Performa 500 Series Service Source
The Performa 500 Series volume of Apple's Service Source is a 161-page service manual covering the Performa 550, 560, 575, 577 and 578. The PDF was distilled on 5 December 1995.
Service Source volumes are module-level documents. They give Apple's own specifications, symptom charts, take-apart procedures and module part numbers, but they do not carry schematics, board-level parts lists or component values, so they cannot be used to source a capacitor table. Where a figure below is quoted, it is quoted as Apple printed it.
Specifications as Apple prints them
Item As printed
CPU, 550 and 560 Motorola 68030 at 33 MHz, built-in MMU
CPU, 575/577/578 Motorola 68LC040 at 33 MHz
Line voltage 100–240 VAC, universal supply
Frequency 47–63 Hz, single phase
Maximum power 120 W
Battery replace if below 3.0 V
Contents
Reconstructed from the manual's own running headers; page numbers are positions in the PDF, so a citation can be checked directly.
  • Basics — Product Information (pdf p. 3)
  • Specifications — Processor (pdf p. 6), Memory (pdf p. 7), Disk Storage (pdf p. 9), I/O Interfaces (pdf p. 10), I/O Devices (pdf p. 12), Sound and Video (pdf p. 13), Electrical (pdf p. 14), Physical (pdf p. 15), Environmental (pdf p. 16)
  • Troubleshooting — General (pdf p. 18), Symptom Charts (pdf p. 19)
  • Take Apart — Rear Housing (pdf p. 36), Fan (pdf p. 39), Analog Board (pdf p. 41), I/O Door (pdf p. 47), Logic Board (pdf p. 49), Drive Bezel (pdf p. 50), Floppy Drive (pdf p. 52), CD-ROM Drive (pdf p. 56), Hard Drive (pdf p. 60), Chassis Harness Assembly (pdf p. 64), CRT (pdf p. 84), Internal Microphone (pdf p. 87), Front Bezel (pdf p. 90)
  • Upgrades — Macintosh Processor Upgrade (pdf p. 93)
  • Additional Procedures — Battery Verification (pdf p. 116), Battery Replacement (pdf p. 118)
  • Adjustments — Geometry (pdf p. 122), Video (pdf p. 130), Light Meter Setup (pdf p. 142), Convergence (pdf p. 148), Geometric Distortion (pdf p. 151), Yoke (pdf p. 156)
Notable content
Apple's Light Meter Setup is the step most often skipped: the video and convergence adjustments that follow it are meaningless without it, and Apple specifies the meter and lens (Model L-248) to be used.
  • No schematic, no parts list, no component values — the analogue board is a module.
  • The Adjustments chapter is Geometry, Video, Light Meter Setup, Convergence, Geometric Distortion and Yoke. There is no voltage adjustment.
Pages that cite this document
This machine contains a high-vacuum picture tube and a live analogue board. Follow CRT Discharge Procedure before working inside one.
Download: Performa_500_series.pdf (1.4 MB)
