Schneider DMP3000 Service Manual
The Kundendienst-Handbuch / Service Manual DMP 3000 is Schneider Computer Division's service manual for the DMP 3000 dot-matrix printer — the DACH-region badge of the Amstrad DMP3000. Ident-Nr. 33 624; the document code in the footer is HDS 60259/1500/04/87, which dates it to April 1987. 12 pages, German and English in parallel columns, with a text layer.
Unlike Amstrad's combined DMP2000/3000/4000 manual, this one covers the DMP 3000 only, and it carries a complete electrical parts list.
Contents
edit- p. 1 — cover
- p. 2 — Cabinet parts list (Ersatzteilliste), with Schneider order numbers
- p. 3 — cabinet drawing
- p. 4 — printer mechanism drawing
- p. 5 — Mechanism parts list with manufacturer part numbers (e.g. damper 190748, set plate 190749)
- p. 6–7 — Circuit diagram
- p. 8 — Wiring diagram
- p. 9 — Main PCB (Hauptplatine), component side and track side
- p. 10 — Electrical parts list — resistors, capacitors, diodes, transistors and ICs
- p. 11 — Miscellaneous parts (mains choke, DIP switches, fuses, Centronics socket)
- p. 12 — Technische Daten, DIP-switch table and the Centronics interface pinout
Electrical parts, as printed
edit| Ref | Part | Schneider part no. |
| C1, C2, C3, C5, C6, C9, C10, C14–C21, C23 | 0.1 µF / 50 V mono glass ceramic | 102A0002-1042 |
| C4 | 1 µF / 50 V electrolytic, 105 °C | 103A1001-0107 |
| C25 | 4700 µF / 30 V electrolytic, 105 °C | 103A1002-4722 |
| C26 | 47 µF / 16 V electrolytic, 105 °C | 103A1001-4703 |
| C28 | 4700 µF / 16 V electrolytic, 105 °C | 103A1002-4721 |
| C31, C34 | 0.047 µF / 250 V metallised film | 102A0008-4725 |
| C32, C33 | mains safety capacitor — see the note below | 102A0009-2225 |
| R60, R61 | 470 Ω 1 W | 101A0004-4711 |
| R62, R63 | 100 Ω 2 W | 101A0005-1011 |
| RCN1 | RC network T002 (ALPS) | 106A0090-0001 |
| VR1 | 68 Ω semi-fixed | 121A0001-6831 |
| D1 | 3.3 V 0.5 W zener | 104A2001-1033 |
| D2–D21 | 1N4148 | 104A0001-4148 |
| D22, D23 | 27 V 1 W zener | 104A2001-1270 |
| D24, D25 | 1N4004 400 V rectifier | 104A0002-4004 |
| BD1 | bridge rectifier S4VB10, 4 A 100 V | 104A1002-0410 |
| BD2 | bridge rectifier S2VB10, 2 A 100 V | 104A1001-0210 |
| TR1, TR2 | 2SA1015Y | 105A0101-1015 |
| TR3, TR4 | 2SB858B | 105A0201-0858 |
| TR5, TR6 | DTA114E | 105A9001-0114 |
| IC6 | µPD7811G-071 — the printer's CPU | 106A9000-7811 |
| IC8 | 27256, 250 ns EPROM | 106A0001-2756 |
| IC10 | 6264, 150 ns SRAM | 106A0001-6264 |
| IC18 | L7805 voltage regulator | 106A0003-7805 |
| IC1 | LM339 / HA17339 | 106A0002-1339 |
| IC17 | NE555 / HA17555 | 106A0002-1555 |
| TRA1 | HA13408 | 106A0004-3408 |
| LED1, LED3 | green TLG211 | 119A0001-0002 |
| LED2 | red TLR211 | 119A0001-0001 |
C32 and C33 are the mains safety capacitors, and the manual contradicts itself about their value: the German column reads 0,0022 µF / 250 V and the English column 0.022/250 V. The Schneider part number, 102A0009-2225, encodes 2200 pF, so 0.0022 µF is the value and the English column has dropped a zero. These are the class-X/Y parts that fail short and smoke in printers of this age — replace them like for like with a correctly class-rated part, and read the marking on the part in front of you.
The two reservoir capacitors, C25 (4700 µF 30 V) and C28 (4700 µF 16 V), are the ones that actually age. Both are specified as 105 °C parts; fitting 85 °C replacements is a downgrade.
Technical data, as printed
edit| Item | Value |
| Print system | Impact dot-matrix wire printer |
| Speed | 105 cps normal, 52 cps double-width |
| Character matrix | 9 × 9 normal; 9 × 10 double-width; 96 ASCII plus italics plus international sets; normal character 2.1 mm wide × 2.55 mm high |
| Columns | 80 standard, 40 double-width, 132 condensed, 66 double-width condensed |
| Line feed | 1/6, 1/8, 7/72 in, and n/216 or n/72 in programmable; 1/6 in in 0.2 s |
| Paper | Continuous 4.5–10 in wide; single sheet or roll 4–9.5 in wide; 1 original + 1 copy on 40 g/m² paper |
| Interface | Parallel, Centronics-compatible |
| Mains | 220–240 V, 50 Hz |
| Size and weight | 40 × 25 × 10 cm; 4.2 kg |
The Centronics port sources +5 V on pins 18 and 35, rated 50 mA maximum. That is a real limit and it is the figure to check before powering anything from a printer port.
The DIP-switch table covers DS1-1 to DS1-8 and DS2-1 to DS2-10 with the OFF and ON meaning of each, including page length (11 in / 12 in), paper-end detection, buffer mode and the beeper. DS2-9 and DS2-10 are marked "ohne Bedeutung" — no function.
What it does not contain
editNo fault-symptom table, no adjustment or alignment procedure, and no head or mechanism service intervals.
edit- Amstrad DMP2000 / DMP3000 / DMP4000 Service Manual — Amstrad's combined manual, whose DMP2000/3000 section runs in parallel with this one
- Schneider DMP4000 Service Manual · Schneider NLQ-401 Service Manual
- Amstrad DMP1 Printer Service Manual · Amstrad DMP2000 Printer Service Manual (standalone) · Amstrad LQ3500 Printer Service Manual
- Capacitor Failure Symptoms
Download the Schneider DMP3000 Service Manual here: Schneider DMP3000 Service Manual.pdf (2.0 MB)
