Atari Stacy Capacitor Replacement Guide
This article provides a capacitor replacement (recapping) guide for the Atari Stacy portable computer. The Stacy shares core ST circuitry but uses a different power regulation design from desktop ST models due to its external AC adapter and internal voltage regulation. Recapping is recommended for any Stacy exhibiting instability, display issues, or as preventive maintenance given the age of these machines (35+ years).
When to recap
Recapping is recommended when any of the following are observed:
- Video noise, flickering, or display dimming
- Random crashes or instability
- Audio distortion or weak sound output
- Visible electrolyte leakage or capacitor bulging
- The machine is approaching or exceeding 30 years of age (preventive maintenance)
- The internal NiCd battery has leaked (electrolyte may have accelerated capacitor degradation in nearby components)
Capacitor inspection
Before replacing capacitors, inspect all electrolytic capacitors on the main board and power regulation circuitry:
- Bulging tops — The top of the capacitor is domed or swollen rather than flat. Indicates internal gas pressure from electrolyte breakdown.
- Leaking electrolyte — Brown, orange, or clear fluid residue around the base or leads of the capacitor. May also appear as dried crusty deposits.
- Corrosion or PCB staining — Discolouration of the PCB around capacitor mounting points indicates electrolyte has leaked and is attacking copper traces.
Tools and materials
- Temperature-controlled soldering iron (recommended 300–350°C)
- Solder wick and/or desoldering pump
- High-quality replacement electrolytic capacitors (Panasonic FR-series or Nichicon UPW/UHE recommended)
- Isopropyl alcohol (99%+) and lint-free swabs
- Digital multimeter with capacitance measurement
- Flux (no-clean type)
- Fine leaded solder (0.5 mm)
- Safety glasses
- Anti-static wrist strap
Main board capacitor list
The Stacy main board is based on the 1040ST design with modifications for portable operation. The following electrolytic capacitors are found on the main board. Designators may vary slightly between board revisions.
| Designator | Capacitance | Voltage | Type | Notes |
| C1 | 100 µF | 16V | Radial electrolytic | Power filtering |
| C2 | 100 µF | 16V | Radial electrolytic | Power filtering |
| C3 | 47 µF | 16V | Radial electrolytic | Decoupling |
| C4 | 47 µF | 16V | Radial electrolytic | Decoupling |
| C5 | 22 µF | 16V | Radial electrolytic | Audio circuit |
| C6 | 22 µF | 16V | Radial electrolytic | Audio circuit |
| C7 | 10 µF | 25V | Radial electrolytic | |
| C8 | 10 µF | 25V | Radial electrolytic | |
| C9 | 4.7 µF | 50V | Radial electrolytic | |
| C10 | 4.7 µF | 50V | Radial electrolytic | |
| C11 | 2200 µF | 16V | Radial electrolytic | Main +5V rail bulk capacitor |
| C12 | 1000 µF | 16V | Radial electrolytic | Secondary power filter |
| C13 | 470 µF | 25V | Radial electrolytic | +12V rail filter |
| C14 | 100 µF | 25V | Radial electrolytic | -12V rail filter |
| C15 | 10 µF | 50V | Radial electrolytic | Reset circuit |
| C16 | 4.7 µF | 50V | Radial electrolytic |
Note: The exact designator labels on your board may differ depending on board revision. Always verify capacitance and voltage by reading the markings on each original capacitor before removal. Photograph the board before starting work.
Power regulation board capacitors
The Stacy contains a separate power regulation board that converts the 18V DC input from the external adapter to the +5V, +12V, and -12V rails required by the system. This board contains additional electrolytic capacitors that are critical to stable operation.
| C101 | 2200 µF | 25V | Radial electrolytic | Input filter (18V DC side) |
| C102 | 1000 µF | 16V | Radial electrolytic | +5V output filter |
| C103 | 1000 µF | 16V | Radial electrolytic | +5V output filter |
| C104 | 470 µF | 25V | Radial electrolytic | +12V output filter |
| C105 | 220 µF | 25V | Radial electrolytic | -12V output filter |
| C106 | 100 µF | 25V | Radial electrolytic | Regulation feedback |
| C107 | 47 µF | 25V | Radial electrolytic | |
| C108 | 10 µF | 50V | Radial electrolytic |
LCD inverter board
The LCD backlight inverter board contains 2–3 small electrolytic capacitors that can cause flickering or backlight failure when degraded. These are typically:
| Capacitance | Voltage | Quantity | Notes |
| 47 µF | 25V | 1 | Input filter |
| 10 µF | 50V | 1 | Feedback |
| 4.7 µF | 50V | 1 | Output stage |
Capacitor replacement procedure
- Disconnect AC adapter and allow to sit for several minutes — No mains-voltage components inside (external PSU), but allow any residual charge to dissipate.
- Open the case — Remove bottom screws, separate case halves carefully.
- Photograph the board — Record capacitor orientations and locations before beginning.
- Remove old capacitors — Heat each lead and use desoldering pump or wick. For stubborn joints, add fresh solder first to improve thermal transfer.
- Clean pads — Remove residual solder and any leaked electrolyte with IPA.
- Install replacements — Observe correct polarity (negative stripe on capacitor body aligns with negative pad marking). Insert leads, solder, and trim.
- Inspect solder joints — Check for bridges, cold joints, and correct polarity under magnification.
- Test for shorts — Use multimeter to check for shorts between power rails and ground before powering on.
- Power up and test — Connect AC adapter. Verify voltage rails. Boot the system and test all functions.
Recommended replacement specifications
When selecting replacement capacitors:
- Match or exceed original voltage rating — e.g. replace a 16V cap with 16V or 25V, never lower.
- Match original capacitance — or increase slightly (up to 2×) for bulk filter capacitors on power rails.
- Use quality brands — Panasonic FR-series, Nichicon UPW/UHE, Rubycon ZLH are suitable choices.
- Low-ESR types recommended for power rail capacitors.
- Verify physical dimensions — Replacement must fit the PCB footprint and clear surrounding components and the case when reassembled.
Voltage verification after recap
After recapping, measure the following voltage rails at the motherboard:
| Rail | Expected voltage |
| +5V | 4.75V – 5.25V |
| +12V | 11.4V – 12.6V |
| -12V | -10.8V – -13.2V |
If voltages are out of range after recapping, check for installation errors (wrong polarity, wrong value) and inspect voltage regulator ICs.
Related maintenance pages
