 800×600 | 8-bit (256 colors) |
| 832×624 | 8-bit (256 colors) |
A DB-15 video output port provides connection to external monitors. A second display can be supported with the addition of a PDS video card.
Audio Capabilities
edit- Monophonic 8-bit sound input
- Stereo 16-bit sound output via internal speakers
- 3.5mm audio input and output jacks
Input/Output and Expansion
editPort Configuration
edit- 2× RS-232/422 serial ports (printer and modem)
- 1× External SCSI port (DB-25)
- 1× ADB port
- 1× Audio input (3.5mm mono)
- 1× Audio output (3.5mm stereo)
- 1× DB-15 video output
Expansion Slots
edit- 1× LC PDS (Processor Direct Slot)
- 1× Communications Slot
- 1× Video I/O slot
- 1× TV tuner slot
editFor detailed maintenance practices including cleaning, PRAM battery management, connector corrosion prevention, and voltage adjustments, refer to the dedicated Macintosh Performa 6300CD General Maintenance page.
editThe Macintosh Performa 6300CD features the same logic board as the Performa 5300 series.
Apple Service Manual
editThe Apple Service Source manual for the Performa 6200/6300 series covers all variants.
editDetailed capacitor replacement guidelines for the logic board can be found on the Macintosh Performa 6300CD Capacitor Replacement Guide page.
Retrobrite
editTo address plastic yellowing common on the beige case, detailed instructions can be found on the Retrobrite page.
editA comprehensive troubleshooting guide addressing no power, startup issues, video problems, and other common failures is available on the Macintosh Performa 6300CD Troubleshooting page.
editSystem Architecture at a Glance
edit| Sub-system | Specification (Macintosh Performa 6300CD, 1996) |
| Bus width | 32-bit data (I/O) • 64-bit data (CPU) |
| ROM | 4 MB |
| RAM | 16 MB (expandable to 64 MB) |
| L1 Cache | 32 KB |
| L2 Cache | 256 KB |
| Video | 640×480 16-bit, 800×600 8-bit |
| Sound | Mono input, stereo output |
| Disks | 1.2 GB IDE HDD, 1.44 MB floppy, 4X CD-ROM |
| Ports | ADB, SCSI, 2× Serial, Audio I/O, Video out |
Processor Specifications
edit| Component | Specification |
| CPU | PowerPC 603e @ 100 MHz[4] |
| Data Bus | 64-bit (CPU), 32-bit (I/O) |
| FPU | Integrated |
| L1 Cache | 32 KB (16 KB instruction, 16 KB data) |
| L2 Cache | 256 KB |
Power Specifications
edit- Input: 100V-240V AC, 50-60 Hz
- Maximum power consumption: 55 Watts
