Macintosh Performa 550
The Macintosh Performa 550 is an all-in-one personal computer introduced by Apple Computer on October 18, 1993.[1] It is the consumer version of the LC 550, sold through retail channels with bundled "home software."
| Macintosh Performa 550 | |
| Type | All-in-One Personal Computer |
| Released | October 18, 1993 |
| Discontinued | April 1, 1996 |
| Intro price | US$2,000 |
| CPU | Motorola 68030 @ 33 MHz |
| Memory | 5 MB RAM (expandable to 36 MB) |
| Storage | 160 MB SCSI hard drive, 2X CD-ROM, 1.44 MB floppy |
| Display | 14" Sony Trinitron color CRT (640×480) |
| Sound | Stereo 8-bit, 22 kHz |
| Dimensions | 17.9" H × 13.5" W × 16.5" D (45.5 × 34.3 × 41.9 cm) |
| Weight | 40.5 lbs (18.4 kg) |
| OS / Firmware | System 7.1P – System 7.6.1 |
| Predecessor | Performa 520 |
| Successor | Performa 575 |
| Codename | Hook |
| Model no. | M1640 |
The Performa 550 shares identical hardware with the LC 550, differing only in the included software bundle and distribution channel. The LC 550 was sold to educational institutions while the Performa 550 targeted home users.
Relationship to LC 550
editThe Performa 550 uses the same logic board, case design, and internal components as the LC 550. Apple marketed the same hardware under different names for different markets:
- LC 550 – Educational market
- Performa 550 – Consumer market (home software bundle)
- Performa 560 – Consumer market (business software bundle)
editThe Performa 550 uses a Motorola 68030 processor running at 33 MHz with a 32-bit data bus. The system bus also operates at 33 MHz. An optional Motorola 68882 FPU can be installed for floating-point calculations.
Memory and Storage
editRAM Configuration
editThe system includes 4 MB of RAM soldered to the logic board, with an additional 1 MB SIMM installed by default for a total of 5 MB. A single 72-pin SIMM slot accepts modules up to 32 MB for a maximum of 36 MB total RAM. SIMMs must be 80 ns or faster.
ROM
editThe Performa 550 contains 1 MB of ROM.
Storage Systems
editStandard configuration includes a 160 MB internal SCSI hard drive, a 2X CD-ROM drive, and a 1.44 MB SuperDrive floppy.
Display and Graphics
editThe built-in 14-inch Sony Trinitron CRT displays 640×480 resolution in 16-bit color. The system includes 512 KB of VRAM soldered to the logic board. A single VRAM slot accepts a 256 KB VRAM SIMM, bringing the total to 768 KB for improved color depth.
A second display can be supported via an LC PDS video card.
Input/Output and Expansion
editPort Configuration
edit- 2× Serial ports (Printer, Modem)
- SCSI port (DB-25)
- ADB port
- Audio input/output jacks
Expansion
editThe Performa 550 includes one LC PDS slot for expansion cards such as Ethernet adapters or additional video output.
editFor detailed maintenance practices including cleaning, PRAM battery management, connector corrosion prevention, and voltage adjustments, refer to the dedicated Macintosh LC 550 General Maintenance page.
editThe Macintosh Performa 550 shares its logic board and analog board with the LC 550. For schematics and service documentation, see the Macintosh LC 550 article.
editDetailed capacitor replacement guidelines for both analog and logic boards can be found on the Macintosh LC 550 Capacitor Replacement Guide page.
Retrobrite
editTo address plastic yellowing, detailed instructions can be found on the Retrobrite page.
editA comprehensive troubleshooting guide addressing no power, chime but no video, intermittent operation, Sad Mac errors, and floppy drive problems is available on the Macintosh LC 550 Troubleshooting page.
editSystem Architecture at a Glance
edit| Sub-system | Specification |
| FPU | Optional Motorola 68882 |
| Bus width | 32-bit data bus |
| ROM | 1 MB |
| RAM | 5 MB standard (4 MB soldered + 1 MB SIMM), expandable to 36 MB |
| VRAM | 512 KB (expandable to 768 KB) |
| Video | 640×480, 16-bit color |
| Storage | 160 MB SCSI HDD, 2X CD-ROM, 1.44 MB floppy |
| Expansion | 1× LC PDS slot |
| Gestalt ID | 80 |
editService Documentation
editThe official Apple Service Source documentation for this model:
