Atari Mega STE Troubleshooting
Revision as of 20:41, 12 April 2026 by Josh (talk | contribs) (Create Mega STE troubleshooting guide)
This guide provides diagnostic procedures and solutions for common faults encountered in the Atari Mega STE computer. The Mega STE combines STE hardware with a 16 MHz clock option, a Phihong PSU (shared with the Atari TT030), and professional I/O — each introducing unique failure modes beyond the standard ST family.
Safety Warning
Preliminary Checks
Before disassembly:
  1. Mains lead and fuse — check continuity from plug to IEC connector.
  2. PSU power switch — verify continuity in the ON position with the machine unplugged.
  3. Keyboard cable — the Mega STE uses a coiled cable with DIN connectors (not RJ12 like the Mega ST). Verify all pins are intact.
  4. CPU speed switch — the Mega STE has a software-switchable 8/16 MHz CPU clock. Some old software only runs at 8 MHz; boot issues may be speed-related.
  5. RAM configuration — the Mega STE uses 30-pin SIMMs (1 MB, 2 MB, or 4 MB configurations). Mismatched or faulty SIMMs will prevent boot.
Power Supply Diagnostics
The Mega STE uses the Phihong PSM-5341 internal PSU, the same unit found in the Atari TT030. It is a switchmode design mounted internally.
Voltage Specifications
Mega STE PSU Output Voltages
Rail Nominal Acceptable Range
+5 V 5.00 V 4.75–5.25 V
+12 V 12.00 V 11.4–12.6 V
-12 V -12.00 V -11.4 to -12.6 V
GND 0 V
PSU Fault Table
PSU Symptom Diagnosis
Completely dead — no LED, no fan Blown mains fuse (internal or external); open power switch Check fuse continuity. Check switch continuity in ON position
PSU ticks but does not start Overcurrent protection tripping; shorted output capacitor Disconnect load and test with dummy resistors. Check output caps for shorts
+5 V low (< 4.75 V) Aged electrolytic capacitors; failed voltage reference Recap the PSU. Check TL431 shunt regulator and feedback network
+5 V high (> 5.5 V) Failed feedback loop; shorted opto-coupler Dangerous — do not operate. Replace opto-coupler and verify regulation loop
+12 V absent Failed 12 V rectifier or filter cap Check 12 V diode and associated caps. The -12 V rail is used for serial ports and VME; absence may not prevent boot but will disable RS-232
Excessive ripple (> 300 mV on +5 V) Dried-out filter capacitors Recap all secondary-side electrolytics. See Atari Mega STE Capacitor Replacement Guide
Motherboard — No Boot
White/Blank Screen
A blank screen on the Mega STE has similar causes to the Mega ST but with additional considerations:
  1. Verify PSU outputs — +5 V and +12 V within spec at the motherboard power connector.
  2. Check 16 MHz oscillator — the Mega STE's main clock is a 32 MHz crystal divided to 16 MHz (or 8 MHz in compatibility mode). Verify 16 MHz at the CPU clock pin.
  3. Check /RESET line — should pulse low on power-on (~100–200 ms) then go high.
  4. Check /HALT line — if held low, the CPU has halted due to a bus error.
GLUE and MMU Custom Chips
The Mega STE uses revised GLUE and MMU gate arrays that support 16 MHz operation. These are surface-mount custom Atari parts and are not field-replaceable without specialised equipment.
  • GLUE failure: No video sync, no bus arbitration. The machine appears completely dead despite good power.
  • MMU failure: RAM not accessible. CPU halts immediately after reset.
Both are rare failures but can occur from ESD damage or voltage transients.
TOS ROM
The Mega STE shipped with TOS 2.05 or TOS 2.06 in ROM. These are specific to the Mega STE / TT030 family and are not interchangeable with 520ST/1040ST TOS ROMs.
TOS ROM Fault Table
White screen, no activity ROM not detected; bad contact in ROM sockets Remove, clean pins with IPA, reseat firmly
Corrupted desktop or garbled text Partially failed ROM; bit-rot in mask ROM Test with known-good TOS 2.06 set. Consider EPROM replacement
Boot to desktop but crashes on GEM operations Incompatible TOS version installed Verify correct TOS version for Mega STE (2.05 or 2.06 only)
RAM (30-pin SIMMs)
The Mega STE uses 30-pin SIMMs in groups of four. Mismatched SIMMs, incorrect speed ratings, or failed modules will cause boot failures.
RAM Fault Table
No boot, no video All SIMM banks failed or absent Verify SIMMs are seated. Try with a single bank of 4 matched SIMMs
Random crashes, data corruption Marginal SIMM; speed too slow for 16 MHz operation Use 80 ns or faster SIMMs. Test each SIMM individually in a known-good slot
Incorrect RAM count reported Mismatched SIMM sizes in a bank All four SIMMs in a bank must be identical capacity
Boot at 8 MHz but crash at 16 MHz SIMMs too slow (> 100 ns) Replace with 80 ns or 70 ns SIMMs
Video and Display Issues
The Mega STE supports the same three display modes as the ST/STE line: 320×200 (16 colour), 640×200 (4 colour), 640×400 (mono). It detects monitor type via pin 4 (Mono Detect) on the 13-pin DIN.
Video Fault Table
No video output Shifter/GLUE failure; monitor cable fault Check 13-pin DIN cable. Verify H-sync and V-sync with oscilloscope
Rolling or flickering on mono monitor V-sync issue; incorrect monitor detection Check pin 4 grounding. Verify V-sync signal at connector
STE enhanced graphics modes not working Software not STE-aware; DMA sound hardware conflict Verify software supports STE. Check the GST Shifter chip
Colour fringing or ghosting Excessive PSU ripple; poor video cable Recap PSU. Use a short, well-shielded monitor cable
Keyboard and Mouse
The Mega STE uses a detachable keyboard with DIN connector (same keyboard unit as the TT030). The mouse and joystick ports are on the keyboard unit itself.
Keyboard/Mouse Fault Table
No keyboard response Bad DIN cable; failed keyboard controller (HD6301) Test cable continuity. Try a known-good TT030 keyboard
Mouse erratic or non-responsive Dirty mouse ball/rollers (ball mice); ADB-like controller fault Clean mouse mechanism. Check mouse port connector for bent pins
Middle mouse button not working Software does not support third button (Mega STE supports 3-button mouse) Verify application supports 3-button input
Floppy Drive
Early Mega STEs shipped with a 720 KB DD drive; later units include a 1.44 MB HD drive. The HD drive requires TOS 2.06 for full support.
Floppy Fault Table
Cannot read HD (1.44 MB) disks DD-only drive fitted; TOS 2.05 does not fully support HD Verify drive type. Update to TOS 2.06 if HD drive is installed
Drive not detected AJAX floppy controller failure; cable fault Check cable. Verify AJAX chip has clock and select signals
Intermittent read errors Dirty heads; marginal PSU under motor load Clean heads with IPA. Check +12 V stability during access
Continuous head seeking Track 0 sensor failure; mechanical jam Check optical sensor. Lubricate head carriage if stiff
SCSI Hard Drive
The Mega STE includes an internal ACSI/SCSI hard drive bay with optional hard disk controller. The 1 MB model shipped without the controller board.
Hard Drive Fault Table
Hard drive not detected at boot No SCSI controller board installed (1 MB model); SCSI ID conflict Verify controller is present. Check SCSI ID is unique (typically ID 0)
Drive spins but not recognised Bad SCSI termination; incorrect driver Ensure termination resistors are fitted on the last device. Update AHDI/ICD driver
Data corruption Marginal SCSI cable; DMA timing issues at 16 MHz Use short, high-quality SCSI cable. Try 8 MHz mode to rule out timing
Clicking or grinding sounds Mechanical drive failure Back up immediately if possible. Replace drive (SCSI2SD or BlueSCSI as modern alternatives)
Serial Ports (RS-232)
The Mega STE has three RS-232 ports (all DE-9 connectors) plus a LocalTalk/RS-422 port. The -12 V rail powers the RS-232 line drivers.
Serial Port Fault Table
No serial output on any port -12 V rail absent from PSU Check PSU -12 V output. Repair/recap PSU
One port dead, others work Failed MAX232 or equivalent line driver for that port Identify and replace the line driver IC
LocalTalk port non-functional Normal — Atari never shipped AppleTalk software. Port is electrically RS-422 Use RS-422 serial software; do not expect Mac networking without third-party drivers
VME Slot
The Mega STE includes a single VMEbus expansion slot. Common VME cards include Ethernet adapters and accelerator boards.
  • Card not detected: Verify card is fully seated. Check +5 V and +12 V at VME connector.
  • System unstable with card fitted: Some VME cards draw significant power. Check PSU capacity and voltage stability under load.
  • Bus errors with VME card: Address conflicts. Verify the card's address range does not overlap TOS or system RAM.
CPU Speed Issues
The Mega STE's 8/16 MHz switch is software-controlled (via the system control panel or XBIOS calls). The hardware supports both speeds, but compatibility issues exist.
CPU Speed Fault Table
Software crashes at 16 MHz but works at 8 MHz Timing-sensitive code not compatible with 16 MHz; slow SIMMs Switch to 8 MHz for that software. Upgrade to 80 ns SIMMs
Cannot switch speed — stuck at 8 MHz Control panel setting not saved; hardware fault in clock divider Check NVRAM / system preferences. Inspect clock generation circuitry
Random lockups at 16 MHz Marginal PSU; insufficient decoupling Recap PSU. Add 100 nF ceramic decoupling capacitors near CPU and RAM
FPU (Floating Point Unit)
The Mega STE has a socket for an optional Motorola 68881 or 68882 FPU.
  • FPU not detected by software: Verify the chip is correctly oriented and fully seated. Check for bent pins.
  • Math errors or crashes in FPU-enabled software: FPU may be a remarked or counterfeit part. Test with a known-good 68881/82.
  • System unstable after FPU installation: Some FPU clock speeds are incompatible. Use a 68882 rated for the CPU clock speed (16 MHz).
DMA Sound (STE Enhanced Audio)
The Mega STE inherits the STE's DMA sound hardware (8-bit stereo PCM, up to 50 kHz sample rate) in addition to the standard YM2149 PSG.
  • No DMA sound output: Check the DMA sound registers are being written correctly. Verify the LMC1992 audio mixer chip is functional.
  • Distorted audio: Recap audio section capacitors. Check for cold solder joints on the audio output stage.
  • YM2149 works but DMA does not: GST Shifter or DMA controller fault. These are custom Atari parts.
